- 471
A 200-km-long high-voltage transmission line 2 cm in diameter carries a steady current of 1000 A. If the conductor is copper with a free charge density of 8.5 x 10^28 electrons per cubic meter, how many years does it take one electron to travel th full length of the cable?
I know that you need to use this equation: [tex]R=p\frac {l}{A}[/tex] and I think I will also need this equation: [tex] I= \frac {\Delta {Q}}{\Delta t}[/tex], but I'm not entirely sure.
The thing I most confused about is the "density of 8.5 x 10^28 electrons per cubic meter. Is that a volume? Are you suppose to use: [tex] I= \frac {\Delta {Q}}{\Delta t}[/tex] to find the time (years)?? I'm stuck from here on out. It'd be great if you could give me some hints as to how to continue. Thanks in advance!
