Current and Watts
  1. Jul 15, 2011 #1
    Can you determine current given only the watts?
    Ex) if you have a lightbulb with 120 Watts, can you determine the current (charge) that flows through it in a second, for example?
  3. Jul 15, 2011 #2
    sophiecentaur
    2017 Award
    Nope.
    In a low voltage circuit, you need a lot of current to produce the same power as for a high voltage circuit.
    Remember - Power (Watts) = Volts (Volts) X Current (Amps)
  4. Jul 15, 2011 #3
    From the way the question is phrased, no was the correct answer.
    You need any 2 (Voltage/Current/Resistance/Power) to determine an unknown in basic circuits.
    However, if you MEANT (since you referenced a 120W light bulb) how much current will the bulb draw on a standard 120 VAC circuit, then that is simply P=V*I ---> I = P/V = 120W/120V = 1 Amp.
    A 120 W rated bulb will not actually draw/dissipate 120 W of power unless it is powered by the expected voltage (ie a 12V battery will not push 10 amps through it).
  5. Jul 15, 2011 #4
    jambaugh
    In general no, you need also voltage:
    Power = voltage times current.
    In the lightbulb example you probably know the voltage implicitly i.e. it's a lightbulb used with 120V AC house lights. In that case you would solve to find the current is 1 amp (1 coulomb per second).
    current = power / voltage
Loading...
Similar Threads for Current Watts Date
I Current and Ohm’s Law Apr 15, 2018
B 4 Questions About Lenz's Law Experiment Apr 15, 2018
B Current in a circuit Apr 3, 2018
B Meaning of Current in Ohm's law Mar 30, 2018
I Question about the physics term "work" Dec 23, 2017
