Current, changing B field
  • Thread starter meganw
meganw
97
(a) If the resistance of the resistor in the figure below is slowly increased, what is the direction of the current induced in the small circular loop inside the larger loop?
(b) What would it be if the small loop were placed outside the larger one, to the left?
V = IR
E (emf) = d(flux)/dt
flux = B(perp.) * A
I know we have to use the right hand rule, but I think I must be doing it wrong.
For a, we know that B must be decreasing becase I is decreasing (and B = u(o) * I(encl.)/dl)
According to Lentz's law, if the flux(B*A) is decreasing then the induced current will have the same field as the other. So in order for both fields to be pointing out as they are, the current must go in the counterclockwise direction in the inner loop.
for part b though, I use the right hand rule and get the same thing-counterclockwishe? But the answer says its clockwise. I don't understand. The flux of the large loop is still decreasing, so doesn't that mean the fields again point in the same direction? That would be both pointing outward. If I use my RHR that I know, in order for the B field to be pointing in the same direction of the induced current, it must go counterclockwise.
Is there something to be said for the fact that it is outside of the loop?
Thanks!
Answers and Replies
Doc Al
Mentor
45,410
1,845
What matters is the flux through the small loop and how it is changing. In what direction does the field point just outside and to the left of the big loop? (That's where the small loop would be for part b.) How is it changing?
Suggested for: Current, changing B field
  • Last Post
  • Last Post
16K
  • Last Post
