Current circuits
  • Thread starter arod2812
In the absence of a nearby metal object, the two inductances LA and LB in a heterodyne metal detector are the same, and the resonant frequencies of the two oscillator circuits have the same value of 430 kHz. When the search coil (inductor B) is brought near a buried metal object, a beat frequency of 4.1 kHz is heard. By what percentage does the buried object reduce the inductance of the search coil?
I don't understand how the inductance REDUCES (as the question says) because the frequency decreases, so I would expect the inductance to increase. I am also confused about how to calculate percent change.
f=1/(2*pi*SqRt(LC) . . . capacitance remains the same and is therefore a constant...
430000 Hz = 1/ (2*pi*SqRt(L)) --> La=1.37E-13
and
4100 Hz = 1/(2*pi*SqRt(L)) --> Lb=1.51E-9
I then took the difference between these two inductance values and divided by Lb to get the % change. I don't think I have the right answer though. IS ANY OF THIS CORRECT?
Answers and Replies
If a beat frequency of 4.1 KHz is heard, that means that the difference between the frequencies of the two coils is 4.1KHz. The frequency in the sense coil can be higher
It's clearer to keep 1/sqrt(C) in this answer or replace 2*pi/sqrt(C) by a constant. It will divide off later. The rest of your work is correct if you use the correct frequency.
Related Threads on Current circuits
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
