• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Current density
  • Thread starter dRic2
dRic2
77
For a configuration of charges and currents confined within a volume ##V##, show that
$$\int_V \mathbf J d \tau = \frac {d \mathbf p}{dt}$$
where ##\mathbf p## is the total dipole moment.
2. Relevant equations
3. The attempt at a solution
I have one question: since the configuration of charges and currents is confined within a volume can I assume
$$∇ \cdot \mathbf J =0 $$
I mean, if there is no "in" nor "out", ##\frac {\partial \rho}{\partial t}## should be zero, right ?
Delta2
Insights Author
573
Not sure , I think you can only assume that if S is the boundary surface of V, then ##\oint_S \mathbf{J\cdot dS}=0## which by divergence theorem means that $$\int_V \nabla \cdot \mathbf{J}dV=0$$ but this last equality holds only for volume V and not for every subvolume of V so this does not imply that ##\nabla \cdot \mathbf{J}=0##.
The whole point is that the charges and currents are not confined to a random subvolume of V so there can be flux in or out through a subvolume of V.
dRic2
77
Ok, I've given up on this one...
The exercise came with a hint: "Evaluate ##\int_V ∇ \cdot( x \mathbf J) d \tau## "
Here as I tried (but it is wrong):
$$ \int_V ∇ \cdot ( x \mathbf J) d \tau = \int_V x ∇ \cdot \mathbf J d \tau + \int_V \mathbf J \cdot ∇ x d \tau$$
then I said "well ##\int_V x ∇ \cdot \mathbf J d \tau## should be zero because..." but it is wrong.
I checked the solutions and the author says:
$$\int_V ∇ \cdot ( x \mathbf J) d \tau = \int_A x \mathbf J \cdot d \mathbf a$$
is zero because since ##\mathbf J## is entirely inside ##V##, it is zero on the surface.
What ? I do not understand... How can he claim that from ##\int_A \mathbf J \cdot d \mathbf a = 0## follows ##\int_A x \mathbf J \cdot d \mathbf a = 0## ?
PS: how do you write the symbol for the integral over a closed surface ?
Delta2
Insights Author
573
It is not only that ##\int_A \mathbf J \cdot d \mathbf a = 0## at the boundary surface A, it is also ##J=0## at the boundary surface. Because the current and charges are confined within the volume V, the current density J is zero everywhere at the boundary surface A of V. If there was current density ##\mathbf{J}\neq 0## somewhere at the boundary surface A, this means there is flow of charge into or outside the volume V.
The symbol for the integral over a closed surface is \oint. Generally you can check the tex commands used by right clicking on an equation and choose view as tex commands and this will open an window with the Latex commands used to make that equation.
dRic2
77
If there was current density J≠0J≠0\mathbf{J}\neq 0 somewhere at the boundary surface A, this means there is flow of charge into or outside the volume V.
Aahhhhhhhhhhhhhhhhh Now I get it!! I used to think "well, there could be some charge moving around the surface"... but that wouldn't be a "volumetric" current density: that would be a surface current density! Now everything fits! Thank you :)
Delta2
Insights Author
573
Ok fine but I have to correct my self a bit, it is not exactly that ##J=0## at the boundary surface but that the component of ##J## normal to the surface element dA is zero, everywhere in the boundary surface (otherwise there would be flow of charge into or outside the volume V), so the dot product ##\mathbf{J}\cdot\mathbf{da}## is zero everywhere in the boundary surface.
dRic2
77
If I recall correctly ##\mathbf J = \frac {d \mathbf I}{d a_{⊥}}## so it has to be normal to the boundary (no need to specify further).
kuruman
Insights Author
1,590
I have never seen this definition. Current ##I## is a scalar, not a vector. The total current through a surface ##S## is $$I=\int_S \vec J \cdot \hat n~dS$$ where ##\hat n~## is the local normal to the surface. This is another way of saying what @Delta2 posted in #6.
dRic2
77
I adopted the definition given in Griffiths' "Introduction to electrodynamics": (pag 208) the current ##\mathbf I## is defined as a vector, and from that follows the definition of ##\mathbf J## that I posted (pag 210).
kuruman
Insights Author
1,590
I see. I prefer to stick with ##\vec J## because that's what appears in Maxwell's equations, Ohm's law in vector form and the continuity equation.
dRic2
77
I see. I prefer to stick with →JJ→\vec J because that's what appears in Maxwell's equations, Ohm's law in vector form and the continuity equation.
I don't see any contradictions. The definition of ##\mathbf J## is the same, the only things that changes is the definition of ##I##, but ##I## does not appear in Maxwell equations, nor continuity equation. I don't know about Ohm's law for now.
PeroK
Insights Author
2018 Award
9,095
3,279
This question came up recently. If the current is contained in some volume, then you can argue that the current on the boundary is either zero or tangential to the boundary, hence ##\vec{J}.\vec{da} = 0##.
But, you can always take the volume over which you are integrating to be larger than the volume that contains the current. That adds no extra charge or dipole moment and ensures that the current density is zero on the boundary.
Want to reply to this thread?
"Current density" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
