Current of Sliding Rod
  1. May 16, 2015 #1
    If the U-shaped conductor in the figure has resistivity ρ (in Ω.m), whereas that of the moving rod is negligible, find the current I at time t. Assume the rod has length L, starts at the bottom of the U at t = 0, and moves with uniform speed v in the constant magnetic field B shown in the figure. The cross-sectional area of the rod and all parts of the U is A (in m2). Express your answer in terms of the given quantities.
    2. Relevant equations
    I = magnetic flux / Resistance
    Resistance = p*L/A where p is the resistivity
    3. The attempt at a solution
    I = B*A*v/p*(L/A)
    The current is equal to the magnetic field times the Area times the velocity, divided by Resistance (which is the resistivity times the Length times the Area)
    What am I missing here because that formula that I calculated is wrong?
  3. May 16, 2015 #2
    instead of going for that formula, go for the basic definition if induced EMF. As the rod moves with a velocity v, what is the emf induced on it?
  4. May 16, 2015 #3
    Emf would be : B*A*v
    So then where does the resistivity come in?
  5. May 16, 2015 #4
    no. emf is not BAv. Its Blv where l is the length of the rod. think about it. try to derive it.
  6. May 16, 2015 #5
    I'm taking an algebra based physics course so I'm not too comfortable with deriving but looking at an example of the derived form:
    so after deriving the Emf equation, Emf = B L v and I would them be B L^2 v / p L/A ?
  7. May 16, 2015 #6
    Here is the picture for the problem, sorry forgot to post it
  8. May 16, 2015 #7
    TSny
    2017 Award
    How did L become L2.
    Also, note that the resistance is in the U-shaped conductor. So, when using R = pL/A you need to consider the length of the U-shaped portion of the circuit. So, the L here is not the same as the L for the length of the moving rod. The length of the U-shaped portion will depend on the time t.
  9. May 16, 2015 #8
    I'm confused with what you would do with the time t. If the length changes based on t then can I just multiply the length by t?
  10. May 16, 2015 #9
    TSny
    2017 Award
    In the figure below, let x be the distance the rod has traveled. Can you express the length of the U-shaped portion of the circuit in terms of x and L? Then you can express x in terms of t.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Current of Sliding Rod
  1. Rings sliding on rods (Replies: 12)
Loading...
