What is the value of t when q(t) is equal to 1.204 seconds in a circuit?
  • Thread starter Sajjad
In summary, the conversation revolved around finding the value of t and current i in a circuit with a charge flow described by the equation q(t)=[3e^(-t) - 5e^(-2t)]. The process involved taking the derivative and using a formula to eventually solve for t=1.204 seconds. The conversation also touched on finding the maximum/minimum charge by setting q'(t)=0.
Sajjad
The charge flowing through a circuit is
q(t)=[3e^(-t) - 5e^(-2t)]--------(1)
find the value of t and then current i.
as i=dq/dt.
i am doing it like this
i=-3e^-t + 10e^-2t.....taking derivative
let e^-t=u...for eaze
i=10[u^2-3u/10]
let 1=0 then
10[u^2-3u/10]=0
10[u^2 - 2(u)(3/20) + (3/20)^2 - (3/20)^2]=0 ...using formula
10[u-3/20]^2 - 10[3/20]^2=0
10[u-3/20]^2=10[3/20]^2
10[u-3/20]^2=9/40
[u-3/20]^2=9/400
u-3/20=sqrt[9/400]
u=sqrt[9/400] + 3/20
e^-t = 3/20 + 3/20...as u=e^-t
Taking log on both side
ln[e^-t]= ln[3/10]
-t= -1.204
t= 1.204 seconds |------ am i doing ok till here?
by putting this in equation 1 we will get the vale for charge,q.
Like I said in the physics forum, when do you want to find t? If you let q'(t) = 0, then you are finding the maximum / minimum charge.
1. How do you solve q(t) for t=1.204s?
To solve q(t) for t=1.204s, you need to plug in the value of t into the equation for q(t) and solve for q. This will give you the value of q at t=1.204s.
2. What is the significance of t=1.204s in solving q(t)?
The value of t=1.204s is the specific time at which we are trying to find the value of q. This could represent a specific moment in an experiment or a point in time on a graph.
3. Can you explain the process of solving q(t) for t=1.204s?
To solve q(t) for t=1.204s, you need to substitute the value of t into the equation for q(t), simplify the equation, and then solve for q. This will give you the value of q at t=1.204s.
4. Is there a specific formula or method for solving q(t) for t=1.204s?
Yes, the formula for q(t) will depend on the specific problem or experiment. However, the general process for solving q(t) for a specific value of t is the same: substitute the value of t into the equation and solve for q.
5. Can you provide an example of solving q(t) for t=1.204s?
Sure, let's say we have the equation q(t) = 2t + 5 and we want to find q at t=1.204s. We would substitute 1.204 for t and get q(1.204) = 2(1.204) + 5 = 7.408. Therefore, at t=1.204s, q=7.408.
