1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Current Source
  1. May 18, 2014 #1
    Question 1: For the circuit below, determine what happens at maximum resistance when varying the 10K (decade box) variable load.
    Question 2:Explain the answer to the previous question, in terms of voltage compliance of the current source.
    Question 3:What causes detectable variations in output current as the load is varied within the compliance range.
    Question 4:Verify the explanation in the previous question, by making use of diagrams.
    2. Relevant equations
    No equations
    3. The attempt at a solution
    Solution 1:
    At maximum resistance, the saturation is reached, and the diode does not work properly anymore, as the collector current begins to drop.
    Solution 2:
    At maximum resistance, the collector current and the emitter voltage will change from being 1mA, and 1 V, respectively.
    Solution 3:
    The detectable variations in output current are the due to the the ammeter's installation into the circuit.
    Solution 4:
    In the diagram below, the top figure is actual data collected from experiment, and the lower image is a theoretical model of how transistors function. The similarities can be seen.
    Are all four of my answers correct?
  3. May 19, 2014 #2
    Staff: Mentor
    Diode? :wink:
    Where did these values come from?
    Are you given an approximate value for β?
Have something to add?
Draft saved Draft deleted
