Current through a wire help
In summary, the conversation is about a homework problem involving current, length, and diameter of a copper wire extension cord. The question is to find the total number of collisions that free electrons undergo in one second, but the person is unsure where to begin and is seeking help. Possible equations and resources are also mentioned.
aftershock
110
A current of I=8.0A is flowing in a typical extension cord of length L=3.00m. The cord is made of copper wire with diameter d=1.5mm.
The charge of the electron is e=1.6*10^-19C. The resisitivity of copper is [tex]\rho[/tex]=1.7*10^-8[tex]\Omega[/tex] m. The concentration of free electrons in copper is n=8.5*10^28m^-3
I honestly have no idea. There's nothing in my book about collisions at all other than saying that's what causes resistance.
Honestly have no idea where to begin... there is literally not a thing about this in my book. It's from an online homework assignment.
hi aftershock! :smile:
erm :redface:what's the question? :confused:
Wow I can't believe I left that part off, sorry.
Find the total number of collisions that all free electrons undergo in one second.
I was able to see the answer and the equation used was something along the lines of m/([tex]\rho[/tex]ne2)
I have no idea where that came from though.
he he :biggrin:
not something I'm familiar with :redface:, but you might get some help from http://en.wikipedia.org/wiki/Classical_and_quantum_conductivity#Classical_conductivity http://en.wikipedia.org/wiki/Drude_model or http://en.wikipedia.org/wiki/Ohm's_Law :smile:
As a scientist, it is important to approach problems with an open and curious mind. While it may not be explicitly stated in your textbook, there are many equations and principles that can help us solve this problem.
First, let's define some terms. Current is the flow of electric charge, typically measured in Amperes (A). In this case, we are given that the current is 8.0A. Length is measured in meters (m), and we are given that the length of the cord is 3.00m. Diameter is measured in millimeters (mm), but we can convert it to meters for our calculations (1.5mm = 0.0015m).
The equation that relates current, length, and resistance is Ohm's Law, which states that V=IR, where V is voltage, I is current, and R is resistance. In this case, we are given the current and length, so we can solve for the resistance of the wire.
R = V/I = (8.0A)(3.00m) = 24.0Ω
Next, we need to consider the properties of the copper wire. The resistivity of a material is a measure of how well it resists the flow of electricity. The higher the resistivity, the more difficult it is for electricity to flow through the material. The resistivity of copper is given as 1.7*10^-8Ωm.
We can use the formula R=ρL/A, where ρ is the resistivity, L is the length, and A is the cross-sectional area, to calculate the resistance of the wire. We know the length and resistivity, but we need to find the cross-sectional area. We can do this by using the formula A=πr^2, where r is the radius of the wire.
r = d/2 = 0.0015m/2 = 0.00075m
A = π(0.00075m)^2 = 1.767*10^-6m^2
Now we can plug in our values to solve for the resistance of the wire.
R = (1.7*10^-8Ωm)(3.00m)/(1.767*10^-6m^2) = 0.0288Ω
This is a very small resistance, which is expected for a copper wire. But why does copper
1. What is current through a wire?
Current through a wire refers to the flow of electric charge, typically in the form of electrons, through a conductive material such as a wire. It is measured in units of amperes (A).
2. How is current through a wire calculated?
The current through a wire can be calculated using Ohm's Law, which states that current (I) is equal to the voltage (V) divided by the resistance (R), or I = V/R. This equation can be rearranged to calculate any of the three variables, given the other two.
3. What factors affect the current through a wire?
The current through a wire is affected by the voltage applied, the resistance of the wire, and the type of material the wire is made of. Additionally, the length and thickness of the wire can also impact the current, as well as external factors such as temperature and humidity.
4. What are some common applications of current through a wire?
Current through a wire is used in a wide range of electrical devices and systems, such as lighting, electronics, motors, and generators. It is also used in transportation systems, such as trains and cars, and in power distribution networks.
5. How can current through a wire be controlled or regulated?
The current through a wire can be controlled through the use of devices such as resistors, transistors, and diodes, which can manipulate the flow of electrons. Additionally, circuits can be designed with specific components and configurations to regulate the current and prevent overloading or damage to the wire.
10K
9K
13K
