Homework Help: Current through diode
  1. Jun 30, 2010 #1
    find current through each diode, suppose that they are ideal (use the second approach)
    [PLAIN]http://img30.imageshack.us/img30/102/86772682.jpg [Broken]
    R is 10kohms
    3. The attempt at a solution
    a) (12-0.7)/10k = 1.13 mA
    b) 0 because diode will be open, actually i added up the two voltate sources and i have a voltage source of 16Volts where + is connected with diodes - and - is connected with diodes + so its reverse biased, hence current will be 0
    c) i added up the voltage sources i have 10 volts and its not reversed biased diodes voltage source will be 0.7
    hence
    (15-0.7)/10k = 1.43 mA
    d) added up voltage sources i had a source of 2 volts
    hence
    (2-0.7)/10000 = 0.13mA
    am i correct?
  3. Jun 30, 2010 #2
    Yeah a,b and d are correct, but in (c), the voltage across diode and resistor is 10 v and not 15 v as you have put in the equation.
  4. Jun 30, 2010 #3
    you are right, thanks a lot :))
