1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Currents and magnetic fields
  1. Oct 28, 2006 #1
    Please help me if you can...
    question: Use the following quantities to calculate the magnetic feild strength of the horseshoe magnet.
    Mass of coil: 20 grams
    current in coil: 2.0 amps
    length of bottom of coil: 10cm
    angle coil makes with vertical: 30 degrees
    Hint: Equate magnetic force on bottom of coil to the horizontal componen of the coils weight.
    The question also adds that there are at least 3 assuptions made in answering this question.
    I've got a diagram
    http://i122.photobucket.com/albums/o272/science_f/0000000000000coilandmagnet.jpg
    I don't know where to start in the calculating proccess:confused: Can someone please help me with the starting point and i'll try and progress from there....this is the first time i've seen a problem like this:blushing:
  3. Oct 28, 2006 #2
    these are the formulas I know:
    B=F/IL
    F=BIL sin @
    B=kI/r
    B=2(pi)knI
    Where k is Amperes constant (2x10^-7NA^-2), L is the length of wire, I is the current, r is the radius of the wire (but in some cases the distance between wires), and F is the force.
    Here's another diagram with brainstorming but i'm not sure if i grasp the concept of this.....I think it is all wrong:cry:
    http://i122.photobucket.com/albums/o272/science_f/000000000000h.jpg
    I actually think that there isn't enough information to do the problem unless it is as simple as:
    F=mg=20x9.8=196
    B=F/IL
    B= 196/2.0x10
    B=9.8
    But i don't think that can be right
  4. Oct 28, 2006 #3
    OlderDan
    What is a horizontal component of weight? I don't think they really mean that. The magnet will exert a force on the lower branch of the coil. You need to think about the direction of the magnetic force. You also need to think about what is keeping the coil in position. There has to be something besides the magnetic force. Something has to be keeping the top of the coil in position. What will be the direction and magnitude of the force on the top of the coil? It will help if you rotate the image so that the magnet is in the plane of the page, and the loop is perpendicular to the page so that the 30 degree tilt can be seen.
  5. Oct 28, 2006 #4
    thanks for that every little bit of info helps
  6. Oct 29, 2006 #5
    OlderDan
    Hopefully you will recognize that this becomes a statics problem where one of the forces involved is a magnetic force. Think forces and torques and all the usual things you use for statics problems.
Similar Discussions: Currents and magnetic fields
Loading...
