Homework Help: Curvature When t=0
  1. Jun 1, 2014 #1
    Find the curvature of
    ##r(t) = \frac 4 9 (1+t)^ \frac 3 2 i + \frac 4 9 (1-t)^ \frac 3 2 j + \frac 1 3 t \hat k## at t=0
    2. Relevant equations
    K=1/|v| * |dT/dt|
    3. The attempt at a solution
    Found v.
    ##v= \frac 2 3 (1+t)^ \frac 1 2 i - \frac 2 3 (1-t)^ \frac 1 2 j + 1/3 \hat k##
    |v|=1
    v/|v|= <(2/3)(1+t)^(1/2), -(2/3)(1-t)^(3/2), 1/3>
    ##\vec T = \frac v (|v|) ##
    Take derivative of T.
    K(0)=1/1 * |dT/dt|
    ##= \sqrt( \frac 1 3 ^2 + \frac 1 3 ^2 )= \sqrt \frac 2 3 ##
    The answer is ## (\sqrt 2) / 3##. Where did I go wrong?
  3. Jun 1, 2014 #2
    Simon Bridge
    Please show your working for the time-derivative of the j term.
    Did you misplace a minus sign?
    Aside:
    * you used the letter k for two different things: avoid. Curvature is K or \kappa
    The way you wrote it, it looks like r(t) depends on the curvature.
    * it can help to indicate vectors: i,j,k are unit vectors?
    \vec r, \hat\imath, \hat\jmath, \hat k gets you ##\vec r, \hat\imath, \hat\jmath, \hat k##, or you can bold-face them.
  4. Jun 1, 2014 #3
    Ok. I tried to use capital K to denote curvature and changed the ##\hat k##
    The problem was copied as is. I fixed the minus signs but since they were squared anyway, it doesn't seem to make a difference.
  5. Jun 1, 2014 #4
    My question is
    1. was my method wrong?
    2. if no to 1 then is there something obviously wrong in any part?
  6. Jun 1, 2014 #5
    ehild
    You did not square the denominators.
    K(0)=1/1 * |dT/dt|
    ##= \sqrt{ \left(\frac {1} {3}\right) ^2 + \left(\frac {1} {3}\right) ^2 }=\frac{ \sqrt { 2}} {3} ##
    ehild
  7. Jun 2, 2014 #6
    Thanks so much!
Have something to add?
Draft saved Draft deleted
