Homework Help: Curve Length Question
  1. Jan 21, 2008 #1
    Help in Curve Length Question :D
    Find the length of the curve where x=cos(t) and y=t+sin(t) where 0[tex]\leq[/tex]t[tex]\leq[/tex][tex]\pi[/tex]
    2. Relevant equations
    [tex]\sqrt{(dx/dt)^2+(dy/dt)^2}[/tex]
    x=cos(t)
    dx/dt=-sin(t)
    y=t+sin(t)
    dy/dt=1+cos(t)
    3. The attempt at a solution
    [tex]\sqrt{(-sin(t))^2+(1+cost(t))^2}[/tex]
    [tex]\sqrt{(sint)^2+1+2cost+(cos(t))^2}[/tex]
    [tex]\sqrt{2+2cos(t)}[/tex]dt
    where I am stuck is how to do substitution to find the length of the curve.
    I found the antiderivative:
    (-1/3sint)(2+2cost)^(3/2) but when I substitute the limits pi and zero I get a length of zero :confused:
    any pointers to get me in the right direction? thanks
  3. Jan 21, 2008 #2
    rock.freak667
    I do not not think you integrated correctly. Show how you got that please.
  4. Jan 21, 2008 #3
    so, I substituted my two derivatives into the length equation, multiplied out my factors, and added sin(t)^2 with cos(t)^2 to get 1.
    Thus, sqrt of 1+1+2cos(t)
    is there a certain part of the integration that you see an error in?
  5. Jan 21, 2008 #4
    rock.freak667
    [tex]\int \sqrt{2+2cos(t)} dt[/tex]
    [tex]=\sqrt{2} \int \sqrt{1+cost} dt[/tex]
    [tex]=\sqrt{2} \int \sqrt{\frac{1-cos^2t}{1-cost} dt[/tex]
    [tex]=\sqrt{2} \int \sqrt{\frac{sin^2t}{1-cost} dt[/tex]
    [tex]=\sqrt{2} \int \frac{sint}{\sqrt{1-cost}} dt[/tex]
    Did you get that?
    Let u=1-cost => du=sint dt
    [tex]=\sqrt{2} \int u^{\frac{-1}{2}} du[/tex]
    [tex]= 2\sqrt{2}\sqrt{1-cost}[/tex]
  6. Jan 21, 2008 #5
    Oh, I see! It's matter of taking a further step and factoring out the [tex]\sqrt{2}[/tex] from my initial integral.
    One question, how did you go from 1+cost to (1-cost^2)/(1-cost)?
    Thanks rockfreak. I'll try the question using that.
  7. Jan 21, 2008 #6
    (a - b)*(a + b) = (a^2 - b^2). Always a good one to be able to quote off the top of your head.
  8. Jan 21, 2008 #7
    rock.freak667
    yeah it's basically that.
    Multiply the numerator and denominator by 1-cost
  9. Jan 21, 2008 #8
    dynamicsolo
    I might mention that this is one of those parametric curves where it is important to investigate its behavior before evaluating definite integrals to find arclengths. The integral from 0 to pi for this problem will give a non-zero value for the integral function rock.freak667 shows. However, you would be in trouble if you were asked to go from 0 to 2(pi) and naively used that function.
    I believe this curve is a cycloid; you would have to use a symmetry argument to take the arclength you find in going from 0 to pi and then doubling that result. This is a frequent potential pitfall in evaluating arclengths and enclosed areas for periodic curves (polar curves such as the rosettes often present such difficulties).
Loading...
