Curve recognition?
  1. Mar 26, 2006 #1
    I'm looking for software that can turn an http://people.deas.harvard.edu/~jones/cscie129/nu_lectures/lecture2/snd_vis/waves.jpg [Broken] back into the audio. Has anyone heard of something like this?
    If not, might there be a way I could do it using current software, such as some sort of curve fitting software combined with some sort of audio generation software?
    Thanks.
  3. Mar 27, 2006 #2
    Integral
    Staff Emeritus
    I recall seeing a article somewhere about someone retrieving the audio from a picture of a groove in a vinyl record.
    I don't see this as physics, more of a tecnnology thing.
  4. Mar 27, 2006 #3
    It's part of physics research, though, and most of physics research involves technology.
  5. Mar 31, 2006 #4
    -Job-
    Sounds doable. There's two obvious encessary steps: reading the data from the curves, outputting the audio. The first is not so hard, depending on how the input is described, if it is a black and white image as the one you linked then i would read each column of pixels, in search of the white pixel, the location of the white pixel giving the value (y-coordinate) of the curve at that column (x-coordinate). That's one approach.
    For converting the data into audio you'd have to do some research as to how audio is recorded. basically you want to map a sound wave into a sequence of values. Generally speaking audio is recorded by sampling every so often. You have some device, like a microphone, which is sensitive to sound waves. This device encodes its interaction with any sound wave at time t into a value. So if a microphone is exposed to a sound lasting for 1 second, then, if you sample every 1/10th of a second, the microphone will generate 10 interrupts to the computer, in each interrupt providing the value it read at time t. This is they key point, you need to know how the microphone encodes a sample into data, once you know that you can use the image of the wave to produce your samples.
    Notice that the sampling rate is usually pretty high. For .wav files the sample rate is 44100Mhz, so 44100 frames per second. Each frame usually having two samples (stereo), or one sample (mono).
    This sounds like an interesting project. It would be cool to make a program that converts a curve into the respective sound.
  6. Apr 13, 2006 #5
    well, I know Mathematica can turn a graph into a sound. If you could somehow make a fourier series of those waves (since they seem reasonably periodic), then you could graph it in mathematica and output a loopable audio clip.
Loading...
Similar Threads for Curve recognition Date
Books on pattern recognition Oct 12, 2016
Mathematica truncates my curves Feb 26, 2012
Speech Analysis/ Recognition Sep 26, 2010
Speech Recognition Dec 23, 2008
Dragon software vice recognition failed ram Dec 27, 2007
