Curve & Region Terminology Explained
In summary: Connected is also wrong. It is connected if it is not disconnected. A space is disconnected if there exist open sets X and Y such that D=XuY, and XnY is empty.
Swapnil
459
I am a little confused about some terminology when we talk about curves and regions (in the context of vectors for example).
Are these correct?
Curve Terminology:
Smooth: A curve C is said to be smooth if it is infinitely differentiable everywhere in its domain.
Continuous: A curve C is said to be continuous if it is once differentiable everywhere in its domain.
Simple: A curve C is said to be simple if it does not cross itself.
Region Terminology:
Connected: A region D in R^3 is said to be connected if any two points in D can be joined by a smooth curve completely in D.
Simply Connected: A region D in R^3, is said to be be simply connected if any simple closed curve inside D can be shrunk down to a point inside D.
Continuous is wrong. Continuous just means continuous. Nothing to do with differentiable.
If you omit the word 'smooth' you have described path connected.
These are different: the space { (x,sin(1/x)), 0<x<1} u { (0,y) : -1<y<1} is connected but not path connected.
A curve in only differentiable if it is continuous, you can't use that in your definition for Continuous. matt grime is correct, it means what a layman would think it means.
Thanks. So ...
Path Connected: A region D in R^3 is said to be path connected if any two points in D can be joined by a curve completely in D.
Also, is this one correct?
Simple: A region D in R^2 is called simple if its boundary consists of only horizontal and vertical curves. A region D in R^3 is simple if its boundary consists of only horizontal and vertical planes.
By the way, it's faily easy to show that any path connected set is connected, that any open, connected set is path connected and that any closed, connected set is path connected. However, there exist connected sets that are not path connected.
So are these correct or not:?
Closed: A curve C is said to be closed if its endpoints are the same.
What about this one?
Connected: A region D is called connected if for any two points P and Q in D, there is a curve C with endpoints P and Q.
I found this definition here:
http://www.math.utah.edu/online/2210/notes/ch18.pdf
We have already told you the deinfition of connected, and demonstrated that it is not equivalent to the condition you give which we also explained was what path connected meant (assuming you mean C to lie in D - if you don't it is a peculiar definition).
I have no idea what "horizontal and vertical curves" could MEAN! A region is "simple" if its boundary is connected.
What is a curve?
A curve is a continuous and smooth line that represents a set of points in a two-dimensional space.
What is the difference between a curve and a line?
A line is a straight path between two points, while a curve is a more general and flexible shape that can bend and change direction.
What is a region?
A region is a two-dimensional area that is enclosed by a curve or a set of curves.
What is the boundary of a region?
The boundary of a region is the curve or curves that enclose the area of the region.
What are some common types of curves and regions?
Some common types of curves include straight lines, circles, parabolas, and ellipses. Common types of regions include rectangles, triangles, and circles.
  • Topology and Analysis
  • Beyond the Standard Models
