Why do balls follow curved paths in Earth's gravity according to GR?
In summary, the GR equ. tells us that a test particle will follow a geodesic line in spacetime, which is not a geodesic line in space. Usually space is flat, but this does not imply that the geodesic line of a test particle in space is a straight line. In the presence of a gravitational field, the trajectory of a particle consists of two parts: gravitational acceleration and spatial curvature. The spacetime associated with the Earth's gravitational field is curved, leading to the curved trajectories of objects in its presence. This is due to the observation that spacetime is curved in the presence of mass or energy-momentum, and cannot be considered flat or straight in a gravitational field.
  • #36
my_wan said:
So which one is correct?
Both. They are not mutually exclusive. Why would you believe otherwise? I keep asking that question but am getting no response. Why is that?
I believe the confusion here lies in the notion that "gravity is a curvature in spacetime." This is not true, I don't care who says it. It sure wasn't Einstein whho said it. In fact he opposed such an idea. Claiming that gravity is a curvature in spacetime is redefining gravity to something other than how Einstein defined it. It is tidal forces which are a curvature in spacetime. Tidal force is defined quite differently than the gravitational force. The former is a tensor quantity while the later is a force 3-vector.
Consider a straight line through an accelerating object as defined in the frame of the object and perpendicular to the direction of acceleration. Isn't that line a geodesic in another frame of reference?
A geodesic is a geodesic in all coordinate systems. Whether a worldline is a geodesic or not does not depend on the particular coordinate system. I think you may be confusing with spatial lines with worldlines in spacetime. They are different things.
Tidal force tensor is a funny way to put it, ...
Funny? Why? Its not like I'm making this stuff up as I go along. Consider how this is explained in Black Holes & Time Warps, Kip S. Thorne, page 111
Therefore, spacetime curvature and tidal gravity must be precisely the same thing, expressed in different languages.
but no, there is no tidal forces. If you blew up a beach ball to the size and mass of the Earth where it is hollow everywhere but a thin crust then gravity is zero everywhere inside.
That's because the gravitational field inside a spherically symmetric shell is flat and thus there is zero spacetime curvature. In the reference frame of the ball itself the gravitational field inside also zero.
If there are any tidal forces then in what direction? From the center out? This would mean that gravity would accelerate you to the thin crust. Not so. You don't have tidal forces without difference in gravitational forces.
That is correct. However I was responding to the notion that the gravitational field at the center of the Earth is non-zero, not the center of some fictitious hollow sphere. Those are very different objects.
Pete
  • #37
By the way, one can have a curved spacetime and still have a flat space. A perfect example is found in cosmology. When one says that the universe is flat it means that space itself is flat. But spacetime is still curved everywhere.
my_wan said:
Again? Where did you ever ask me or even MeJennifer any of these question?
Oops! Sorry. I guess I wanted to ask that but never did. My appologies. But now the question has been asked.
Pete
  • #38
I forgot to mention that the term length is actually used in relativity when speaking about the integral of ds so please don't get me wrong. I merely wanted to indicate that the notion of zero length can be confusing since people often think in Euclidean terms when hearing of length. For example: the "distance" between two events A and B for two distinct events A and B can be zero. This cannot happen in Euclidean geometry where the distance between A and B being zero means that A = B, i.e. the points are not distinct but are the same. This phenomena is called degeneracy and the metric which defines "length/magnitude/distance" is call indefinite.
Pete
  • #39
pmb_phy said:
Its quite possible to have a gravitational field in a flat spacetime. In fact Einstein's equivalence principle depends on it.
MeJennifer said:
That does not make any sense to me Pete. Again I await an example where an observer could, in principle, measure such a field. For instance it would be interesting to know what actually gravitates in such a field.
It is a null geodesic simply because its length in spacetime is 0.
I think what Pete is getting at the artificial gravity that would be measured in an accelerating rocket. That would be an example of a "gravitational field" in flat spacetime. It can be handled by Rindler Spacetime which is the metric for flat spacetime (I think). I think it is a matter of definitions and terminology. It would be nice if we could clear the matter up so that we are using the same definitions and terminology.
  • #40
When I first responded to you I wasn't sure how you meant what you said and noted that. The ensuing debate only grew more convoluted so I took the time to consider exactly what the actual issues were.
Again, this is the first I seen this question. I now get where you make the distinction though. It seems our difficulty here is that you take gravity and GR (a gravitational field) as synonymous where I do don't. I as a matter of habit I separate the theoretical description from the thing being defined. When I speak of gravity I am speaking of the acceleration g alone, not its metric description in GR. The acceleration g defined wrt the mass is due to curvature in GR. This in no way implies that the metric of space-time is not influenced by a gravitational field in flat space-time. Flatness is the property of uniformity of the metric.
Yes, you are essentially right about the source of confusion. However, your definition of gravity assumes it refers to it's full description under GR.
Wiki - Gravitation said:
The terms gravitation and gravity are mostly interchangeable in everyday use, but in scientific usage a distinction may be made. "Gravitation" is a general term describing the attractive influence that all objects with mass exert on each other, while "gravity" specifically refers to a force that is supposed in some theories (such as Newton's) to be the cause of this attraction.
Here I must still disagree. I am not confusing spatial lines with world lines but in some situations a spatial lines can illustrate the world line of a particular observer, i.e., events. Consider, observer A stretches a long thin wire W in space such that it represents a straight line in the word line of A. Observer B passes the a midpoint perpendicular to W with a constant velocity wrt W. The wire is cone shaped in the world line of B. Observer C accelerates through the same path as B. In the world line of B the wire is a geodesic, as per the principle of equivalence.
World lines represent how events are ordered wrt an observer. This ordering defines the geometry of the distribution of things in space as defined by that observer. It would be just as easy to use events, such as flashes of light at various places, to represent this wire stretched in space.
I wasn't implying it was wrong in any way, just never heard it stated that way. LOL
Here we seem to agree that zero space-time curvature means no acceleration, as per our incongruent definitions of gravity. Only you use the term "gravitational field" is zero whereas I used "gravity" and agree here that zero space-time curvature equals a zero gravitational field. So I can't say you are wrong yet you chose to use my definition of gravity here. So you must have taken issue with what I said purely on the presumption that I mean gravity in the wrong way rather than anything explicitly wrong with my actual statement.
It still leaves the original statement that started this debate to be answered:
pmb_phy said:
This is true if one is approximating the gravitational field near the Earth's surface as a uniform gravitational field. Such a field has zero spacetime curvature. Space is also flat in such a field.
First off hollow spheres are not fictitious objects, that's a red herring. Now you are trying to make a distinction between a hollow sphere and the center of the Earth as if I didn't strictly specify both time I said it, or that it makes any difference whatsoever.
my_wan said:
Illustration:
If the Earth was hollow like a large beach ball then anywhere inside this hollow the gravity would be zero, i.e., the space-time is flat, yet the gravitational time dilation would be the same as on the surface with gravity.
Yet your claim of fictitious doesn't even work because even if the Earth has nothing more than a hollow spot just big enough for you to fit there is still no gravitational forces, tidal or otherwise. In fact the only forces on the mass at the center right now is the pressure from the matter not at the center, no gravitational forces of any kind.
Your original statement that MeJennifer took exception to remains to be explained also, the only argument she made that I concur with:
pmb_phy said:
The trajectory of a particle in the Earth's gravitational field consists of two parts (1) gravitational acceleration and (2) spatial curvature. The space-time associated with the Earth's gravitational field is curved.
You can have gravitational time dilation without curvature but not acceleration. Spatial curvature and acceleration are facets of the same thing.
  • #41
pardon the expresson, but... :yuck:
If the options are SR and GR, I'm pretty sure that gravity falls under GR.
Regards,
Bill
  • #42
So where was I asked that question before?
Regards,
Bill
Gravity is the phenomena, GR is the theory. There is a big difference and as I pointed out in the post even pmb_phy used that distinction in his own response when he said;
Yet he's been arguing with me for using that same definition, essentially the exact same statement, and claiming I'm somehow conflating gravity and curvature. So the tongue in cheek means little to me.
It's also essentially flat at the center of the Earth as the Earth really is right now.
  • #43
Hi wan and Jennifer, Pete is exactly correct here.
Spacetime curvature is an intrinsic physical characteristic of the spacetime that cannot be transformed away. For example, in a curved spacetime "straight" (i.e. geodesic) worldlines that are initially parallel will not remain parallel. This is an observable fact that can be determined in any reference frame. For example, consider a rock dropped above the north pole simultaneously with a rock dropped above the south pole. They are on geodesics that begin parallel and wind up intersecting. This is a frame-independent observation due to spacetime curvature.
A uniform gravitational field has no such frame-independent curvature. In such a field particles follow parabolic paths. If you drop two rocks in a uniform gravitational field their worldlines remain parallel at each point in time and never intersect. The parabolic path itself can be transformed away by choosing a suitable reference frame. In such a frame the worldlines are seen to be straight.
Remember, one of the key points in doing GR is to take a small volume of space where spacetime can be considered locally flat. Such a volume doesn't get rid of gravity, it gets rid of curvature. In other words, you can make a volume small enough to neglect spacetime curvature on the surface of the earth, but you can never make the volume small enough that an accelerometer will read 0 rather than g.
If you are making the approximation that the field is uniform then you are making the approximation that objects follow parabolic trajectories and you are making the approximation that the spacetime is flat.
  • #44
How would you then explain the relative acceleration of a particle dropped inside a uniformly accelerating lab? There's surely no curvature inside such a lab?
-J
  • #45
Hi all,
The attached diagram represents a lab undergoing proper born rigid acceleration in a straight line relative to an inertial observer, drawn on a Minkowski diagram.
Imagine the lab to be multi storey, with observer on each floor with their own clocks. In the diagram two observers on different floors send timing light signals (the blue lines) to each other (Events A and B). They receive these signals simultaneously at events C and D because both these events lie on a line of simultaneity in the lab (The magenta lines). On receiving these signals they echo them back and the signals arrive back at there respective observers simultaneously at events E and F.
Within the accelerating lab, observers spatially separated (horizontally and vertically) observe that once their clocks are synchronised, they remain synchronised so they consider their clocks to run at the same rate. This can not be said for clocks at the top and bottom of a tower on Earth for example. This is because spacetime on Earth is curved while spacetime measured by observers in the accelerating lab is flat. The spacetime within the lab is flat because all spatially separated observers consider their spatial separation to remain constant and their clock rates to remain constant with respect to each other. Despite the apparent flatness of the spacetime they occupy, the observers in the lab observe light moving horizontally to follow a curved path, and any dropped objects to accelerate downwards. Hence you have "gravitation" in flat spacetime.
In an earlier discussion with Jennifer we mentioned that a cylindrical hypersuface can be considered flat in GR while a spherical hypersurface is curved. I made the analogy that the surface of a cylinder is curved in one spatial direction (single curvature) while the surface of a sphere is curved in two spatial directions. (Double curvature). Likewise the accelerating lab can simulate the single curvature of the cylindrical surface but it cannot simulate the double curvature of the spherical surface. Special Relativity, Minkowski diagrams and Rindler spacetime can handle the flat spacetime (single curvature) of an accelerating lab while general Relativity is required to describe motion in the spherical gravitational topology (double curvature) of a typical spherical massive body.
In the Minkowski diagram it is easy to observe that the proper acceleration measured by different observers on different floors of he accelerating lab is proportional to 1/R while the proper acceleration measured by observers in a tower on the Earth varies as 1/R^2.
This is another difference between the flat spacetime of the accelerating lab and the curved spacetime of a spherical massive body.
Free falling observers in the accelerating lab observe light rays in any direction to follow straight paths (straight null geodesics), while the non inertial observers at rest with the lab frame observe light rays to follow curved paths (curved null geodesics).
On the other hand, observers in a lab free falling towards the Earth will not observe light rays to follow exactly straight paths unless the lab is very small and then the paths will approximate straight lines. These free falling observers will not consider their spatial separation to remain constant and they will not consider their clocks to run at the same rate. This is because the curved spacetime with the lab free falling towards the Earth is not the same as the flat spacetime observed by observers freefalling within a lab that is being accelerated by a rocket.
Nearly every reference to a "null geodesic" in a google search suggest a null geodesic is a path and not a point.
Having, thought it through (and rejecting the conclusions I made in post #4 which were only true for an infinitesimal region of space) I tend to think the views and definitions expressed by Pete and Dalespam are the correct ones in this thread.
Admittedly the term "flat spacetime" is a confusing definition for the spacetime found in an accelerating lab, but that seems to be the definition most widely used in texts on the subject. I think that is to differentiate it from the curved spacetime measured in the proximity of a large gravitational body that can not be duplicated by an linearly accelerating rocket except in an infinitesimal region of the gravitational body.
Also as alluded to earlier, it seems that flat spacetime has the property ( possibly a definition?) that all observers at rest with that spacetime and maintaining constant spatial separation measure their clock rates to be the same irrespective of the fact that they may feel or measure different proper accelerations to maintain that constant spatial separation.
  • #46
Hi Kev. I think you have these two parts slightly wrong. The Born-accelerated observers on your 'floors' do not agree that their respective clock rates are the same, because their clocks get more and more out of sync during the acceleration. Think what will happen in your Rindler diagram when the acceleration is stopped - don't you think the clocks will then need to be resynchronized?
Your purple lines of "instantaneous simultaneity" is when the clocks on all floors read the same time, but they realize that the clocks get out of sync. Light signals send forward and backward during the acceleration are red-shifted and blue-shifted respectively, just like in a gravitational field. It's only the tidal effects that differ, AFAIK.
-J
  • #47
That in no way is true. Gravity is the thing that GR describes. I do not use these terms synonymously.
The gravitational acceleration is defined by the metric. Unless the metric is first defined then the affine connections can't be calculated and thus the gravitational acceleration cannot be defined. On the other hand one can state the affine connections but then the metric can be found from those connection coefficients.
Wrong. That is not true in general. Why do you believe it is?
My definition? So your saying that although this was defined by Einstein I am to get the credit for it? Gee! Thanks! :smile:
You can us the term "gravity" anyway you'd like. I thoiught this was a relativity newsgroup and as such we're talking aboiut how Einstein used these terms.
If we're not talking about Einstein's theory of relativity then I have just lost interest in this discussion. Are we or are we not talking about Einstein's theory of relativity and as such talking about how Einstein defined these terms? Even MTW define the gravitational field as requiring the non-vanishing on the affine connection, which does not require spacetime to be curved.
Um ... I never said they were!
I said that the actual Earth is not hollow and as such the curvature at the center of the Earth is not zero. However if you hollowed out a cavity centered at the center of the Earth then the gravitational field will vanish throughout that cavity leaving no gravitational field and as such no tidal gradients, hence the spacetime is zero in such a cavity. However, if the center of th hollowed out cavity is not centered at the center of the Earth then the spacetime will still be flat but, in a frame of reference which is at rest with respect to the Earth, the gravitational field will be non-vanishing, in fact it will be a uniform gravitational field. I can show you how to calculate that in the weak field limit if you'd like? Its rather simple in fact.
Excuse me? Who said that I had to fit there? There is a gravitational field inside a matter distribution regardles of whether we measure it or not. Its calculable and therefore exists. Seems to me that you're still confusing gravitational acceleration with spacetime curvature. Why do you keep doing that?
(sigh) I didn't say that the gravitational field at the center of is non-zero. It is zero. But the fact that its zero does not mean that the curvature is zero. The gravitational field inside the Earth, which is not hollow, is not uniform and therefore the tidal tensor is non-zero. The tidal force tensor can be non-zero and yet leave a zero gravitational field.
Correct. I never said otherwise.
I see that I have no reason to continue responding to your comments. I will therefore be unable to respond unless you explain why you keep saying this. So when you explain or prove that Spatial curvature and acceleration are facets of the same thing. then I see I've stated all the facts and you either accept them, reject them, or have me prove them to you, or let me show you the GR material that explains all of this. Which will it be?
Pete
  • #48
If it is easy enough for you to do I would appreciate that. I assume that the weak field limit is some sort of approximation to GR that is appropriate for "typical" spacetimes instead of black holes.
  • #49
I love to hear those words. :shy:
Yes! Quite right!
The geodesics do not start out parallel in this case. In fact its not even very meaningful to compare geodesics which have a finite separation because the parallelness will depend on how a tangent vector is parallel transported in order for them to be compared. A better example is to compare two objects which are very close to each other when they are let go and left to free-fall. The geodesics will start off parallell and then they will diverge.
I recommend caution be used in such visualizations. Consider the fact that two particles at rest in an inertial frame of reference S will remain at rest in that frame. Consider now a frame S' which has a uniform acceleration with respect to S and directed along a line which is parallel to the separation 3-vector of the two particles. In Newtonian mechanics the distance is invariant, all clocks tick at the same rate and thus the separation remains the same. However in relativity the distance changes with speed and clocks run at different rates. This means the distance between the two particles contracts. This is a result of clocks running at different rates in thefield and thus acclerations of the two particles is different. The particle higher up in the field is larger than that of the particle lower in the field (since clocks higher up run slower when measured locally). However spacetime deviation is an invariant quantity since it is calculated in terms of invariant properties of spacetime.
All that means is that the grqavitational field can be transformed away and one can chose the "size" of the volume to be so small that your instruments cannot measure the tidal accelerations. Note that this is more of a limitation of the intruments than the impossibility of detecting the spacetime curvature. Remeber that curvature is a local property, not a global one. Curvature is calculated by using local points in a manifold and taking the limit as the volume approches zero.
Pete
  • #50
I thought that parallel was synonymous with "same 4-velocity". So since they both initially start out at rest their geodesics would start out parallel. Am I missing some subtle point here?
  • #51
I analysed this in some detail in this old thread (with yet more diagrams) https://www.physicsforums.com/showthread.php?t=216113 and concluded that two clocks would be out of sync after born rigid accleration when they reach same final constant velocity.
In this thread I am considering the slightly different situation where the two clocks maintain constant born rigid acceleration indefinitely. I would be interested in your opinion of my conclusion in that old thread ;)
-J
The light signals sent forward and backward should behave as any other light signal in a time space diagram moving at 45 degrees as I have shown on this diagram (the blue lines). If the signals are sent at 0 seconds by the upper and and lower observers and both arrive at 1 seconds as shown by their respective clock and then return at 2 seconds as shown by their respective clocks then presumably the upper and lower clocks must remain in sync (while constant proper born rigid acceleration is maintained) as far as I can tell.
  • #52
To be called "the same 4-velocity" one must be able to compare the 4-velocities when the particles are located at different points in spacetime. However since there is no way to compare 4-vectors which are located at different points in spacetime the 4-velocities cannot be said to be "the same." This is easily vizualied by using the two-dimensional surface of a sphere such as the Earth. Start with a tangent vector located at the equator which points eastward. First parallel transport this vector to the North Pole by moving along the a great circle which passes through the poles and through the initial position of the tangent vector. Then picture what would happen if you first parallel transported one quarter the way around the sphere and then parallel transport along the great circle which passes through the poles as well as through this new location. You will see that the end results result in tangent vectors which have a 45 degree angle between them.
Pete
  • #53
Yes, that makes sense. I guess to talk about parallel world lines converging or diverging you have to start with two lines close enough together that the spacetime between them at the beginning can be considered flat in order to avoid such problems. Then you have to move them far enough through the curved spacetime that you can see them converge or diverge since it won't be apparent right away.
  • #54
As far as I checked, I agree with your conclusions in that thread.
Yep, that's in the inertial reference frame. In an accelerating frame, light does not move isotropically like that, as I'm sure you know.
I don't think so. Your 'old thread' has shown that when the acceleration stops and both ends of the lab are moving at the same velocity, their clocks will be out of sync. Since the two ends are not experiencing the same proper acceleration, they will reach that 'same velocity' at different times, not only in the reference frame, but also in their own frames. To me that makes their clocks never synchronized during the acceleration (after the start, that is). But I may be wrong...:frown:
-J
  • #55
Flat Tilted Plane and a Uniform Gravitaional Field
my_wan = If I've got this right then I imagine that you're visualizing gravity using an embedding diagram. The one for the Earth is like a flat space with a bowling ball placed on it and then depresses into the surface and thus "curving" it. I would imagine that you're thinking of the diagram in terms of a little ball rolling on the surface. Where the surface is level there is no acceleration and where it dips down due to the bowling ball then it accelerates "down" the surface. The meaning of an embedding diagram is to represent the increases in distances as a function of the decrease in the radial coordinate r. If one were to use this vizulization for a uniform gravitational field then you should imagine a tilted plane. In the rest frame of the observer in free-fall all he measures is a flat level plane. Notice that any observer in free-fall can transform the gravitational field away by moving to a free-fall frame. This is to be vizualized by picturing the location a little ball is from the view where the surface normal is directed upward. In a small enough region the the surface looks flat and since the surface is not titled then there is no gravitational field present at that location from that observers point of view.
  • #56
How could an observer possibly measure a flat plane? If the Riemann curvature tensor vanishes it is flat, and there is nothing to measure. So are you saying there is some kind of force still active that causes gravitation?
Again Peter, what you say about gravitation in flat spacetime does not make any sense to me, I gladly attribute it to my lack of understanding of the matter.
  • #57
Is the spacetime background experienced by an observer in a rocket experiencing constant proper acceleration flat or curved?
  • #58
There is a difference between something being equivalent and identical.
An accelerating rocket is not identical to gravitation.
  • #59
I agree, the diagram in post #45 is the point of view of an inertial observer in flat spacetime and to him light follows straight lines in 3 space and in 4D spacetime, as shown in that diagram. Sure, in the reference frame of the observers in the accelerating lab light follows a curved path in 3 space. However, the events are the same from any observers point of view. If A sends a signals at one second intervals as measured by A's clock and they arrive at B at one second intervals as measured by B's clocks then those two clocks are syncronised in the reference frame of A and B. Since the readings are the proper times of those observers then any observer would have to agree that is what they measure.
-J
I disagree. To the inertial observer in the diagram the observers A and B have different velocities at any given moment. In the reference frame of A and B they consider themselves to have the same velocity at any given instant (which is why they consider their spatial separation to be constant in their reference frame. The line of simultaenity is not only the the line that connects events that simultaneous in the reference frame of the accelerating observers, it is also the line that connects equal velocity as measured by the inertial observer (although of course he does not consider A and B to have equal velocity simultaneously). In the reference frame of the accelerating observers they can consider their velocity to be zero while experiencing different proper accelerations. This is analogous to two observers that are stationary with respect to each but at different altitudes in a tower on the Earth for example.
A subtle difference is that the observers in the Earth tower measure their clock rates to be different while the observers in the accelerating lab do not. This is a tidal effect of the curved spacetime of the Earth that is not present in the lab experiencing artificial constant proper acceleration.
  • #60
You have avoided the question. Is the spacetime in an accelerating rocket flat or curved?
I did not ask what it is equivalent to.
  • #61
This subject has been discussed in the relativity literature to quite an extend. You can read this in Exploring Black Holes by Taylor and Wheeler (It was yours truly who came up with the title in fact! :smile: That part is online in www.eftaylor.com. See the download section and look through the available chapters that are there for you to download.
The idea of locally flat is similar to people standing on Earth. Suppose the Earth was a perfect sphere with a perfectly smooth surface. Then people standing on the Earth who are examining only the region in the nearby space around him (surrounded by, say, a small loop ~ 1 mile in diameter) might conclude (if his instruments weren't sensitive enough) that he was standing on a plane. When applied to general relativity it becomes the equivalence principle. Indeed if one were to parallel transport a vector around such a loop then the the difference between the initial vector and the final vector would decrease with the size of the loop. For the person standing on a smooth sphere, as mentioned above, he wouldn't have enough accuracy in his instruments to detect the curvature. However, whether the curvature is detected or not will depend on the accuracy of the instruments he is using. Thus "local" means that your instruments are not accurate enough to detect the curvature. Ask yourself this; if you are on a lake in a boat and the water is so calm that the surface is as smooth as glass then how would you, with no instruments, detect the curvature? Here the only instruments you are using will be your own eyes.
Then answer this form me; Why do you associate gravity with spacetime curvature? As far as your lack of understanding I recommend that you read Einstein's relativity book in the subject. Its called Relativity: Special and General, by Albert Einstein. It covers almost everything we've discussed. However, while Einstein does explain the relative existence of a gravitational field he does not get into gravitational fields which have tidal gradients in it (i.e. spacetime curvature). Also ask yourself what Einstein meant when he stated in his 1916 review paper on GR that one can "produce" a gravitational field by merely changing coordinates.
I do have one last question for you - Do you have a solid understanding of the differences in the definition and meaning of tidal forces and the gravitational field, at least within Newtonian mechanics?
Thanks
Pete
  • #62
In this case it means identical. I.e. there is no possible way to determine whether one is at rest in a uniform gravitational field or in an accelerating frame of refernce. The metrics, which actually defines the field, are identical. Consider this; what experiment could you do within the rocket cabin (which is at rest with respect to the accelerating rocket) to determine you were accelerating as opposed to being at rest in a uniform gravitational field? Looking out side the cabin won't help you because there might just be a uniform field whose source you can't see. The firing of the engines won't help you since its just as possible that the engines are merely making sure that you don't fall but remain at rest in the field.
A good example of gravity in flat spacetime is a vacuum domain wall. This is an object which finds use in early cosmology. I think that there is a Scientific American article on them as well as cosmic strings. Such a wall generates repulsive gravitational field (i.e. antigravity). Objects in free-fall near the wall will be gravitationally accelerated away from the wall. The reason is due to there being tension in such a wall. The tension is in two dimensions which gives two terms for the pressure in the wall. There is one term for the mass density. Since each is a source of gravity, when they are added together the resulting active gravitational mass is a negative value, hence antigravity. Antigravity like this also explains the accelerating expansion of the universe as well as inflation theory. Oops! I see I went off on a wee bit of a tangent, huh?
Pete
  • #63
Pete
Hi pete,
Is there a requirement that the cabin is infinitesimal?
If not, then you could observe that acceleration at different "heights" within the cabin is proportional to 1/R while the acceleration due to any normal gravitational body is proportional to 1/(R^2). As I mentioned in an earlier post, the gravitational attenuation perpendicular to an infinitely long cylindrical body is also proportional to 1/R. To make the two analogies completely equivalent someone would have to show that gravitational time dilation with respect to "height" within the rocket is the same as for the cylindrical massive body. It is interesting to note that the observers in the accelerating rocket even see an apparent event horizon below which they can never receive light signals, as long as they maintain constant proper acceleration.
  • #64
kev said:
Hi pete,
Any cabin will have a finite size so I see no way to create an experiment that will measure the size of a cabin to be infinitesimal. So no, there is no such requirement. "Local" refers to the restriction of size and space of a region of spacetime. That means that not only must the volume of space be limited to a certain size but so too does the time it takes to run an experiment, i.e. this is a limitation in both space and time.
If not, then you could observer that acceleration at different "heights" within the cabin is proportional to 1/R while the acceleration due to any normal gravitational body is proportional to 1/(R^2).
Einstein never said that a curved spacetime is equivalent to a uniformly accelerating frame of reference. Einstein was speaking about a uniform gravitational field. Seems to me you have a particular field in mind, e.g. that outside a spherically symetric body. It is not limited to that. Consider what I said about a cavity inside a sphere with uniform mass density whose center is not the center of the Earth. Inside the cavity the strength of the field has the same value everywhere inside the cavity. Hence it does not vary according to 1/R. By the way, the gravitational field varies as 1/R2. It is the gravitational potential that varies as 1/R. This, of course, refers to the weak field limit. When using the strong field exact values it becomes hopelessly complex and not very interesting.
Ah! I see where that 1/R comes from now. Thanks for clarifying that for me.
As far as the rest, please see my comments above regarding the equivalence principle. Note that there are two different forms, one called the weak form while the other is called the strong form.
Pete
  • #65
Pete
The point I am getting at is that the observers inside the cabin should consider that the measurements they make within the cabin could be exactly "duplcated" by some gravitational body even if that gravitational body is only hypothetical. If there is no such hypothetical body that can duplicate the apparent field within the cabin, then they can clearly declare that they are artiificially accelerating (rocket power) and not in a gravitational field by measuring those observations that cannot be exactly duplicated by any (even hypothetical) gravitational body. That is why it is pleasing to me that an infinite massive cylinder can duplicate the 1/R attenuation of born rigid acceleration. With a bit a luck the cylindrical body can duplicate all other measurements inside the accelerating rocket. If they can can not be duplicated then all we have to do is to point to the differences and use them to answer the question "What possible measurements can you make inside the cabin that can tell you, you are not in a gravitational field?" Our hypothetical gravitational body must be free of tidal effects because they are not measured within the cabin, with the possible exception of red shift of light signals sent up and down the cabin.
  • #66
Hi Kev. Isn't proper acceleration that changes over the height of the Born-rigid accelerated lab equivalent to a tidal effect?
On clock rates, check Prof. http://www.csupomona.edu/~ajm/professional/talks/relacc.ppt" , where he comments on born rigid acceleration:
  • Since the vertex distances are different, so are the accelerations
  • The "front" object, B, has a smaller proper acceleration than the "rear" object, A
  • A and B agree at all times on matters of simultaneity
  • A and B agree at all times on their common velocity
  • A and B agree that their proper separation is constant
  • A and B agree that B’s clock runs faster in direct proportion to their respective vertex distances.
Perhaps not a refereed publication, but rigorously correct, AFAIK.
  • #67
Tidal effects are not required in a gravitational field. Redshifted light signals also do not imply the presence of tidal forces/spacetime curvature.
Why do you associate tidal forces with a gravitational field? I gave you a nice example of a body which generates a field with no tidal forces in it. Tidal forces and gravitational forces (or tidal gradients and gravitational acceleration) are defined quite differently. The former is defined through the tidal force tensor and the second defined through an acceleration 3-vector.
Pete
  • #68
I have a problem with item 4 in the following list:
The "front" object, B, has a smaller proper acceleration than the "rear" object, A.
1) A and B agree at all times on matters of simultaneity
2) A and B agree at all times on their common velocity
3) A and B agree that their proper separation is constant
4) A and B agree that B’s clock runs faster in direct proportion to their respective vertex distances.
This quote from Einstein's "ON THE ELECTRODYNAMICS
OF MOVING BODIES" https://www.fourmilab.ch/etexts/einstein/specrel/www/#SECTION11 seems to disagree.
"Let a ray of light start at the ``A time'' Ta from A towards B, let it at the ``B time'' Tb be reflected at B in the direction of A, and arrive again at A at the ``A time'' Ta'.
In accordance with definition the two clocks synchronize if
Tb - Ta = Ta' - Tb
We assume that this definition of synchronism is free from contradictions, and possible for any number of points..."
The above relation holds in the accelerating rocket frame. A signal leaving A at Ta = 1 second arrives at B at time Tb = 2 seconds and returns to A at time Ta' = 3 seconds, then Tb - Ta = Ta' - Tb = 2-1 = 3-2 = 1 showing the clocks are synchronised according to Einstein's definition. We can further check that a signal leaving A at Ta = 3 seconds arrives at B at time Tb = 4 seconds and returns to A at time Ta' = 5 seconds, then Tb - Ta = Ta' - Tb = 4-3 = 5-4 =1.
Condition 1 in the list states that A and B agree at all times on matters of simultaneity. This suggests that they agree their clocks advance simultaneously.
We can also add a third inertial observer C and note the following:
1) A and B agree at all times on matters of simultaneity.
1) If A and B agree that two events are simultaneous then C does not agree those events are simultaneous.
2) A and B agree at all times on their common velocity.
2) C does not agree that their velocities are equal at any given instant.
3) A and B agree that their separation is constant.
3) C does not agree that the separation of A and B is constant.
4) C agreee that B’s clock runs faster in direct proportion to their respective vertex distances.
Odd that C disagrees with all measurements that A and B make except for item (4). It seams the measurements of A and B should be swapped with those of C for item 4 to make a consistent list of observations.
On page 13 of the presentation you linked to, the author does agree that flashing clocks at positions A and B will be flashing simultaneously. That contradicts item 4 of the list.
  • #69
Hi kev, I don't quite follow your logic with the extended list that you supplied and how it contradicts Mallinckrodt. Can you explain a little more?
Slide 13 of Mallinckrodt seems to hold that "flashing synchronously is not the same as flashing at a definite time interval because the clocks run at different rates". So how does that contradict the different clock rates?
I must confess that Rindler frames are quite slippery on some of these concepts and it is always possible that even the professor did slip up! I'll give it another thought in the next few days. Maybe the moderators can help us out?
-J
  • #70
Hi again kev. I understood what Mallinckrodt wrote as: the rod flashes at the same clock times all along the rod, but for rear- and front end observers the intervals between the flashes are different. It should be like that if the proper length remains the same for those observers, yet they experience different proper accelerations. The front clock records less acceleration because it runs faster than the rear clock. How else?
-J
