I Curved space
  • Thread starter Kairos
as calculations are technically difficult in curved spaces, I wonder if we would obtain the same results by adding one additional (virtual) dimension in order to embed the space in a higher order Euclidean volume, just to facilitate the treatments? (for example embed a 3D hypersphere in a 4D euclidean space)
thank you in advance
fresh_42
Mentor
Insights Author
2018 Award
10,716
7,324
Does this become easier, because it is on a flat plane?
245390
You can calculate with spacetime as if it was flat, at least either locally or on a global scale. Since the embedding doesn't change the geometric shape, there will be no gain in doing so.
Orodruin
Staff Emeritus
Insights Author
2018 Award
15,598
5,622
The entire point of differential geometry is not to have to rely on an embedding space because it generally complicates things.
A.T.
1,423
Embedding curved spaces in flat higher dimensionless spaces is usually done to help with visualization. But for calculations, you usually want as few variables and as little redundancy as possible.
48
OK thanks
I supposed that the simplicity of euclidean rules would compensate the additional spatial variable. bad idea !
pervect
Staff Emeritus
Insights Author
9,441
772
Kip Thorne has written some popularizations in "Interstellar" about the embedding approach. But I haven't seen any non-popularized treatment of General Relativity using embeddings.
So, if you're attracted to the approach and you don't mind reading popularizations (which are usually limited, even when well written), you could try "Interstellar", but for a serious, textbook study you'd want to learn the differential geometry approach.
There's at least one other approach to GR, that uses funky fields that warp rulers and clocks in a flat space-time. This is akin to Einstein's discussion of rulers on a heated marble slab as a model for non_euclidean spatial geometries. This approach has been outlined by Straumann in "Reflections on Gravity" <<link>>. I rather suspect that Straumann's approach has some limits in regards to modelling some of the topological features that the full theory handles, and that this matters in such topics as understanding black holes, but the author doesn't discusss these limitations, unfortunately.
Want to reply to this thread?
"Curved space" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
