Custodial Symmetry
I have never really understood the approximate 'Custodial symmetry' in the Standard Model. I've seen it being described in many texts, but I can't seem to be able to put my finger on it.
Would somebody please write down the transformation law for the Higgs fields under a 'custodial SU(2) transformation?' It would really help if I got that!
blechman
custodial isospin in the electroweak interaction is defined many ways, depending on what you want to do with it (they're all effectively the same up to field redefinitions). but a good starting place is the following: posit a GLOBAL symmetry:
SU(2)_L x SU(2)_R
Now gauge the SU(2)_L and identify it with the standard model gauge group, but only gauge the U(1)_R subgroup of the SU(2)_R part, and identify that with hypercharge. The special treatment of the U(1)_R explicitly breaks the R part of the symmetry, but if we turn off that special treatment (let g'=0) then the R symmetry is restored (up to the Yukawa couplings). So one can do a spurion analysis with g' and the fermion yukawa couplings.
To the extent that g' is small, this describes the standard model. The SU(2)_R is the "custodial isospin" symmetry (sometimes it is the SU(2)_D, but I usually use the former in my research; as I said, they're the same up to field redefinitions).
If you want to make the custodial isospin symmetry manifest, you can let the Higgs transform as a bifundamental of the L-R symmetry:
[tex]H\rightarrow LHR^\dagger[/tex]
This symmetry is realized in the standard model if you group the right-handed fermions into doublets of the SU(2)_R symmetry and let g'=0. If you have g' nonzero, this symmetry is only realized if R=1.
Custodial isospin symmetry is very important for EW precision measurements - it ensures that the W-Z mass ratio (called [itex]\rho[/itex]) cannot get too large, for example. Its corrections must be proportional to g' and yukawas, especially the top quark yukawa coupling. This is a well known result.
The extent to which custodial isospin symmetry is broken is a very powerful test for physics beyond the standard model.
Hope that helps.
Related Threads for: Custodial Symmetry
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
