Are Relatively Prime Elements Generators of Cyclic Groups?
In summary, an element k is a generator of Zn if and only if k and n are relatively prime. This can be proven by showing that if k and n are relatively prime, then k generates Zn, and if k generates Zn, then k and n are relatively coprime. The first part can be proven by showing that the order of k is n, and the second part can be proven by contradiction.
halvizo1031
78
Zn={0,1,...,n-1}. show that an element k is a generator of Zn if and only if k and n are relatively prime.
it makes sense but I am having a hard time proving this.
So you need to do two parts:
1) If k and n are relatively prime, k generates Zn. What do you need to prove to show this?
2) If k generates Zn, then k and n are relatively coprime. This part is probably easier done by proof by contradiction
well i understand i need to show both ways but to be honest, this is all i have:
==>if m is in {0,1,...,n-1} is a generator, its order is n. Also, its order must be n/(m,n). Thus, n=n/(m,n) which implies (m,n)=1.
<== if (m,n)=1 then the order of m is n/(m,n)=n/1=n.
therefore, m is a generator of Zn.
1. What is a cyclic group?
A cyclic group is a mathematical group that can be generated by a single element, also known as a generator. This means that all elements in the group can be obtained by repeatedly applying the group operation to the generator.
2. What are the properties of a cyclic group?
The main properties of a cyclic group include closure, associativity, identity element, inverse element, and commutativity. These properties ensure that the group operation is well-defined and that the group behaves in a predictable manner.
3. How do you determine the order of a cyclic group?
The order of a cyclic group is equal to the number of elements in the group. This can be determined by finding the number of times the generator needs to be multiplied by itself to obtain the identity element.
4. Can a cyclic group have more than one generator?
Yes, a cyclic group can have multiple generators. However, all generators will generate the same group as long as they have the same order as the group itself.
5. What is the relationship between cyclic groups and modular arithmetic?
Cyclic groups have a close relationship with modular arithmetic. In fact, modular arithmetic can be thought of as a specific type of cyclic group. The group operation in modular arithmetic is addition, and the modulus determines the order of the group.
