Understanding why cyclic rule works
In summary, the cyclic rule in partial derivatives is a result of the chain rule applied to the partial derivatives of a multivariable function. When taking the partial derivative of one variable with respect to another, the other variables are held constant. The cyclic rule states that the product of the three partial derivatives with respect to each variable in a cycle will always equal -1. This can be derived from the equation for the total differential, and is a result of the chain rule. The apparent cancellation of the variables is only possible because they are kept constant in each partial derivative.
gloryofgreece
I don't quite understand why cyclic rule works (from Pchem)
(del x/ del y)_z = part of x with respect to y, hold z constant
I don't know why is it negative 1?
del x/ del y)_z * del y/ del z)_x * del z/ del x)_y = -1
Mathematics news on Phys.org
You could derive it. Not sure if there is any other way to imagine it
[tex]\mathrm{d}z=\left.\frac{\partial z}{\partial x}\right)_y\mathrm{d}x+\left.\frac{\partial z}{\partial y}\right)_x\mathrm{d}y[/tex]
Now to get [itex]\left.\frac{\partial x}{\partial y}\right)_z[/itex] from the above equation just find the fraction [itex]\frac{\mathrm{d}x}{\mathrm{d}y}[/itex] under the condition that [itex]\mathrm{d}z=0[/itex], i.e.
[tex]\left.\frac{\partial x}{\partial y}\right)_z=\left.\frac{\mathrm{d} x}{\mathrm{d} y}\right)_{\mathrm{d}z=0}=-\frac{\left.\partial z/\partial y\right)_x}{\left.\partial z/\partial x\right)_y}[/tex]
The minus sign comes from rearranging the first equation.
Also
[tex]\left.\frac{\partial z}{\partial y}\right)_x=\frac{1}{\left.\frac{\partial y}{\partial z}\right)_x}[/tex]
or
[tex]\left.\frac{\partial z}{\partial y}\right)_x\left.\frac{\partial y}{\partial z}\right)_x=1[/tex]
The apparent cancellation is only possible since both derivatives have the same variables kept constant!
1. What is the cyclic rule?
The cyclic rule, also known as the rule of cyclic permutation, is a mathematical principle that states that the order in which a series of operations are performed does not affect the final result.
2. Why is it important to understand why the cyclic rule works?
Understanding the cyclic rule can help scientists and mathematicians make sense of complex equations and calculations, as well as verify the validity of their results.
3. How does the cyclic rule apply to different fields of science?
The cyclic rule is applicable in various fields of science, such as physics, chemistry, and biology. It is particularly useful in analyzing complex systems and processes, as well as in understanding the relationships between different variables.
4. Can you provide an example of the cyclic rule in action?
Sure, one example is the commutative property of addition, which states that changing the order of adding numbers does not change the result. For example, 2 + 3 + 4 is equal to 4 + 3 + 2.
5. Are there any limitations to the cyclic rule?
While the cyclic rule is a powerful mathematical principle, it may not apply in certain situations, such as when dealing with non-commutative operations or when there are dependencies between different variables.
  • General Math
  • Linear and Abstract Algebra
  • General Math
  • General Math
