Cyclic Subgroup of GL(2,q)
Main Question or Discussion Point
I'm trying to prove that [tex]GL(2,p^n)[/tex] has a cyclic subgroup of order [tex]p^{2n} - 1[/tex]. This should be generated by
[tex]\left( \begin{array}{cc}
0 & 1 \\
-\lambda & -\mu \end{array} \right)[/tex]
where [tex]X^2 + \mu X + \lambda[/tex] is a polynomial over [tex]F_{p^n}[/tex] such that one of its roots has multiplicative order [tex]q^{2n} - 1[/tex] in its splitting field.
Now since the above matrix satisfies its own characteristic polynomial, [tex]X^2 + \mu X + \lambda[/tex], I believe this somehow implies that it has order [tex]q^{2n} - 1[/tex].
The problem is that my Galois Theory isn't up to scratch so I don't have a clue how to justify this.
Here are some of my thoughts: I think I'm right in saying that any splitting field of [tex]F_{p^n}[/tex] is of the form [tex]F_{p^{mn}}[/tex]. For a quadratic is it always [tex]F_{p^{2n}}[/tex]? A primitive element of [tex]F_{p^{2n}}[/tex] would clearly have the desired order.
Answers and Replies
The q's should be p's. Corrected version:
0 & 1 \\
where [tex]X^2 + \mu X + \lambda[/tex] is a polynomial over [tex]F_{p^n}[/tex] such that one of its roots has multiplicative order [tex]p^{2n} - 1[/tex] in its splitting field.
Now since the above matrix satisfies its own characteristic polynomial, [tex]X^2 + \mu X + \lambda[/tex], I believe this somehow implies that it has order [tex]p^{2n} - 1[/tex].
206
It seems like you're going about the problem correctly except that obviously the splitting field won't be as described if the quadratic is reducible. Other than that, unless I'm forgetting something (which would hardly be surprising), what you're saying is completely true.
Hurkyl
Staff Emeritus
Try thinking linear algebra -- if:
. F is a field
. a is algebraic over F
. the minimal polynomial of a is quadratic
Then you know that F(a) is a vector space over F, with basis {1, a}, right? So if you know the number of elements of F, then how many does F(a) have?
Another useful linear algebra viewpoint -- one common way to study an operator is by looking at its eigenvalues. What are the eigenvalues of X?
Finally, a more algebraic viewpoint: you can prove that F[X] (the subalgebra of two by two matrices generated by X) is actually isomorphic to F(a).
OK thanks guys. So F(a) has cardinality the square of F in Hurkyl's question, hence a splitting field of an (irreducible) quadratic over [tex]F_{p^n}[/tex] is always [tex]F_{p^{2n}}[/tex]. So we just need the polynomial [tex]X^2 + \mu X + \lambda[/tex] to have a root which is a primitive element of [tex]F_{p^{2n}}[/tex].
I guess eigenvalues are the key to showing that [tex]\left( \begin{array}{cc}
0 & 1 \\
-\lambda & -\mu \end{array} \right)[/tex] then must have order [tex]p^{2n}-1[/tex].
Indeed diagonalization over [tex]F_{p^{2n}}[/tex] gives [tex]\left( \begin{array}{cc}
0 & 1 \\
-\lambda & -\mu \end{array} \right) = P^{-1}\left( \begin{array}{cc}
r_1 & 0 \\
0 & r_2 \end{array} \right)P[/tex] where [tex] r_1, r_2 [/tex] are the roots of [tex]X^2 + \mu X + \lambda[/tex] in [tex]F_{p^{2n}}[/tex]. It immediately follows that our matrix has exact order [tex]p^{2n}-1[/tex].
Is there a canonical form for such a polynomial? I.e. can we write [tex]\mu = \mu(w), \lambda = \lambda(w)[/tex] where w is a primitive element of the field. I suspect this is probably asking a bit too much though. Is there at least a method of generating examples of these polynomials?
Hurkyl
Staff Emeritus
Every element w of an algebraic extension of F has a minimal polynomial -- the unique, monic, irreducible polynomial f that has w as a root. If you know w, it's fairly straightforward to compute -- in this case, just compare w^2 to 1 and w. If you know w's conjugates, it's even easier, since the roots of f are the conjugates of w.
Related Threads for: Cyclic Subgroup of GL(2,q)
  • Last Post
  • Last Post
  • Last Post
  • Last Post
