Cyclotron Radius of Proton: .625m
In summary, the conversation discusses the calculation of the cyclotron radius of a proton moving at 3.0*10^5 m/s in a perpendicular direction to a 5*10^-6T magnetic field. After plugging in the appropriate values, the calculated result is 625.5m. However, there is a discrepancy with the answer given (.625m) and it is suggested that the original magnetic field value may have been intended to be 5*10^-3T instead. The expert confirms that the answer calculated is correct.
Noreturn
49
The cyclotron radius of a proton moving at 3.0*10^5 m/s perpendicular to a 5*10^-6T magnetic filed is:
r=mv/qB
So plug and chug:
r= (1.6*10^-27)(3*10^5)/(1.602*10^19)(5*10^-6)
r=625.5m
However they have it down as .625m. Where do I get the sig figs wrong at?
Check the input numbers. The magnetic field looks awfully small for a cyclotron magnet and is close to the Earth's magnetic field.
I just checked the problem again and looks like I still did it right. Is it maybe just possible they messed up, or is the answer indeed .625?
Your answer is right.
The extremely low magnetic field (1/10 the magnetic field of Earth) suggests that they originally wanted to ask about 5*10-3 T and then changed it without changing the answer.
1. What is a cyclotron radius?
A cyclotron radius is the distance from the center of a cyclotron to the orbit of a charged particle.
2. How is the cyclotron radius of a proton calculated?
The cyclotron radius of a proton can be calculated using the formula r = mv/qB, where m is the mass of the proton, v is its velocity, q is its charge, and B is the strength of the magnetic field.
3. Why is the cyclotron radius of a proton important?
The cyclotron radius of a proton is important because it helps scientists understand the behavior of charged particles in a magnetic field. It is also used in particle accelerators to control the path of particles.
4. How does the cyclotron radius of a proton compare to other particles?
The cyclotron radius of a proton is smaller than that of heavier particles with the same charge and velocity. This is because the mass of the particle is inversely proportional to its radius in a magnetic field.
5. Can the cyclotron radius of a proton be changed?
Yes, the cyclotron radius of a proton can be changed by altering its velocity, charge, or the strength of the magnetic field it is moving through.
11K
