• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Cylinder lying on conveyor belt
haruspex
Insights Author
2018 Award
31,682
4,677
It's not much different from what you did. The acceleration of the belt is ##\frac{dV}{dt}##. In the non-inertial frame it manifests itself as a fictitious force ##ma## acting on the CM in the opposite direction as the acceleration of the belt. The torque equation about the point of contact on the belt gives ##MaR=(Mk^2+MR^2)\alpha## (note the use of he parallel axis theorem). Let ##a'_{cm}## be the acceleration of the CM in the non-inertial frame. Then ##a'_{cm}=\alpha/R##. Put this back in the torque equation, cancel the masses and get $$a'_{cm}=\frac{R^2}{k^2+R^2}a=\frac{R^2}{k^2+R^2}\left(-\frac{dV}{dt}\right).$$ The negative sign is introduced because ##a'_{cm}## and ##\frac{dV}{dt}## are in opposite directions. In the inertial frame, the acceleration of the CM is $$a_{cm}=a+a'_{cm}=\frac{dV}{dt}-\frac{R^2}{k^2+R^2}\frac{dV}{dt} =\frac{k^2}{k^2+R^2}\frac{dV}{dt} $$The velocity of the CM is$$v_{cm}(t)=\int a_{cm}dt=\frac{k^2}{k^2+R^2}\int \frac{dV}{dt}dt=\frac{k^2}{k^2+R^2}V(t).$$I am not convinced that this is a better way to approach the problem however.
Reading that made me realise that in non-inertial frames it is valid to deal with fictitious changes in momentum. If the frame has acceleration a=a(t) over an interval then conservation of momentum works by adding the "fictitious" term mΔv=m∫a.dt.
Something similar may be possible for angular momentum, and if such a rule were taken as standard you could avoid the integration step above.
276
haruspex
Insights Author
2018 Award
31,682
4,677
Aren't you assuming constant acceleration with this statement?
No, that is a pefectly general equation.
kuruman
Insights Author
1,808
Yes, having to do the integral is exactly why I am not convinced that my method is a better way to approach the problem. It has the advantage that it is based on a "snapshot" FBD and does not require justifying conservation of momentum over an interval Δt but, overall, I think it is lengthier.
Want to reply to this thread?
"Cylinder lying on conveyor belt" You must log in or register to reply here.
Related Threads for: Cylinder lying on conveyor belt
  • Posted
  • Posted
  • Posted
9K
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
