ehf
- 13
A cylinder shape object with a movable piston is 1.5 times of its own weight. The mass of object is figure. The initial buoyant force of the object is the waterVt.41 R Pititon iri, cylinder is Vi. and P1. Ignore the net volume of the tinder aP Before floating in the water container as shown in the Ina, and the volume and pressure of air inside Piston 1 cylinder material. The pressure at the top of water After container is set to be 0. Assume the temperature is (1)SP is applied from an external syringe. (2) and (3) show shapes of the cylinder before and after applying so P. constant. (a) Find out the required ratio of length /2/11 to make the object start to sink. [2 points] (b) In a case that we ignore the pressure due to water depth, find the minimum pressure aP to be applied to the water in order to make the object sink. [4 points] (c) In a case that we consider the pressure due to water depth, find the minimum pressure a p to be applied to the water in order to make the object sink. [4 points]
http://i.imgur.com/iVok98y.jpg
Well I am sorry but i have an exam coming up so what i can do is a simple OCR. if you click the imgur link it is perfectly visible.
P=P0+ρgh
F=mg=ρgV
1 and 2 is about it but i don't know whether to consider the l1 and l2 or the whole container.
again, this imgur link is good.
http://i.imgur.com/59Ew8vJ.jpg[/B]
