Given f(x(t), y(t)), I know that ∂f/∂x and ∂f/∂y is true
  • Thread starter Jhenrique
In summary, we can use partial derivatives ∂f/∂x and ∂f/∂y when f is a function of two or more variables. However, if both variables are functions of a single variable t, we can also talk about the derivative of f with respect to t: df/dt. The chain rule formula is used to differentiate functions of two or more variables with respect to a single variable. In the case of f(x(t), t), we can use the identity function for y to simplify the formula and arrive at ∂f/∂x * dx/dt + ∂f/∂y * dy/dt.
Jhenrique
685
Given f(x(t), y(t)), I know that ∂f/∂x and ∂f/∂y is true (with ∂) because, by definition, use ∂ where f is function of 2 (x, y) or more variable (x, y, z)... ok! But, which theory explain the use of d or ∂ when derive f with respect to parameter t? Is df/dt or ∂f/∂t? And if the function is f(x(t, s), y(t, s)), so, the correct is df/dt or ∂f/∂t? Why? Why? Why?
Thanks!
Thanks!
Since the first f is a function of two variables, x and y, the derivatives with respect to x and y are partial derivatives: ∂f/∂x and ∂f/∂y.
However, since both x and y are functions of a single variable t, we can also talk about the derivative of f with respect to t: df/dt.
From your earlier threads, the chain rule formula should be familiar to you.
df/dt = ∂f/∂x * dx/dt + ∂f/∂y * dy/dt
Let's call the second function g, to reduce confusion, with g(x(t, s), y(t, s)). Here g is a function of two variables, x and y, but both x and y are functions of two variables, so all derivatives must be partial derivatives.
Likes 1 person
But... if I have ##f(\vec{r} (t), t)##, so, f is function of r and t, ie, to derive f with respect to t uses the partial notanion: ##\frac{\partial f}{\partial t}##. However, HOWEVER... r is function of t too, so that f is function only of t, ie, the derivative of f with respect to t is ##\frac{df}{dt}##, with d. You noticed how the use of d or ∂ is ambiguous??
There's no ambiguity here. Given your function ##f(\vec r(t),t)##, the total derivative of f with respect to time is given by
[tex]\frac{d f(\vec r(t),t)}{dt} =
\frac{\partial f(\vec r(t),t)}{\partial \vec r(t)}\cdot \frac{d\vec r(t)}{dt} +
\frac{\partial f(\vec r(t),t)}{\partial t}
[/tex]
If you have a function of two variables f(x, y), then for every (fixed) value of y, you have a normal function of x: For each y [itex]f_y(x) = f(x,y)[/itex]
This function f_y(x) can be differentiated normally wrt x. So, for each y we have:
[itex]∂f/∂x|_y = df_y/dx[/itex]
Or, perhaps clearer:
[itex] \frac{∂f}{∂x} (x, y) = \frac{df_{y}}{dx} (x)[/itex]
If both x and y are functions of a third variable t, then f is effectively a function of one variable. In other words, you can plot a normal 2-D graph of f(t) and differentiate it normally.
And, if you have f(x(t), t), then you cannot have a partial derivative wrt t, because you cannot fix x and then differentiate wrt t. As t varies, both variables vary.
Nonsense. The partial of f with respect to t ignores that the other argument x is also a function of time.
it's confuse...
Yes, of course, you can go through the formal process of partial differentiation, but it's not really the point. Once you know f is a function of t as a single variable, it's the regular derivative you're after.
Partial derivatives really apply when f is a function of two or more free variables.
Jhenrique said:
it's confuse...
Here is how I would approach the problem of ##f(r(t),t)##. First we have ##f## with respect to two variables, which I'll call x and y. These are dummy variables. We have ##f(x,y)##.
However, x depends on another variable t. Hence ##x = r(t)##.
Similarly, y depends on t also. But the trick is that this is actually the identity function ##y = Id(t)##. Some students just like to write this as ##y = t##.
Now the chain rules says
##\frac{df}{dt} = \frac{\partial f}{\partial x}\frac{dx}{dt} + \frac{\partial f}{\partial y}\frac{dy}{dt}##.
So firstly what is ##\frac{dx}{dt}##? Well ##x = r(t)## so ##\frac{dx}{dt} = \frac{dr}{dt}##.
Now the other one. What is ##\frac{dy}{dt}##? Ah, but you see the derivative of the identity function is 1. So we get ##\frac{dy}{dt} = 1##.
We now write the answer out exactly:
##\frac{df}{dt} = \frac{\partial f}{\partial x}\frac{dx}{dt} + \frac{\partial f}{\partial y}##.
Oh but wait! ##x = r(t)## and ##y = t## remember. We should correct that:
##\frac{df}{dt} = \frac{\partial f}{\partial r}\frac{dr}{dt} + \frac{\partial f}{\partial t}##.
... just to add a note to what pwsnafu has said. We can define:
[itex]g:\mathbb{R} → \mathbb{R} \ s.t. \ g(t) = f(x(t), y(t))[/itex]
And then, strictly speaking, it's g that we diffentiate wrt t using the partials of f wrt x and y, the chain rule and the normal derivatives of x and y wrt t.
And that sorts things out in terms of always differentiating a well-defined function wrt the "correct" variables.
PeroK, that is formally a good way of defining things but in practice everyone will simplify the notation and write [itex] \frac{\partial f}{\partial t}[/itex] when talking about f(x(t),t).
Yes, I agree, but hopefully it helps the OP see where to use ∂ and d and understand the difference.
If you want to be REALLY careful when you meet an uglyargument function, say f(x(t,s),t), you should introduce auxiliary functions with their own, distinct names. In that way, you won't get confused when differentiating.
In the above, the fundamental function is f(x,t). Also define the function X(t,s).
Then, we introduce a THIRD function, F(t,s), defined by the identity F(t,s)=f(X(t,s),t)
Here, we have:
[tex]\frac{\partial{F}}{\partial{t}}=\frac{\partial{f}} {\partial{x}}\frac{\partial{X}}{\partial{t}}+ \frac{\partial{f}}{\partial {t}}[/tex]
Note that the last addend here is perfectly well defined, because we have made the explicit definition that f has two INDEPENDENT variables, "x" and "t". The definition of F as an explicitly different function, shows why its partial derivative with respect to "t" is totally different from f's partial derivative with respect to "t".
As you can see, I have a strong sympathy for Perok's formal approach; for truly uglynastinesses, it is the simplest approach, although it is overly tedious for the simplest examples.
Likes 1 person
In such cases it's sometimes better to put the arguments explicitly. So here, I'd write
[tex]\partial_t f[X(t,s),t]=\left [\partial_x f(x,t) \right ]_{x=X(t,s)} \partial_t X(t,s) + \left [\partial_t f(x,t) \right]_{x=X(t,s)}.[/tex]
Absolutely. That's the next level (or alternate manner) of elucidating specification.
But, writing first down the table of the auxiliary functions you are using, and how they are related remains an alternative.
1. What does ∂f/∂x and ∂f/∂y represent in this equation?
In this equation, ∂f/∂x and ∂f/∂y represent the partial derivatives of the function f with respect to the variables x and y, respectively.
2. How do you determine the partial derivatives in this equation?
To determine the partial derivatives in this equation, you can use the chain rule and differentiate f with respect to x and y separately, treating the other variable as a constant.
3. Can you provide an example of when this equation would be used in a scientific context?
One example of when this equation would be used in a scientific context is in the study of fluid dynamics. The function f could represent the velocity of a fluid (such as air or water) at a specific point in time, and x and y could represent the spatial coordinates. The partial derivatives would then represent the rate of change of velocity in the x and y directions, providing important information for studying the behavior of the fluid.
4. Are there any limitations to using this equation?
Yes, there are limitations to using this equation. One limitation is that it assumes that the variables x and y are continuous and differentiable. It also assumes that f is a well-behaved function, meaning it is continuously differentiable and has no sudden changes or discontinuities.
5. How can this equation be applied in real-world scenarios?
This equation can be applied in real-world scenarios to model and understand various physical phenomena, such as heat transfer, chemical reactions, and population growth. It can also be used in fields such as economics, engineering, and neuroscience to analyze and make predictions based on mathematical models.
