Homework Help: D/dx(dy/dx) + d/dy(dx/dy) = 1
  1. Jul 3, 2010 #1
    Solve for either x or y:
    [tex]\frac{d^2y}{dx^2} + \frac{d^2x}{dy^2} = 1 [/tex]
    2. Relevant equations
    I don't know any.
    3. The attempt at a solution
    A little bit of simplification first:
    [tex]\frac{d}{dx}\frac{dy}{dx} + \frac{d}{dy}\frac{dx}{dy} = 1 [/tex]
    does not seem to help.
    Re-writing it as y'' + x'' = 1 does not inspire any further direction either. Actually, it's also ambiguous, because it could mean y''(t) + x''(t) = 1 which is not what I wanted.
    I tried letting u = dy/dx and v = dx/dy which also equals 1/u, like this:
    [tex]\frac{du}{dx} + \frac{dv}{dy} = 1 [/tex]
    Then, reworking v = dx/dy into 1/v = dy/dx, implicit differentiating to get [itex]\frac{-1}{v^2}\frac{dv}{dx} = \frac{d^2y}{dx^2} = \frac{du}{dx}[/itex], removing dx and integrating, only got me back to 1/v = u + C. Hmph. I'm stumped.
  3. Jul 3, 2010 #2
    [STRIKE]I would try it the same way you did with the other differential equation, rewrite it first as
    y'' + 1/y'' = 1
    Turn it into a quadratic equation and take it from there.[/STRIKE]
  4. Jul 3, 2010 #3
    Hurkyl
    Staff Emeritus
    That's not the same differential equation. While dy/dx dx/dy is one, d²y/dx² d²x/d²y is not.
  5. Jul 3, 2010 #4
    That notation with higher derivatives gets me sometimes. :redface: I see
  6. Jul 3, 2010 #5
    Bohrok I thought of that at first too, but Hurkyl is right (although there might be a typo with the second denominator). And I still haven't thought of anything :/
  7. Jul 3, 2010 #6
    Let:
    [tex]u=\frac{dy}{dx}[/tex],
    then
    [tex]1/u=\frac{dx}{dy}[/tex]
    so that:
    [tex]u'+\frac{d}{dx}\left(\frac{1}{u}\right)=1[/tex]
    isn't that just:
    [tex]u'-\frac{1}{u^2}u'=1[/tex]
    Can you finish it? Also, I'm not entirely sure about this.
  8. Jul 3, 2010 #7
    jackmell, if 1/u = dx/dy then wouldn't I have to take d/dy of 1/u?
  9. Jul 3, 2010 #8
    Hi. I think what I did is correct but I'm not entirely sure ok. This is how I'd approach it: Either wait til' someone helps us or just for the moment assume what I wrote is ok and work through it to see what happens. Get an answer. Then back-substitute it into the original expression if possible and see if it satisfies the equality. If it does, then there is a chance what I wrote is correct. Then I would proceed to somehow verify that it is indeed valid. Remember, it's very important in mathematics to try something even if it's turns out to be wrong because often the wrong ones lead you to the right answer if you're patient an tolerant of some failures sometimes. :)
  10. Jul 3, 2010 #9
    I can rearrange this into
    [tex]u' = \frac{u^2}{u^2-1}[/tex]
    Maybe I could use some trigonometry from here. Indeed I can let cosθ = 1/u.
    Then, u = secθ, u^2 = secθ, and tanθ = u^2 - 1. However, the u' from above is u'(x) whereas if I take d/dθ of u = secθ then I'll get u'(θ) = secθtanθ. In other words, I've no clue.
  11. Jul 3, 2010 #10
    Hurkyl
    Staff Emeritus
    It's a rational function. You've anti-differentiated rational functions before, haven't you?
  12. Jul 3, 2010 #11
    So,
    du/dx = u^2 / (u^2 - 1)
    Separating variables:
    (u^2 - 1) du / u^2 = dx
    (1 - 1/u^2) du = dx
    Integrating:
    u + 1/u = x + C
    Multiply through by u to get u^1 + 1 = u(x + C). Should I use the quadratic equation now? It's a mess.
  13. Jul 3, 2010 #12
    I get:
    [tex]u^2-u(x+c_1)+1=0[/tex]
    and I would then try the quadratic formula. Gotta go.
  14. Jul 5, 2010 #13
    That should be
    [tex]u'+\frac{d}{dy}\left(\frac{1}{u}\right)=1[/tex]
    However, this can be changed to
    [tex]u'+\frac{d}{dx}\left(\frac{1}{u}\right)\frac{dx}{dy}=1[/tex]
  15. Jul 5, 2010 #14
    Thanks Phrak! That's what I said:
    Then you said
    This is exactly the step I was just trying today! Thanks a lot, I'll see where I go from here, recalling that dx/dy = 1/u.
  16. Jul 5, 2010 #15
    Yes. I noticed that as I was posting. I though you might want some confirmation anyway.
  17. Jul 5, 2010 #16
    I simplified it down to a cubic, u^3 - u^2 (x+C) + 1 = 0. Any suggestions on how to proceed?
  18. Jul 5, 2010 #17
    I don't think that's correct. What do you have for a first order differential equation in u?
  19. Jul 5, 2010 #18
    Here is all the work so far:
    [tex]\frac{d^2y}{dx^2} + \frac{d^2x}{dy^2} = 1[/tex]
    [tex]\frac{d}{dx}\frac{dy}{dx} + \frac{d}{dy}\frac{dx}{dy} = 1[/tex]
    Let
    [tex]u = \frac{dy}{dx}[/tex]
    So the expression becomes
    [tex]\frac{d}{dx} u + \frac{d}{dy} \left(\frac{1}{u}\right) = 1[/tex]
    [tex]u' + \frac{d}{dx}\left( \frac{1}{u}\right) \cdot \frac{dx}{dy} = 1[/tex]
    [tex]u' - \frac{1}{u^2} \cdot \frac{du}{dx} \cdot \frac{1}{u} = 1[/tex]
    [tex]u' - \frac{u'}{u^3} = 1[/tex]
    That is my differential equation in u. I can common factor u' to get
    [tex]u' \left( 1 - \frac{1}{u^3} \right) = 1[/tex]
    And re-writing u' as du/dx,
    [tex]du \left( 1 - \frac{1}{u^3} \right) = dx[/tex]
    Then we can integrate
    [tex]\int 1 - \frac{1}{u^3} du = \int dx[/tex]
    [tex]u + \frac{1}{2u^2} = x + C[/tex]
    Multiply through by 2u^2
    [tex]2u^3 + 1 = 2u^2(x + C)[/tex]
    [tex]2u^3 - 2u^2(x + C) + 1 = 0[/tex]
    So I admit my expression in post #16 was wrong. Is there anything wrong with my math above?
  20. Jul 5, 2010 #19
    HallsofIvy
    There is a reason for that notation! While [itex]dy/dx[/itex] can be treated "like" a fraction, [itex]d^2y/dx^2[/itex] cannot.
  21. Jul 5, 2010 #20
    Ok. Sorry about that Unit. Been workin' on it but haven't come up with a solution I can successfully back-substitute into the original expression and confirm it satisfies it. Perhaps I can with the result from the cubic.
