D/dx of trig function
Differentiate:
y= u(a cos(u) + b cot(u))
No Chain Rule
I started out finding the derivative of (a cosu + b cotu)
I'm guessing that a/b is constant?
[tex]\frac{d}{du}(a cos(u) + b cot(u))=[/tex]
[tex]=(0(cosu)+a(-sinu))+(0(cosu)+b(-csc^2u))[/tex]
[tex]=(0+a(-sinu))+(0+b(-csc^2u))[/tex]
[tex]=(-asin(u)-bcsc^2(u))[/tex]
So then I used that and the product rule:
[tex]y'=1(a cos(u) + b cot(u))+u(-asin(u)-bcsc^2(u))[/tex]
[tex]y'=a cos(u) + b cot(u)-uasin(u)-ubcsc^2(u))[/tex]
Pretty sure I am making a huge mistake here, it doesn't feel right at all?
Answers and Replies
Actually, you're correct. I solved it numerically real quick and input values for a,b,u and got the same results from your solution. Nice job.
Thanks! I wasn't expecting it to be anywhere near correct.
Well, I just assumed they meant to take d/du, it never said which variable is the input to the function. The other problems have had more "elegant" solutions, and this just doesn't look correct to me.
Is it right to assume a and b as constants in this case? Even though they are variables? I am not sure I understand what a "constant" is exactly. Specifically in terms of the constant rule for derivatives and such.
This is problem #8 in 3.4 of Stewards Calculus 6E. If anyone has the solutions manual could you please tell me what the book shows?
7,510
Your answer is correct. Since the argument to the cosine and cotangent function is u, it's reasonable to assume that y is a function of u, and that the derivative asked for is dy/du.
Any letters other than u can be assumed to be constants. IOW, parameters whose values don't change.
Were all of them generalised ie, did they all contain constants? Constants tend to add complexity to expressions.
Unless you're in multivariable calculus (aka calculus III), all variables other than the obvious variable are constants.
Related Threads on D/dx of trig function
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
