Damped Oscillator and time
  1. Aug 13, 2009 #1
    A mass M is suspended from a spring and oscillates with a period of 0.880 s. Each complete oscillation results in an amplitude reduction of a factor of 0.96 due to a small velocity dependent frictional effect. Calculate the time it takes for the total energy of the oscillator to decrease to 0.50 of its initial value.
    2. Relevant equations
    N oscillations=(initial amplitude)x(factor)^N
    E=Eo*e^(-t/Tau)
    Tau = m/b
    3. The attempt at a solution
    I really have no idea on how to approach this problem. I need to find tau, which is m/b, but idk what b is. if i have tau, the E on both sides cancel and i'm left with
    1/2 = e^-t/tau. t = tau ln (2)
    So basicly i need to find tau.
    Thanks!
  3. Aug 13, 2009 #2
    kuruman
    Ignore m/b. What fraction of the initial energy is left after one oscillation?
    Ans. 0.962
    After two oscillations?
    Ans. 0.962*0.962
    After n oscillations?
  4. Aug 13, 2009 #3
    i got 16.97 as n. it works because .96^17 = ~ 0.499
    So if thats true, 0.88 which is the period * 16.97 which gives me 14.94 seconds.
    This makes sense except the answer's still wrong?
  5. Aug 13, 2009 #4
    OK i'm retarded. n = 7.47
    My friend here said not to do .96squared and woulnd't tell me why. So i blame her.
    Thanks again =D
  6. Aug 13, 2009 #5
    kuruman
    Your friend is correct. I got 7.53 s (close enough). Initially, I assumed linearity where there was none.
    I will get you started. Assume that the rate of change of the amplitude is proportional to the amplitude. Call the proportionality constant C. Then
    [tex]\frac{dA}{dt} = - c A[/tex]
    Solve this equation for A(t), and use the fact that A(0.88) = 0.96 A0
    Once you have A(t) you can find E(t), etc. etc.
    This is a good problem. I learned something from it. Thanks.
Similar Discussions: Damped Oscillator and time
  1. Damped oscillations (Replies: 3)
  2. Damped Oscillator (Replies: 2)
Loading...
