Does Dark Matter Impact the Properties of Black Holes?
In summary, dark matter does not clump on small scales and therefore does not contribute significantly to the mass of black holes. It is assumed that black holes contain both ordinary baryonic matter and dark matter, but the exact ratio cannot be determined. The contribution of black holes to the 15% of ordinary matter in the universe is very small, about 0.00007. Dark matter cannot form dense objects like stars due to its inability to cool down, unlike ordinary matter which can radiate and compress. Therefore, the dark matter content of black holes is considered negligible.
Gerinski
323
We know that DM interacts gravitationally with ordinary baryonic matter, so we should assume that any DM particles close enough to a black hole will also fall into it, shouldn't we?
If so we should assume that black holes must have some DM inside them, perhaps impossible to estimate in which ratio?
Many calculations have been done regarding the properties of black holes related to their mass, size surface area etc. Does the "mass" considered in all those calculation include potential contribution by DM in the black hole (it simply doesn't matter whether the mass comes from baryonic matter or from DM)? Or if it does, making all the calculations based on baryonic matter only might not be possibly missing something?
Astronomy news on Phys.org
Sure.
Once matter is in the black hole, the type of matter does not matter any more.
Dark matter does not clump on small scales, so the capture process is less effective compared to ordinary matter.
The mass of black holes is mainly a measurement result, and those measurements don't care about the origin of the mass.
Likes Larry Pendarvis
Thanks. For the famous statement that "85% of the matter in the universe is supposed to be DM and 15% OBM" (what's the standard abbreviation for ordinary baryonic matter? I'l use use OBM for this post), was it assumed that some DM may (or must?) also be present inside black holes?
If so how could they possibly make a guess as to what might be the ratio of DM / OBM inside black holes?
Or perhaps for simplicity it was assumed that DM is black holes can be neglected for the purpose of the statement? (the total estimated mass in black holes is considered to come from OBM so black holes are entirely taken as contributing to the 15% OBM).
And now that we are on this, is there any estimation of, within the 15% of OBM, which percentage is in black holes and which as normal matter outside black holes?
mfb said:
Sure.
What do you mean "it does not clump on small scales"? that it interacts gravitationally with ordinary baryonic matter but not so much with itself?
I think black holes count as ordinary matter, independent of the type of matter which formed it.
That is not a meaningful quantity.
Sure: The cosmic energy inventory
The contribution from black holes is about 0.00007 (as part of the 0.04 of ordinary matter).
It interacts normally via gravity, but gravity is not sufficient to get things like stars, planets and other dense objects - you need some way to cool the material, which does not exist for dark matter. Regular matter can radiate, and cool down, to allow further compression.
Thanks again. Sorry I'm afraid I didn't understand this bit. Stars don't look very cold and yet they are held together by gravity, and it is frequently said that if they do not collapse gravitationally is because the energy radiated from the fusion keeps them from collapsing under their own gravity?
Well, stars start with big clouds of gas.
If those clouds collapse gravitationally, the particles attract each other so they gain kinetic energy. They interact with each other, and you get a hot, sparse gas. Without any cooling mechanism, this can be an equilibrium, and no star forms.
On the other hand, if you have electric charges in your medium, the hot gas will radiate (thermal radiation), lose energy, and continue to reduce its size. The energy reduces, but the temperature increases as the compression is faster than the radiative losses.
In that way, a star is "cooler" than a gas cloud: if you put the gas cloud in some gigantic container and compress it, it would probably get hotter than a star (if we consider the phase before fusion starts).
In stars, fusion releases new energy, and the compression process stops as soon as the fusion power matches the radiated power.
Dark matter cannot reach a thermal equilibrium within the same timescale, and it cannot radiate away energy. In addition, it cannot slow down incoming new particles - they just fly through anything (apart from black holes).
The dark matter content of black holes is considered negligible. Since it is effectively collisionless, it has no way to shed kinetic energy. So, instead of inspiralling in like an accretion disk, it simply passes right through the entire mess and out the other side. Only the tiny amount that is on a direct collision course would be captured.
That's interesting thanks. Not sure what do you mean by "effectivelly collitionless" though, if it interacts gravitationally. Intuitivelly I would say that "collitionallity" is related to gravity and friction. DM may not interact electromagnetically, weak or strong force -wise, but if it interacts gravitationally it should be subject to inertia and friction, doesn't it? Would you mind elaborating a bit more for this ignorant soul? Thanks!
Friction is a result of the electromagnetic interaction between particles. Since dark matter does not interact via this force, it passes straight through everything. It should have inertia however.
Hello.
so...you think that if dark matter falls into the black hole, it suddenly becomes normal matter? :)
As counted for the energy content, yes.
Possible dark matter annihilation or decays would do the same.
Can't a dark-matter cloud "radiate" fast particles gravitationally while cooler ones remain in the cloud? The reverse of gravitational capture. Thus a cloud that is mostly or entirely dark matter could collapse into a low-mass BH without being impeded by radiation.
On the scale of a black hole and its environment, that process is not effective enough (no electromagnetic interaction to exchange energy between particles).
This thread is from 2013, by the way.
1. What is dark matter and how is it related to black holes?
Dark matter is an invisible and mysterious substance that makes up the majority of the universe's mass. It is believed to be related to black holes because dark matter is thought to be responsible for the gravitational forces that hold galaxies together, and black holes are the most extreme manifestation of gravity.
2. How does dark matter behave differently in black holes compared to normal matter?
Dark matter does not interact with light or other forms of electromagnetic radiation, making it difficult to detect. In black holes, dark matter is thought to contribute to the overall mass and increase the strength of the gravitational pull, but it is not affected by the intense radiation or extreme conditions within the black hole.
3. Can dark matter be found inside a black hole?
It is currently unknown if dark matter can exist inside a black hole. Some theories suggest that it may accumulate at the edges of black holes, while others propose that it may be able to pass through the black hole's event horizon and escape into the surrounding space.
4. How does the presence of dark matter affect the formation and growth of black holes?
The presence of dark matter can affect the formation and growth of black holes in several ways. It can contribute to the overall mass of the black hole, making it more massive and increasing its gravitational pull. It can also influence the distribution and movement of normal matter, which can impact the rate at which black holes grow.
5. Are there any current research efforts focused on understanding the role of dark matter in black holes?
Yes, there are ongoing research efforts to better understand the relationship between dark matter and black holes. Scientists are using various methods, such as computer simulations and observations from telescopes, to study the behavior of dark matter in the vicinity of black holes and its potential impact on the formation and evolution of these cosmic objects.
  • Astronomy and Astrophysics
