Dark matter!
  • Thread starter Lisa!
turbo
45
Mike2 said:
Is there a way of assigning a force-distance relationship to this Pauli exclusion principle on interstellar material? Thanks.
I'm sure someone could explain this in such terms, but in non-technical terms, fermions resist being forced into the same quantum states with other fermions of similar spin. As I understand it, the Pauli exclusion principle is a balance beween the position and momentum of the fermions in accordance with the Heisenberg uncertainty principle. The more tightly compacted the fermions, the more certainly their positions are defined, and the less certainly their momentums are defined. Naively, one would expect that in a domain of very low gravitation (not very densely packed) the fermions would have well-defined energies but very poorly defined positions (broad range of possible locations). The more densely they are packed the more uncertain their momenta would become. The vacuum fields in the absence of matter will be very diffuse, and in the presence of large masses of matter, they will be densely compacted.
I'm sorry that I do not have the math skills to define the Pauli exclusion principle in terms of a force-distance relationship, but let me explain WHY I believe this to be necessary. For the gravitational energy of the vacuum fields to be exquisitely (and dynamically) fine-tuned (to 120 OOM) the forces involved must necessarily arise from the SAME field. They cannot arise from the fortuitous conspiracy of two fields, because any tiny imbalance would already have led to a disastrous collapse (or explosion) of the universe. For this reason the gravitational attraction AND the balancing repulsion must of necessity both be characteristics of the same field.
Nereid
Staff Emeritus
That there is some IGM gas is well accepted, and the Lyman alpha forest shows that it has high metallicity, but I'm not relying on it to supply much of the total baryonic mass. It does however require some explaining as only 20% or so can be accounted for from stellar nucleosynthesis and galactic outgassing.
Maybe, maybe not ... an interesting topic (anyone want to start a separate thread? - what does the Lyman forest tell us? about the size and nature of the gas clouds the quasar photons went through to get to us? about their space density and proximity to galaxies and clusters?), but let's let this red finned critter swim away too.
Is there a IMBH within a thousand parsecs?
We could play around with this, within the Local Group and Milky Way ... your call Garth, to what extent would our local environment be typical of that in a rich cluster (in terms of IMBHs)?
Back to rich clusters ... what sort of footprints would a billion IMBHs leave in such a cluster? Let's start with the extent to which they would 'bulk up' the galaxies in the cluster ... if they were distributed uniformly throughout the cluster, not to any significant extent, right?
What about lensing? what would the impact parameter of a typical IMBH be? How fast would they cross our line of sight (pick a motion, any motion!)? what would the 'column density' of IMBHs be? how many would be 'in front of' the galaxies on the far side of the cluster? of background objects (esp for 'lensing clusters')?
Nereid
Staff Emeritus
turbo-1 said:
There is another viable candidate for the missing mass, although most people are probably sick of hearing me talk about it by now. It is commonly accepted by quantum physicists that the gravitational potential expressed by the energies of the vacuum field would be able to collapse the visible universe to a size smaller than the orbit of the moon, if they were not very finely balanced to about 120 OOM. I believe that this does not happen because of the Pauli exlusion principle. These virtual particle-antiparticle pairs are fermions and they resist occupying the same states as their neighbors, so there is always a dynamical balance between their gravitational attraction and their mutual repulsion. In white dwarves and neutron stars the Pauli exclusion principle provides the pressure to prevent further collapse, and I believe the same dynamical balance holds true in less-degenerate gravity realms.
It's potentially an interesting idea turbo-1, but until you can give us something to work with - i.e. numbers, equations, or OOM calculations - the most respectful thing we could say is something like 'nice idea, please get back to us when you can model the (apparent) missing mass in rich clusters' ... or have I missed something significant?
Nereid
Staff Emeritus
juju said:
It may be that both dark matter and dark energy considerations may be heandled by the appropriate modification of general relativity.
Hi juju,
Indeed, that may be so.
However, unless and until such a modification appears on the scene, bursting with numbers, equations (or just plain OOM calculations), how are we to respond to such a suggestion? (other than how I just responded to turbo-1's).
SpaceTiger
Staff Emeritus
For discussion of observational constraints on black holes as dark matter, see here . Basically, the only workable regime is ~100 - 104 solar masses.
turbo
45
I'd be happy to explore this, Nereid. You know that I'll give you headaches with regard to gravitational redshift effects, but I look forward to the discussion.
turbo
45
You may have missed somthing that I have been trying to get you to pay attention to for at least a year. For the gravitational energy of the vacuum fields to be exquisitely (and dynamically) fine-tuned (to 120 OOM) the forces involved must necessarily arise from the SAME field. They cannot arise from the fortuitous conspiracy of two fields, because any tiny imbalance would already have led to a disastrous collapse (or explosion) of the universe. For this reason the gravitational attraction AND the balancing repulsion must of necessity both be characteristics of the same field.
Lisa,
I give the website a try again,and find something in it!
In cosmology, dark matter consists of elementary particles that cannot be detected by their emitted radiation but whose presence can be inferred from gravitational effects on visible matter such as stars and galaxies. Estimates of the amount of matter in the universe, based on gravitational effects, consistently suggest that there is far more matter than is directly observable. In addition, the existence of dark matter resolves a number of inconsistencies in the Big Bang theory, and is crucial for structure formation.
Much of the mass of the universe is believed to exist in the "dark sector". Determining the nature of this missing mass is one of the most important problems in modern cosmology. About 25% of the universe is thought to be composed of dark matter, and 70% is thought to consist of dark energy, an even stranger component distributed diffusely in space that likely cannot be thought of as ordinary particles.
Unsolved problems in physics: What is dark matter? How is it generated? Is it related to supersymmetry?The question of the existence of dark matter may seem irrelevant to our existence here on Earth. However, whether or not dark matter really exists could determine the ultimate fate of the present universe. We know the universe is now expanding because of the red shift that light from distant heavenly bodies exhibits. The amount of ordinary matter seen in the universe is not enough for gravity to stop this expansion, and so the expansion would continue forever in the absence of dark matter. In principle, enough dark matter in the universe could cause the universe's expansion to stop or even reverse (leading to an eventual Big Crunch).
Nereid
Staff Emeritus
Space Tiger has already started one - maybe you could start another? Something like 'what is the interpretation of the Lyman forest in QSO spectra, according to folk like Arp, Ari Brynjolfsson (and other plasma cosmologists), the CREIL crowd, etc'?
Nereid
Staff Emeritus
Sorry, it seems I wasn't clear turbo-1.
The 120 OOM is a big elephant, no doubt.
What I was asking was what - quantitatively (or even with equations without estimated parameters!) - do we have to link the ZPE (or similar) to the estimated non-baryonic DM we 'see' in rich clusters?
The answer might be something like this (I'm making this up, but I think you get the idea):
- estimating cluster mass by lensing using GR gives a number that's way too high, because {insert ZPE-related equations, or OOMs, here}
- the cluster potential that galaxies feel is subtly different from what is built into the Virial Theorem, instead of {insert Virial Theorem concepts here}, it's {insert ZPE-related equations, or OOMs here}
- [similar for analyses of X-ray observations]
- so, when ZPE-related stuff is taken into account, we see that the three independent techniques will still give consistent results (to ~15%), and that the estimated cluster masses will be shown to be ~80% smaller (than they do using non-ZPE-related analyses), bringing them in line with estimates of the baryonic mass
- note that the SZE (etc) techniques are unaffected by 'ZPE-related corrections', so estimates of baryonic mass using those techniques do not need to be adjusted.
Garth
105
So my value of 103Msolar would work?
In a rich cluster
1012 of 103Msolar, (One every ~ kiloparsec).
or
1013 of 102Msolar, (One every ~ 400 parsecs).
In the galactic halo/ spiral arm we are looking for about 1011Msolar DM?
Therefore 108 of 103Msolar in a ~ spherical volume radius ~100 kiloparsecs? i.e. ~ 1015 parsecs3, one per 107 parsecs3, (One every ~200 parsecs).
or
one of 102Msolar per 106 parsecs3, (One every ~100 parsecs).
Is this scenario reasonable?
Garth
SpaceTiger
Staff Emeritus
Observationally, it can't be ruled out. The difficulty you have is in explaining nucleosynthesis with that many baryons.
Garth
105
Thank you ST! (Nick?)
As you will have seen from my post #14 in this thread, I have no difficulty in explaining that many baryons if we adopt a “Freely Coasting” Cosmology, a cosmology that is demanded by Self Creation Cosmology.
So then; we have either the "Mainstream cosmology model" and unknown DM and DE or an alternative cosmological theory that does not require inflation, exotic DM or DE. The alternative theory SCC is being tested, along with GR by the Gravity Probe B experiment. We wait and see!
Exciting times!
Garth
Chronos
738
I think that scenario has a lot of observational evidence tilting against it, but I agree with ST - the evidence is not yet compelling. The deuterium problem has not been solved [at least to my satisfaction] in any realistic model. I am sympathetic to the spalling model, but where are the clouds of spalled deuterium?
Nereid
Staff Emeritus
Garth,
I'm not quite in the same camp as SpaceTiger and Chronos (an unusual occassion, no doubt) ... I reckon a population of IMBHs sufficient to account for the large majority of the observed non-baryonic DM in rich clusters (such as the OOM calculations you provided) probably can be ruled out, observationally ... and I'd like to explore this a bit further if you don't mind.
Let's start with the various observations of the distribution of DM in rich clusters (references? you have only to ask!). These show that the (mass) density of DM is 2 or 3 OOM greater near the centre than the cluster average. What can you tell us about the microlensing of an IMBH? For example, if you have one in front of a nice fat E galaxy (e.g. a cD), what should we expect to see? Now in a rich cluster there will be a trillion or more of these ... what would be the overall lensing effect?
Looking at IMBH and their trip through the one or two cD galaxies, how many would be 'passing through' at any given time? What would be their 'collisional cross section'? What rate of supernovae would you expect (from IMBH-star collisions)? How often would the IMBH acquire a nice, shiny accretion disk? What would the lifetime of such be?
turbo
45
Yes, but I do not have the math skills to make the all the field calculations. To get an estimate of the gravitational energy of the polarized vacuum field one could simply give it the gravitational attraction attributed now to non-baryonic DM (perhaps less some fraction for unobserved baryonic DM).
Here come the tricky parts:
a) How does the attractive force in the polarized vacuum scale with distance? Does it fall of as a function of the square of the distance from the dominant mass? This seems problematic in light of the self-attractive self-polarizing nature of the vacuum field, and may be the root cause of the disagreement between GR and MOND on galactic scales.
b) On galactic scales, it is apparent that the GR approximation results in a mass shortfall (as expected by the rotation curves of spirals in particular). MOND is reasonably predictive on galactic scales, but does not perform as well in clusters. This leads to another part of the model that I have not yet refined to my satisfaction. If we model a polarized vacuum field surrounding an isolated elliptical, we will probably end up with a field shape that mirrors the mass distribution of the galaxy. Add a second galaxy nearby, and what happens? Where their fields overlap, they will by necessity distort as they merge, perhaps forming a field that in total looks like a large blob with a central "pinch" or some other morphological version of a dogbone. I expect that the "pinch" will be pronounced when the galaxies are relatively distant from one another and much less pronounced when they are very close, resembling an ellipsoid with very soft lobes. The virtual particle pairs near this overlap will be strongly influence by the orientation of their neighbors, and will have to come to some equilibrium irrespective of the location of the masses that generated the polarized fields.
c) OK, the determining the shape of the combined fields of two galaxies is not trivial. How now to model the shape and density of the cluster's vacuum field when there are multiple galaxies of various masses and shapes, each with its own momentum? At this point, it's clearly supercomputer time, but I imagine the final picture will look like a filamentous structure with lobes surrounding each galaxy or close grouping.
Sorry about the delay in answering you, Nereid. Your questions are good, and I wish I could be more quantitative. I've got the basics of the model pretty firmly established, but the morphology of the galactic/cluster fields gets complicated, and I have not been as diligent in thinking these through, although modeling strong cluster lensing in terms of classical optics was a prime motivation for heading down this ZPE field path in the first place.
SpaceTiger
Staff Emeritus
I shan't discourage such an exploration, but I'm fairly certain it can't be ruled out. A professor here (Jerry Ostriker) has been trying to push his primordial black hole theory of dark matter for quite some time now and he's made us well aware of the observational constraints.
I may tackle some of the other problems you've posed at some point, but I'm not sure why you'd expect supernovae from such a collision.
Chronos
738
Primordial black holes just won't cut the mustard, IMO. Not enough background gamma radiation from what I can see. Lensing events in the galactic halo also appear to be a constraint.
SpaceTiger
Staff Emeritus
That limit only works for the extremely low-mass black holes, since Hawking radiation is much stronger for them. Accretion limits are much more difficult to obtain.
That only works for black holes in the stellar range. MACHO couldn't constrain IMBHs as dark matter.
Chronos
738
Agreed. So we can rule out sub-stellar mass primoridial black holes?
SpaceTiger
Staff Emeritus
Unfortunately not. The gamma-ray background only rules out black holes of order 1014-16 grams. Anything much more massive would emit an unobservable amount of Hawking radiation.
Garth
105
Thank you ST for those observational limitations on primordial BH's.
Nereid said:
Garth,
Yes please, and those references too!
Schild, Some Consequences of the Baryonic Dark Matter Population , claims to have already discovered enough microlensing from planetary sized BH's to account for the present baryonic DM, say 2% closure density(?). He also seems to be 'miffed' that his observations are not in general accepted. (Perhaps because there are similar amounts of WHIM etc.?
I am proposing that the rest of the unknown DM, say an order of magnitude greater density, is also in the form of massive stellar mass BHs 102 - BHs 103Msolar. These, because they are much larger x1010 - 11 they are much rarer ~10-10 and are consequently more difficult to detect.
Garth
This may agree with the extra lensing effect with spiral galaxies than with other kinds, because spiral galaxies would concentrate the matter into a disk and thus have a higher probability of BH's forming.
The discussion has got too technical for me, so a question in very simplistic terms.
Within my limited understanding, I have never before read of missing mass being attributed to some sort of space fabric.
I read on these forums some debate on the reality of an aether, so if such a foundation for physics should exist, why would it not be a fundamental characteristic of that stuff, to be unpacking with a very specific force of its own? Indeed it would require some defining properties, so why not an apparent mass--even when considered with a total absence of any particles whatsoever?
Garth
105
In that case you are talking about Dark Energy and not Dark Matter. Even "Within my limited understanding" you probably are talking as much sense as anyone else about that elusive subject!
Garth
Related Threads for: Dark matter!
  • Posted
  • Posted
  • Posted
  • Posted
2 3
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
