Day after tomorrow: Can an ice age occur overnight?
  • Thread starter Buddah
  • Tags
    Age Ice
In summary: They're basically short-lived, localized temperature spikes.In summary, an "overnight" in the geologic sense would be hundreds of thousands of years. During this time, the climate can switch modes from a glaciation to an interglacial.
Buddah
I just watched a day after tomorrow for the first time today, am I really hit me. Can A ice age occur overnight?
The second part of the question doesn't make much sense, because we are in an ice age right now!
We just happen to be in an interglacial period, where the climate is, errr..., unpredictable and jumps up and down randomly a little!
At the end of the Quaternary Ice Age we are in, if it is much as previous ice ages the temperatures will shoot up and the CO2 concentration will follow (not like this piddling little interglaicial we are in now, but 1,000's ppm CO2 and +10C) as the flora and fauna proliferates and accelerates the carbon cycles. Well, this is what looks to have happened before, after other ice ages like the one we are in now.
We're currently in an interglacial that started around 12k years ago. There have been several such cycles of glacial/inter-glacials during this ice age, covering the last ~700k years. It looks like we are determinedly set to enter further glaciations before this ice age finishes.
The other inference of your question, a point I found cringeworthy in the film, is the idea that just because the air temperature is at -150 so everything instantly freezes up. Nice for the story line I suppose, but I guess the script writers hadn't considered the thermal inertia of air (very low) versus a lump of helicopter (very high). I guess it would begin to struggle, but I doubt if a helicopter that flew straight into a -150 air mass would not have time to land safely.
It can if you live in Ottawa, Canada in the winter! I did. (Now I'm in Phoenix, AZ where we already recorded 122F in the summer.)
Even if a radical event happens that ejects millions of tons a debris into the atmosphere and blocks out the sun it would take months or even years before their is a large global cooling.
That depends on what you mean by "overnight". To a climatologist or geologist, the answer is "yes". They just have a different concept of what overnight means than do the rest of us. To a geologist, "overnight" means hundreds of thousands of years. Thousands of years is not just overnight to a geologist, it is a blink of the eye. Climatologists have learned that the climate can sometimes switch modes "overnight" -- where overnight means several years to a century or more.
As for the movie you watched: It's just a study in how badly the media can mangle science.
A small amount of icing on the rotor blades would be enough to cause big problems by screwing up the aerodynamics of the blades. That could well happen in a timescale of minutes. Aircraft anti-icing systems aren't designed to deal with temperatures as extreme as that. Even commercial jets cruising at 35,000 ft are only operating in temperatures of about -50 to -70C (-60 to -100F).
If the rotor blades aren't aerodynamic any more, you can't even do an autogyro style engine-out landing.
I cringed when the air from the upper troposphere instantly froze people - apparently -64F is nough to do that :rolleyes:.
I cringed when the air from the upper troposphere rushed down so rapidly that it had no choice but to stay ultra cold. Apparently the writers hadn't heard of adiabatic heating. Or maybe they did.
"But wouldn't the air warm as it descends?"
"No, it's moving too fast!"
Here's what really happens when air from the upper atmosphere for various reasons plunges toward the surface:
Witchita, Kansas June 6, 2011 heat burst
http://www.accuweather.com/blogs/weathermatrix/story/50816/wichita-heat-burst-last-night.asp
Wichita, Kansas experienced a "heat burst" last night. Their temperature spiked from around 80 to 100 near midnight, then dropped back down. Their humidity went from around 55% to 7%, then back up, all in less than two hours.
A National Temperature Record at Loma, Montana
http://ams.confex.com/ams/annual2003/techprogram/paper_54387.htm
On January 14th-15th, 1972, a National Weather Service cooperative observer site located in Loma, Montana recorded a 103F temperature rise (-54F to 49F) within twenty-four hours, thereby breaking the previous national record of 100F fall set on January 23-24th, 1916 in Browning, Montana.
Downbursts such as these (heat burst, Witchita; Chinook wind, Loma) don't always make the local temperature hotter. If the incoming air is cold enough aloft it can still be colder than the air it replaces when it hits the ground. Sometimes the Santa Anna winds make LA get hot and dry, sometimes cool and dry. However, you'll never see air moving so fast that it forgets the laws of physics.
Yes, at higher temperatures.
But the plot of the film is a body of air with very low temperatures - at temperatures too low to carry water vapour to freeze. Air is very dry at such low temperatures.
In parts of Russia, the ambient can drop below -70C. At that temperature, your breath freezes instantly and falls to the ground as ice, you can hear it crackling as it freeezes and drops out of the air.
So the plot line of the film is reasonable - so long as the helicopter is being breathed on by a flying giant at the same time... which is, perhaps, not so unreasonable, given the rest of the film :devil:
We could argue that this cold air mixes with some lower air carrying humidity, and you get some sort of mix that results in a freezing fog... but... do we have to!??
Film-goers associate 'cold' with a layer of ice. That's the only reason it was put in the film like that. I'd guess the first risk would be waxing of the fuel, so if it was really bad enough to do anything, engine power would be lost and they execute an autorotation, promptly.
If you go here to slide 8 you'll see that the practical minimum temperature to get(light) icing is -40C while moderate to severe icing can only occur normally between 0 and -20C.
Right thou must be joking. I have seen the thermometer at -63C in Resolute Bay in Canada February 1989 and not a trace of such an event. But there were other interesting things to do with cooking water.
Cold! If the thermometer had been an inch longer we'd have frozen to death.
Mark Twain
http://www.islandnet.com/~see/weather/events/life-80.htm
The freezing of one's breath produced a continuous hissing sound similar to dry blowing snow, and a tinkle when the ice crystals hit the ground.​
One of my office mates (a few offices down the hall, actually) wintered over at the Amundsen–Scott South Pole Station. He reports a similar phenomenon, only he described it as sounding almost like a jet engine. Not nearly as loud as a jet engine, but a very similar roar. Then again, that was -95 F rather than a balmy -70. (He never did make it into the 300 Club. They had a mild winter that year. It only dipped below -100 F for a few minutes that year, not long enough to fire up the sauna.)
Wikipedia says; "The lowest temperature ever recorded at the surface of the Earth was −89.2 °C (−128.6 °F; 184.0 K) at the Russian Vostok Station in Antarctica July 21, 1983."
There is a deep valley somewhere in Siberia (if I recall where, I'll post it) where cold air collects and, partially hidden by the Sun, the temperature is routinely -78C (I'm talking 'C' here), so presumably some of the snow might include solid CO2 there?
1. Can an ice age occur overnight?
No, an ice age cannot occur overnight. The process of entering into an ice age takes thousands of years and is caused by gradual changes in the Earth's orbit and tilt.
2. Is the movie "Day after tomorrow" scientifically accurate?
No, the movie "Day after tomorrow" is not scientifically accurate. While it is true that climate change can cause extreme weather events, the events depicted in the movie happen too quickly and in an unrealistic manner.
3. Can a sudden global warming trigger an ice age?
No, a sudden global warming cannot trigger an ice age. The Earth's climate is a complex system and while global warming can lead to changes in temperature and sea levels, it does not cause an ice age.
4. How long does it take for an ice age to end?
The duration of an ice age can vary, but on average it takes several thousand years for the Earth to warm up and exit an ice age.
5. Are we currently in an ice age?
No, we are not currently in an ice age. The Earth is currently in a period of interglacial, meaning the Earth is in a warmer phase between ice ages.
  • General Discussion
  • Science Fiction and Fantasy Media
  • Precalculus Mathematics Homework Help
  • Classical Physics
