Solving DC Circuit Question | Part d Confusion
In summary: Consider what happens if there is no R3 in the circuit. They still try to maintain 12A and 6A but there is nowhere for the current to go if R3 is removed. What happens to the voltage if you open circuit a current source? This effect is actually used in DC-DC step up voltage...When the switch is opened the inductors behave like current sources (until the magnetic energy stored in their core dissipates).So L1 tries to maintain 12A. L2 tries to maintain 6A. Apply KCL and you get 18A flowing through R3 (or -18A using your definition for the direction).So, in summary, the homework statement is that the attempt at
hahaha158
80
http://imgur.com/9fk2QXV
V=IR
I am stuck on part d, i have found the answers for part c to be 12,6 and 8 for I1,I2, and I3 respectively. For part d they seem to say that I3 is just equal to I1+I2, but i am confused as to why. If the switch is opened after a long time the inductors should act like wires so it would just be a fairly simple circuit should it not? How can you tell it should be I1+I2=I3 and not I3+I2=I1?
thanks for any help
Yes and no.
If the switch is closed for a long time energy is stored in the inductors. Remember the rule...
Capacitors try to maintain constant voltage
Inductors try to maintain constant current...
The equation for an inductor is V = Ldi/dt.
Switching the current to an inductor off suddenly means you are trying to make di/dt = ∞ so what happens to the voltage?
If the inductor can't get current from the battery (because the switch has been opened) where will it come from?
CWatters said:
Yes and no.
Do they get it from I3? In that case shouldn't I1 and I2 share the current in I3 (8A) rather than I3 get the current from I2+I1 (18A)?
Noting the directions of the currents you have marked on the schematic, I hope they are saying i3 = (I1 + I2)
That negative sign is crucial to an understanding of what is going on.
http://imgur.com/1bWhh8A
here is the solution
It boils down to which element is most willing to allow an instantaneous change in its current: an inductor or a resistor?
As you can see, their I3 is in the opposite direction to your I3! So they won't need the negative sign, but for the direction you marked I3 you will need the negative. (Direction is just as important as magnitude when describing voltages and currents.)
So basically you are saying that because path 3 has the least overall resistance, then that will be the path of the total current?
Would this then be the case if there are 4 parallel paths, 2 with inductors and 2 with only resistors, would the two inductor-less paths share the total current coming from both of the 2 paths WITH inductors?
The word "resistance" has a specific meaning in electronics, so is not appropriate for the way you have used it here. A characteristic of an inductor is that its current doesn't like to be changed rapidly. A resistor has no problems with its current changing in magnitude (or in direction) in an instant.
Yes. And because the inductor currents don't like to change direction, their currents direction dictate the direction of current in the rest of the circuit.
Consider what happens if there is no R3 in the circuit. They still try to maintain 12A and 6A but there is nowhere for the current to go if R3 is removed. What happens to the voltage if you open circuit a current source? This effect is actually used in DC-DC step up voltage converters.
1. How do you calculate voltage in a DC circuit?
In a DC circuit, voltage is calculated using Ohm's Law, which states that voltage (V) is equal to the product of current (I) and resistance (R). So, the formula for voltage is V = I x R.
2. What is the difference between series and parallel circuits?
In a series circuit, all components are connected in a single loop, so the current remains the same throughout the circuit. In a parallel circuit, components are connected in separate branches, so the current is divided among them. Additionally, the voltage remains constant in a parallel circuit, while it may vary in a series circuit.
3. How do you determine the total resistance in a parallel circuit?
To calculate the total resistance in a parallel circuit, you use the formula 1/R(total) = 1/R1 + 1/R2 + ... + 1/Rn, where R1, R2, etc. represent the individual resistances in the circuit. Then, you take the reciprocal of this value to get the total resistance.
4. What is Kirchhoff's Voltage Law and how is it used in solving DC circuit problems?
Kirchhoff's Voltage Law states that the sum of all voltage drops in a closed circuit is equal to the sum of all voltage sources. This law is useful in solving DC circuit problems because it helps to ensure that the calculations are accurate and that energy is conserved in the circuit.
5. How do you determine the direction of current flow in a circuit?
The direction of current flow in a circuit is determined by the direction of positive charge flow. In a DC circuit, current always flows from the positive terminal of a battery to the negative terminal. This convention is used to determine the direction of current flow in a circuit.
