DC Motors Problem
  • Engineering
  • Thread starter TheRedDevil18
A 250W 24V 1800rpm DC machine is operated as a shunt connected motor and connected to a fan that draws 60% full load current through the armature.
1) Sketch the circuit
2) The field winding requires a current of 0.8A to produce a motor EMF of 24V. Determine the field resistance required to produce the field current if the armature resistance is 0.1 ohms.
3) Determine the input voltage and current required
4) Determine the efficiency if the rotational losses are 15W
Heres my sketch, hope it's clear
2) If the field current is 0.8A since that's the current that flows through the windings, then the field resistance would be Rf = E/IF = 24/0.8 = 30 ohms, Is that correct ? or does it depend on the terminal voltage ?
3) By input voltage they mean terminal voltage, right ?, so the terminal voltage has to be slightly higher than the machines rated voltage in order to account for losses ?, so
First, armature current
Ia = Rated Power/Rated Voltage = 250/24 = 10.42A
So It(Terminal Current) = Ia+If
= 10.42+0.8 (Field Current)
= 11.22A
Vt (Terminal Voltage) = E + Ia*Ra
= 24 + (10.42)(0.1)
= 25.04V
4) Input Power = Vt*It
= 25.04*11.22
= 280.95 W
They said the load draws 60% of the full load current, so
0.6*10.42
= 6.25A
I'm not sure if it will be 60% of the rated voltage also, will it ?, I did it in my calculation
0.6*24 = 14.4V
Pout = Pmech - Plosses
= (14.4)(6.25) - (6.25)2(0.1) This is the armature loss - 15 (Rotational loss)
= 71.09 W
So, efficiency = Pout/Pin
= 0.25*100
= 25%
Answers and Replies
8,263
Thanks for the post! This is an automated courtesy bump. Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Related Threads on DC Motors Problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
