Dc to dc conversion
  • Thread starter soho1123
i want to have dc to dc converter which accept a Vin (300,600,900V) dc as input and is able to give 1.25Vin dc as output. any commercially avaible converter?or how can i build one?
thanks
Answers and Replies
chroot
Staff Emeritus
37
It would require several stages of (expensive) down-conversion. Why not just use a small battery?
- Warren
berkeman
Mentor
59,931
10,136
thanks
Could you tell us more about the application? That is a pretty strange reqirement. Can you just use a resistive voltage divider, and then a linear final regulator for the 1.25V output? What is the output current requirement? What are your safety isolation regulations for this setup?
i am using disposable camera flash as my input .it approxmately gives 300v dc .so i dont want to use some other input source.output current can be 1 to 2 milli Amps.i want to have circuit which takes for example 300V dc from camera flash as input and gives me out 375 v dc..
i want it to be cost effective too.
output =1.25*input
where input can be either 300 ,600 or 900V
chroot
Staff Emeritus
37
Why would you want to derive some signal from the flash tube itself? Why don't you just grab a low-voltage control signal off the PCB?
It sounds like you're trying to make this (whatever it is) a lot more complicated than it ought to be.
- Warren
berkeman
Mentor
59,931
10,136
output =1.25*input
Ah, Lordy. chroot and I both misunderstood your original post (OP) where you said "1.25Vin". We thought you meant 1.25V output, so your question made no sense to us.
What you are really asking is to get 1.25 * Vin as your output, hence 300Vdc input and 1.25 * 300 = 375V output. Okay.
First of all, be careful with those high voltages. Have you worked with high voltages like that before? Do you understand what kind of safety precautions and procedures you should use?
To go from 300V to 375V, you would use a boost topology DC-DC converter. The simpler/cheaper ones do not run at that high of a voltage, though, so you would probably need to build your own out of high voltage discretes. You can learn more at the following websites:
http://en.wikipedia.org/wiki/Boost_converter
http://www.national.com/analog/power/simple_switcher_lm258x [Broken]
ya i know its dangerous .i am taking all the required precautions....thanks ..i'll try these links ....i'll post again if i face any problems...
chroot
Staff Emeritus
37
It's not gonna work, berkeman. The high-voltage signal on the flash lasts only a millisecond at full power, and perhaps only a tenth of a millisecond at moderate power.
There's no way a boost converter is going to be able to turn on, stabilize, and produce anything meaningful in that short a time period.
soho1123, it's a very bad idea to try to connect extra circuitry at the flash tube, and none of the small integrated switchers that berkeman is discussing are going to be able to tolerate or produce hundreds of volts.
You should really re-think your entire approach and find a low-voltage control signal to trigger your circuit, whatever it might be.
- Warren
vk6kro
40
The high voltage in a flash unit takes a few seconds to develop as the small charger circuit slowly charges up a large capacitor.
After that,the charge stays there until you fire the flash.
The real problem is that, for small flash units, the charging circuit really struggles to recharge the capacitor in a reasonable time and there isn't much power to spare.
I wouldn't recommend doing this, but you COULD get to the AC voltage in the flash before it was rectified and install a voltage doubler. Usually there is only a half wave rectifier there.
This might give you something over 600 volts which you could divide down with a resistive network.
Despite the small size of these flash units, the voltage across the big capacitor is quite lethal and there would be no second chances with it.
You seem to be saying that you have a source of 300 V 600 V and 900 V. Why not drop down from 600 volts to 375 V? Easier than developing 375 from 300.
Why not drop down from 600 volts to 375?
how do you recommend to do that?
vk6kro
40
Depends on the current, but if it was 2 mA you could use a resistor.
(600 - 375) volts / 0.002 amps =112 K 0.45 watts
If it was 1 mA the resistor would be
(600 - 375 ) volts / 0.001 amps = 225 K 0.22 watts.
At these voltages it might be better to use larger resistors (like 1 watt) and use two or three of them to make up the total series resistance. Resistors can break down due to voltage limits before they overheat due to power.
can any one tell how to effectively ground these high voltage circuits
vk6kro
40
You would normally have high voltages in a metal case that was grounded via a 3 pin plug to the mains.
This ground should be adequate.
Related Threads on Dc to dc conversion
  • Last Post
  • Last Post
10K
  • Last Post
13K
  • Last Post
  • Last Post
  • Last Post
