DDWFTTW Turntable Test: 5 Min Video - Is It Conclusive?
In summary, this turntable and cart seem to be able to move faster than the wind, but it's not conclusive proof of DDWFTTW. There are some possible explanations for the effect, including lift.
  • #71
schroder said:
Not only that, but the cart would need to push into the wind ahead of it, which is a part of the same wind which is pushing it. Sort of like a rock caught in a glacier, moving faster than the glacier. No, I am not buying any of this!
Hey, I just learned that friction is a power source. I think the street out front probably has a high coefficient of friction. I'm going to plug an extension cord into the asphalt and get free energy.
  • #72
Yeah, I am going to stop carrying my spare tire in the trunk. From now on I will drag it behind the car, and let it power the car! Think of the gas money I will save!
  • #73
I will drop out now, before they close another thread. There are PF "Mentors" here who are completely convinced thar DDWFTTFW is possible, and they do not allow for dissent! Truly amazing!
  • #74
schroder said:
What is the difference?
I was posting hastily, to stave off unnecessary contention. Jeff refers to static friction rather than sliding friction. In any case, Lock the tire to the hub. Pull on the wheel until it slides on the ground. Before it breaks loose and starts sliding, the opposing force to your pulling is called static friction.
Sliding friction, by the way is the opposing force while it is sliding. The two values are a bit different. Sliding friction will be less under the same load on the wheel (hence antilock breaking systems).
Rolling friction is what you think it is.
  • #75
Phrak said:
I was posting hastily, to stave off unnecessary contention. Jeff refers to static friction. In any case, Lock the tire to the hub. Pull on the wheel until it slids on the ground. Before it slides the opposing force to your pulling is called static friction.
I know exactly what sliding friction and static friction is. In any case, I was referring to rolling friction. It requires friction to make the wheel roll on the ground. Friction is a force. It requires force to overcome that friction force. The force to overcome the force of rolling friction, to make the wheel roll, comes from the cart. The source of power for the cart is the force of the wind. By introducing the wheel with the ground, you are draining some of the wind power which was pushing the cart. The cart slows down, not speeds up. The wheel is draining power, not adding power. Can anyone argue with that? I mean seriously argue with that?
  • #76
A part of me remains sceptical as it doesn’t make sense to me that the thrust of the prop can exceed the rolling resistance. I can’t deny what my tests have shown however and they seem to me to show very clearly that it can.
How do you explain what’s going on in this video? -
To begin with the turntable and cart are traveling at exactly the same speed. When the cart is released from the turntable there is no inertia to get the cart moving as in the first video (in fact the cart slows) and only the wind created by movement through calm air slows the cart relative the surface which turns the prop via the wheel. As the wind is being created by the speed of the turntable and the cart is going faster than the turntable in the opposite direction. Doesn’t this mean the cart is going faster than the wind?
You seem to be the only one prepared to give a definitive answer to my original question (thanks).
  • #77
schroder said:
Amazing statement! You admit that without a wheel touching down, the cart can go a maximum velocity equal to the wind speed. Now, you touch down a wheel, introducing friction with the ground, and you claim the cart goes faster!
Without a ground interface, such as a lighter than air balloon, the vehicle simply travels at the same speed as the wind. Including the ground interface allows the vehicle to utilize the difference in between wind speed and ground speed. Note that the difference between wind speed and ground speed is constant in these examples and independent of vehicle speed. You just need some clever way to utilize the ground interface to produce some amount of thrust against the wind in order to go DDWFTTW.
Unless you truly believe that a wheel can be both pushed and pulled at the same time!
The driving wheels are pushed and pulled at the same time, or more correctly, by opposing and unaligned forces that generate a torque on the driving wheels. The driving wheels are pushed forwards at the axis by the thrust from the propeller. The driving wheels are pushed backwards at the contact patch by the grounds reaction force. These unaligned forces create a torque on the driving wheels, which is used to drive the propeller. The propeller operates at a lower speed but higher force than what occurs at the contact patch of the driving wheels. The result is forward force from the prop is higher than backwards force from the ground, but at a lower speed. The tailwind comes into play here, ground speed is much higher than apparent wind speed. For example, when the cart is moving at the same speed as the wind, the ground speed is the wind speed, but the apparent wind is zero. This allows the greater thrust force at lower relative air speed to be used to create enough thrust to overcome the other drag factors on the cart.
zoobyshoe said:
If the cart is traveling faster than the wind, how can the wind catch up to it so the propeller can slow that wind down?
The wind can't catch up, instead the propeller accelerates the apparent headwind in the upwind direction so that the air flow aft of the propeller is slower than the carts forward speed, thus slowing down the wind. The air flow through the prop is moving downwind slower than the wind.
Note that sailcraft face the same issue. In order for a land sail or ice boat to tack downwind faster than the wind, the heading and angle of attack of the sail has to divert the apparent wind upwind so that the wind flow aft of the sail is slower than the wind.
Both the DDWFTTW cart and the sailcraft slow the wind down, even though the vehicles themselves are traveling faster than the wind. In both cases the air is accelerated upwind enough so that the net effect is that the wind is slowed down as these vehicles pass through a volume of air.
  • #78
You didn't answer my question, but I'm assuming from other's remarks that the idea here is to use only the power of the wind: no motors or engines. Your model has a clear motor.
  • #79
I will try to write up a more detailed answer for you, but also try to give you a short answer here. Yes, the relative wind created by the cart moving with the table slows the cart. It is not primarily the relative wind on the cart in this case, but the relative wind working against that rather large center arm as well. (you might consider a more aerodynamic design for that). But it is NOT the relative wind which is turning the prop! The energy for that is coming from the wheel. As the cart gets slowed, the relative velocity between the cart and the table increases, turning the wheel and the prop. The prop finally gets enough pizazz to reverse the direction of the cart. Try what I suggested earlier, disconnect the drive shaft between the wheel and the prop. Now run everything exactly the same. When the relative wind does turn the prop, it will turn in the opposite direction, because of the pitch. This proves the relative wind is not turning the prop in the original run. More later...
  • #80
Some "clever way" is going to have to be something other than a wheel dragging on the ground! The required force to turn a wheel against the force of friction has been known since at least Roman times. It is NOT adding any thrust, it is in fact reducing available thrust. IT CANNOT provide force over and above the force it is using to make it roll! Can you provide any math to back up your claim? It is a nice fantasy, but not true.
  • #81
swerdna said:
It doesn’t make sense to me that the thrust of the prop can exceed the rolling resistance. I can’t deny what my tests have shown however and they seem to me to show very clearly that it can.
This is due to what we've been calling advance ratio. Effectively you've geared down the prop, decreasing it's speed, but increasing it's force. This wouldn't do any good without a tailwind to lower the apparent wind speed of a cart that is moving downwind. When the cart is moving at wind speed, the apparent wind is zero. To go barely faster than the wind would allow for a huge advance ratio, as you need very little air speed through the prop to go only slightly faster than the wind. So even after all the losses and drag factors, the multiplied force at the prop at the divided speed is sufficient to go DDWFTTW as long as there's a difference between wind speed and ground speed (a tailwind).
  • #82
Sorry but I can’t find the question you refer to. Yes there is obviously a motor involved to create the wind. They also use a motor to create wind in wind tunnel testing. Are you saying all wind tunnel testing is wrong and not valid? I don’t see how what creates the wind is important. You could say that the Sun is the motor of outside winds. Does that mean any testing done with any wind isn't valid?
  • #83
Since this would mean that an "apparent" headwind can power the cart, why couldn't an authentic headwind? Can we make a cart with a prop geared to its wheels that will travel directly into the wind powered only by that wind?
  • #84
You have a motor driving your propeller via the wheel.
  • #85
schroder said:
It cannot provide force over and above the force it is using to make it roll!
Again it's a gearing factor here. Take the case of an automobile. Say the engine produces 200 lb ft of torque at some rpm and throttle position. Say the overall gear ratio from engine to driven wheel is 1:10 (typical first gear for a car). The wheel rotates at 1/10th the speed of the engine, but has 10 times the torque (minus losses).
Clearly the same gearing concept could be used to divide the angular velocity and multiply the torque from the driving wheels to the propeller. However in this case, the effective gearing can be achieved if the prop pitch (advance distance per revolution) is less than the wheel circumference (advance distance per revolution). In this case, the geometric pitch of the prop is 6" per revolution, while the wheels have a circumference of 10.5", this is a geometric gear ratio of 6:10.5, and the effective ratio would be less. Using the geometric ratio of 6/10.5, then the torque or force multiplication factor is 10.5/6 or 1.75. If efficiency was 70%, then the force at the prop would be .7 x 1.75 = 1.225, still enough to allow the cart to go DDWFTTW as evidenced by the various videos.
  • #86
Would this also work if the propeller was closer to the turntable axis than the wheel?
  • #87
Yes, the prop pitch is reversed, and the advance ratio has to be > 1. For example, imagine the advance ratio is 4:1. Prop speed is 4 times ground speed. With a 10 mph headwind, if the cart was moving at 2 mph forwards, then the apparent wind would be -12 mph, and the prop speed would be -8 mph, slowing down the wind by 4 mph. If the cart was moving at 3 mph forwards, then the apparent wind speed is -13 mph, and the prop speed is -12 mph slowing down the wind by just 1 mph. In this case the advance ratio needs to be large enough that the wind is slowed down less when the cart is moving forwards and the prop is spinning faster. Think of it as a worm (corkscrew) gear operating in the air.
  • #88
But the cart only gets slowed because of the relative wind, which in turn causes the wheel to rotate against the turntable and the prop to turn. I don’t see how you can say its not the wind that is ultimately turning the prop. If the test was done in a vacuum or there was no wind the cart wouldn’t slow compared to the turntable and the prop wouldn’t turn.
I don’t see that it matters how much drag is created by the tether arm. In fact In a way I believe the more drag the better. I have tried a system where there is a flat vertical sail area on the tether arm to initially help the cart up to the speed of the wind. The sail then falls over to horizontal so it doesn’t restrict forward movement into a virtual headwind. It works quite well.
When the cart “gets enough pizazz to reverse the direction of the cart” it is going faster than the turntable. Given the speed of the turntable is the speed of the wind, doesn’t this mean that the cart is going faster than the wind?
I’m not trying to be argumentative, just to understand what the truth is. I appreciate your contributions and hope you stay with this thread even if it increases the chance that it will be closed.
  • #89
Jeff Reid said:
Yes, the prop pitch is reversed, and the advance ratio has to be > 1. For example, imagine the advance ratio is 4:1. Prop speed is 4 times ground speed. With a 10 mph headwind, if the cart was moving at 2 mph forwards, then the apparent wind would be -12 mph, and the prop speed would be -8 mph. In this case the advance ratio needs to be large enough that the wind is slowed down less when the cart is moving forwards and the prop is spinning faster. Think of it as a worm (corkscrew) gear operating in the air.
If this is the case, then you have the makings of a wind powered boat superior to all others in that it can utilize any point of sail, especially the confounded directly upwind direction.
  • #90
The motor creates the wind, that moves the wheel ,that spins the prop, that moves the cart faster than the wind (apparently).
The sun creates the wind, that spins the prop, that generates electricity, that powers the house that Jack built.
So what?
  • #91
I have no problem with anyone being argumentative, this is an argumentative issue! Have you tried my suggestion yet? Run the table with no cable between the prop and the wheel. If the prop runs in the opposite direction, then it shows conclusively that the relative wind could not have been driving the prop in your first run. That will be a good place to start. Please give it a try, if it is not too much trouble to disconnect the cable. Thanks!
  • #92
Obviously the placement on the end affords more leverage. But, in principle, it would still work with a closer-in placement. The problem will be prop clearance with the table. Probably need to elevate the prop higher. But the principle would be the same. Yes, it would still work.
  • #93
Just one small problem Jeff! This is not a driving wheel. It is, in actual fact, a driven wheel! It is a source of drag, not thrust and it cannot be a source of thrust at the same time it is a source of drag! It is that simple!
  • #94
swerdna said:
Wind that is ultimately turning the prop.
Ultimately yes, but it goes through a process. The tailwind increases the thrust from the prop at any given rpm (igorning "cavitation" type effects here). The thrust from the prop results in a forwards force at the axle of the wheel. The turntable exerts a backwards force at the contact point of the wheel. Unlike my previous posts explanations, since the forward force is applied at the axle there is no torque generated by that force. The backwards force exerted by the turntable to the contact patch of the wheel creates a torque force that is used to drive the propeller. Since the propeller pitch is less than the wheel circumference, the thrust speed is reduced, but the thrust force is increased by the effective reduction in gearing. In this case the prop geometrically advances 6" per revolution, while the wheel advances 10.5" per revolution, a geometric advance ratio of 6/10.5.
Using the cart as the frame of reference, when the turntable spins up, the cart experiences a negative ground speed and a positive air speed. The thrust from the prop resists the positive air speed and the cart accelerates forwards. Eventually the cart reaches the point where there is a negative ground speed and zero relative air speed, but at this point the prop is generating a large amount of thrust at a very slow speed, enough to keep the cart accelerating forwards. Eventually, the apparent wind becomes a headwind, negative air speed, and this reduces the thrust from the prop at a given rpm. As the cart speeds up, the thrust speed increases at a lower rate than the ground and apparent wind speed and eventually stops accelerating when the thrust equals the overall drag.
  • #95
schroder said:
This is not a driving wheel. It is, in actual fact, a driven wheel. It is a source of drag, not thrust and it cannot be a source of thrust at the same time it is a source of drag.
The wheel is indeed a source of drag or better stated, the ground exerts a backwards force at the point of contact of the wheel, opposing forward motion. However, this backwards force times the radius of the wheel equals the torque applied to the wheel. The wheel in turn transfers this torque to the propeller, and it's the propeller that generates the thrust. Because of the effective gearing (advance ratio), the torque is multiplied and the speed divided. The propeller generates more thrust than the force from the wheel, but at a much lower speed. The power output (thust times air speed) is less than power input (drag force times ground speed), but the force from the prop is higher than the force from the ground with enough left over to compensate for the other drag factors.
Again, a realtive tailwind is required for this to work, since the reduction in speed would render the prop usless unless the apparent wind is significantly slower than the ground speed. As stated before when the cart is moving at the same speed as the wind, then the apparent wind is zero, the prop is generating all of the induced wind and thrust, and the ground is opposing this thrust, most of it going to the driven wheel, creating a torque on that wheel, which transfers the torque to the propeller, which generates a higher thrust at a lower speed because of the advance ratio.
As an example of the effective gearing, imagine someone standing on the bottom pedal on a 10 speed bicycle in high gear. How much force would it take another person to push the bike forwards, which would raise the riders center of mass by the diameter of the pedals? It would only take a fraction of the persons weight to do this. The force from the person would be opposed by a backwards force from the ground, creating a torque on the driven wheel, and this torque would be multiplied while the angular speed was divided at the pedals. Even if the gearing was 1:1, the fact that the pedals have a smaller diameter than the wheel would still result in a higher force at the pedals than at the wheel because of the smaller radius of the pedals versus the wheel (even though the torque would be the same). It's the angular equivalent of a lever.
  • #96
I think what you are confusing is the word "friction" which means somehow "power dissipation" to you. But the friction here is just a mechanical binding, it is (ideally) not dissipative. As such, you could, instead of a "friction wheel" consider a dented wheel on a dented "floor" and then you see maybe more the mechanical side of it.
This is not a "free energy" machine or anything. Consider the following: consider, instead of having air in the original experiment of the OP, a static "turntable" above the turning turntable, all that in a vacuum. So we now have a spinning disk, and above that, a fixed disk. The fixed disk is a "replacement" for the static air. It is perfectly possible to design a cart between both wheels (the fixed one and the turning one) such that it does exactly the same as the propeller-driven cart, by having a wheel on the top (static) disk, another wheel on the bottom (turning) disk, and gears linking both. Indeed, it is sufficient that the gears impose a certain ratio of speed between the top wheel and the bottom wheel and you can make it go any speed. If the ratio is -1, (that is, the top wheel will run just as fast as the bottom wheel, but in the opposite direction), then the cart will run at half the speed of the turning disk. If the ratio is 1, the system will be blocked (there's no possible motion from the cart for which the top wheel and the bottom wheel will have exactly the same speed in the reference frame of the cart). If the ratio is 0, then the cart will remain fixed in space. If the ratio is 1/2, however, the cart will run at the same speed as the lower wheel, but in the opposite direction (indeed, from the cart's PoV, both wheels go forward, but the bottom one twice as fast as the top one, satisfying its gearing ratio).
By playing with the gearing ratio, you can obtain about any motion you want.
Now, think of the static air mass as playing more or less the role of the static wheel. There's no reason why things now become impossible.
This is comparable to the way you can roll up a wire on a wheel by pulling the wire and the wheel towards you. If the diameter on which you wind up the wire is smaller than the diameter of the wheel which rolls on the floor, then the wheel will come faster towards you than that you are pulling the wire towards you, and the wheel will actually wind up the wire around it - see attachment.
Edit: I also added a rough sketch of the cart between two turntables...
  • #97
So, an apparent tailwind is required for this to work, your words, not mine. And when the cart is moving at the same speed as the wind, the apparent wind is zero. Now you say the prop is inducing all the wind and thrust, but it is the torque on the wheel, transferred to the propeller, which powers the prop. There is no wind pushing the cart, it is zero. And yet something is still turning that wheel, which is turning that propeller which is powering the cart. That is perpetual motion Jeff. There is no other way to describe it. I can't believe you really believe in this.
  • #98
If you are inclined to argue some stance that is beyond my recognition, please give a clear one. This requires a clear statement of what you think is fact, and some sound motivation for it. I'll not participate in any more bickering beyond this.
  • #99
Are we talking about "ideal" mathematical abstractions or about a real mechanical device on a real turntable? Friction is always dissipative and while it is conserved (as heat) it is not mechanically conserved. It will slow the cart down, never speed it up!
  • #100
Phrak said:
If you are inclined to argue this stance, please give a clear one. I'll not participate in any more bickering beyond this. Take your time. Please, take your time.
I believe my stance is very clear and is based upon established physics. Your stance is not at all clear.
  • #101
I was just wondering if this would work for linear movement with linear wind. The the only difference seems to be, that here the simulated wind at the propeller is much faster then at the wheel.
  • #102
Binding friction is not dissipative. As I said, if this confuses you, consider it to be a dented wheel on a dented turntable.
  • #103
This is absolutely not perpetual motion, not any more than the little car between a static and a turning wheel is (see my previous post).
What you have is that there is a mechanical binding between the cart and the turntable on one hand (given by the wheel on the turntable), and there's another "binding" between the propeller and the air mass, and there is a mechanical link between both. For a certain RPM of the wheel on the table, a certain RPM of the propeller is set, and this, in turn, gives a certain force on the cart. There will be a balance between the power taken or given by the wheel on the table, and the power taken or given by the propeller. The cart will settle in that motion when both are in equilibrium, and that equilibrium is given by the equivalent of a gearing ratio (including, in this case, the efficiency of the propeller).
  • #104
Yes, but in fact it is not the simulated wind at the back of the propeller which is driving this. It is the wheel turning on the table, and powering the prop via a cable. This does not demonstrate a down wind vehicle at all! If the inventor will do the test I proposed, by running the device with the cable disconnected, the wind created will turn the prop in the other direction, as a turbine, not a propeller. If the cable were to be connected in the same way, and this device were in a wind tunnel, with the table stationary, it would in fact attempt to move upwind, not downwind! A simple test with an electric fan will prove this. But it will only try to move upwind, the fan will push it back slowly. What is happening here is an upwind configured device is being powered by the wheels to try and prove DDWFTTW, which is silly. If you want to test this as a true downwind device, disconnect the cable and connect it to the other side of the wheel and run it again. It will try to go downwind, but considerably less that the table speed. We can try all these tets if the owner/inventer is willing to discover the truth of the matter.
  • #105
schroder said:
When the cart is moving at the same speed as the wind, the apparent wind is zero. Now you say the prop is inducing all the wind and thrust, but it is the torque on the wheel, transferred to the propeller, which powers the prop. There is no wind pushing the cart, it is zero.
I didn't state that. The prop is generating the wind and thrust that pushes the cart. The torque required to drive the prop coexists with a torque on the driven wheel, and the wheel exerting a forwards force on the ground, which reacts with an equal and opposite force on to the wheel. However at the point of application of force from the ground the speed involved is much higher than the induced wash from the prop, and this effectively multiplies the power (force times speed), which is the "clever way" that the DDWFTTW cart takes advantage of the difference between wind speed and ground speed.
So ultimately, the difference between wind speed and ground speed create a situation where opposing forces correspond to differing amounts of power, more power obtained from the wheel + ground interface than consumed by prop + air interface, providing enough excess power to enable the cart to go DDWFTTW.
<h2>1. What is the DDWFTTW Turntable Test?</h2><p>The DDWFTTW Turntable Test is a scientific experiment that aims to test the validity of the controversial "Double-Dark Warp Field Theory" proposed by physicist Harold White. It involves spinning a turntable at high speeds while measuring the weight of an object placed on it, in an attempt to detect any changes in weight that could indicate a warp field.</p><h2>2. What is the purpose of the 5-minute video?</h2><p>The 5-minute video is a condensed version of the full DDWFTTW Turntable Test, which can last up to 3 hours. It is meant to provide a quick overview of the experiment and its results, making it more accessible to a wider audience.</p><h2>3. Is the 5-minute video conclusive?</h2><p>The 5-minute video is not meant to be a conclusive proof of the Double-Dark Warp Field Theory. It is simply a demonstration of the experiment and its findings, which can then be further analyzed and studied by the scientific community.</p><h2>4. What were the results of the DDWFTTW Turntable Test?</h2><p>The results of the DDWFTTW Turntable Test showed a small but consistent decrease in the weight of the object placed on the spinning turntable. While this could potentially be attributed to a warp field, further research and testing is needed to confirm this hypothesis.</p><h2>5. What are the implications of the DDWFTTW Turntable Test?</h2><p>If the results of the DDWFTTW Turntable Test are confirmed by further experiments, it could have significant implications for our understanding of space-time and the possibility of faster-than-light travel. It could also potentially lead to new technologies and advancements in space exploration.</p>
  • Other Physics Topics
11K
10K
27K
  • Astronomy and Astrophysics
  • Math Proof Training and Practice
