Homework Help: DE general solution
  1. Aug 4, 2010 #1
    [itex]y' = \frac{y+y^2}{x+x^2}[/itex]
    2. Relevant equations
    separation of variables
    3. The attempt at a solution
    I start with
    which is
    [itex]\frac{dy}{dx} = \frac{y+y^2}{x+x^2}[/itex]
    next step is
    [itex]dy = \frac{y+y^2}{x+x^2}dx[/itex]
    than I divide both sides by [itex]y+y^2[/itex]
    so gives
    [itex]\frac{dy}{y+y^2} = \frac{1}{x+x^2}dx[/itex]
    so then I integrate both sides.
    [itex]\int\frac{dy}{y+y^2} = \int\frac{1}{x+x^2}dx[/itex]
    which gives
    [itex]ln\right[\frac{\mid y\mid}{\mid y+1\mid}\left][/itex]=[itex]ln\right[\frac{\mid x\mid}{\mid x+1\mid}\left][/itex]
    Is this right so far?
  3. Aug 4, 2010 #2
    vela
    Staff Emeritus
    Education Advisor
    Don't forget the arbitrary constant.
  4. Aug 5, 2010 #3
    Sorry,
    [itex] ln\left[\frac{\mid y\mid}{\mid y+1\mid}+ C \right][/itex] = [itex]ln\left[\frac{\mid x\mid}{\mid x+1\mid}+C \right][/itex]
    I now multiply both sides by [itex]\mid y+1\mid[/itex]
    [itex]
    ln\left[\frac{\mid y+1\mid \mid y\mid}{\mid y+1\mid} \right]
    [/itex] = [itex]
    ln\left[\frac{\mid y+1\mid \mid x\mid}{\mid x+1\mid}+ C \mid y+1\mid \right]
    [/itex]
  5. Aug 5, 2010 #4
    Divide by |y+1| Equals
    [itex]
    ln\left y \right]
    [/itex] = [itex]
    ln\left[\frac{\mid x\mid}{\mid x+1\mid}\right]
    [/itex]
  6. Aug 5, 2010 #5
    Do I then take the inverse log to make
    [itex]y = \frac{\mid x\mid}{\mid x+1\mid} + C [/itex]
  7. Aug 5, 2010 #6
    How did you knew straight away that the integral of 1/(x+x^2) is ln(|x/(x+1)|) ?
  8. Aug 5, 2010 #7
    vela
    Staff Emeritus
    Education Advisor
    Not quite. You can combine the two arbitrary constants into one to get
    [tex]\log \left|\frac{y}{y+1}\right| = \log \left|\frac{x}{x+1}\right| + c[/tex]
    Now take the inverse log.
  9. Aug 5, 2010 #8
    Char. Limit
    No, not yet...
    You need a log(A) = log(B), but you have a log(A)=log(B)+C. So, say C=log(D), then say that log(B)+log(D)=log(BD), then your equation can be inverse logged. But not before.
  10. Aug 5, 2010 #9
    vela
    Staff Emeritus
    Education Advisor
    Sure it can.
    log A = log B + c
    → elog A = elog B + c = elog Bec
    → A = Bec
  11. Aug 5, 2010 #10
    Char. Limit
    Good point. I just feel it's easier for me if I do it my way.
  12. Aug 5, 2010 #11
    log A = log B + c
    → A = Bec
    So i've got
    So i take the inverse log of both sides
    [tex]e^{\log \left|\frac{y}{y+1}\right|} = e^\log \left|\frac{x}{x+1}\right| + c}[/tex]
    [tex]e^{\log \left|\frac{y}{y+1}\right|} = e^\log \left|\frac{x}{x+1}\right|} e^c[/tex]
    in turn gives
    [tex]\left|\frac{y}{y+1}\right|} = \left|\frac{x}{x+1}\right|}e^c[/tex]
    How do I get rid of the [tex]y+1[/tex] in the dinominator of LHS?
  13. Aug 5, 2010 #12
    Char. Limit
    First, make some restrictions on x so you can lose the absolute values, then multiply both sides by y+1. You can solve for y from there.
  14. Aug 5, 2010 #13
    muitiply both sides by [tex]y+1[/tex] for [tex]x \neq 0[/tex]
    gives
    [tex]y= \frac{x(y+1)e^c}{x+1}[/tex]
    I keep rearranging but I can't seem to get the (y+1) out of the RHS it just seems to be changing sides
  15. Aug 5, 2010 #14
    vela
    Staff Emeritus
    Education Advisor
    First, to get rid of the absolute values, recall that |a|=|b| means a=±b.
    Second, assume x≠0 and y≠0 for the moment. If you take the reciprocal of both sides, you get
    [tex]\left|1+\frac{1}{y}\right| = e^{-c}\left|1+\frac{1}{x}\right|[/tex]
    Can you see where to go from there?
  16. Aug 5, 2010 #15
    Using that |a|=|b| means a=±b.
    becomes
    [tex]\frac{-(y+1)e^{-c}}{y}) = \frac{-(y-1)e^{-c}}{y}) [/tex]
    so
    [tex](-e^{-c}+\frac{-1}{y}) = (-e^{-c}-\frac{-1}{y})[/tex]
    is that right so far
  17. Aug 5, 2010 #16
    vela
    Staff Emeritus
    Education Advisor
    Nope. Check your algebra.
  18. Aug 5, 2010 #17
    becomes
    [tex]\frac{-(y+1)e^{-c}}{y} = \frac{-(y-1)e^{-c}}{y} [/tex]
    so
    [tex]\frac{-(y+1)e^{-C)}{y}) = \frac{-(y-1)e^{-C)}{y}) [/tex]
  19. Aug 5, 2010 #18
    I mean,
    [tex]\frac{-(y+1)e^{-C)}{y} = \frac{-(y-1)e^{-C}{y}[/tex]
  20. Aug 5, 2010 #19
    [tex]\frac{-(y+1)e^{-C}}{y} = \frac{-(y-1)e^{-C}}{y}[/tex]
  21. Aug 5, 2010 #20
    i s that better
    [itex]\frac{-(y+1)e^{-C}}{y} = \frac{-(y-1)e^{-C}}{y}[/itex]
  22. Aug 5, 2010 #21
    vela
    Staff Emeritus
    Education Advisor
    I'm not sure what you're doing. The exponential is always positive so you can pull it inside the absolute value to get
    [tex]\left|1+\frac{1}{y}\right| = \left| e^{-c}\left(1+\frac{1}{x}\right)\right|[/tex]
    So you have |a|=|b| where
    [tex]a= 1+\frac{1}{y}[/tex]
    [tex]b = e^{-c}\left(1+\frac{1}{x}\right)[/tex]
    Try taking it from there.
  23. Aug 7, 2010 #22
    How this look?
    [tex]\left|1+\frac{1}{y}\right| = e^{-c}-(1+\frac{1}{x}) = e^{-c}-1-\frac{1}{x}[/tex]
    or
    [tex]1+\frac{1}{y} = e^{-c} 1+\frac{1}{x}[/tex]
  24. Aug 8, 2010 #23
    What I was trying to do was something I remembered when working with absolute values on both sides of the equation. which was that there could be two solutions depending on + or -.
    So I thought there might be more then 1 solution.
    So using what I've got.
    take 1 from both sides.
    [tex]\frac{1}{y}\ = e^{-c}\left(1+\frac{1}{x}\right)-1[/tex]
    Take reciprocal of both sides
    [tex]\frac{y}{1}\ = \frac{1}{e^{-c}\left(1+\frac{1}{x}\right)-1}[/tex]
    [tex]y = \frac{-xe^{c}}{x(e^c-1)-1}[/tex]
