Deadhang Equation - Improve Finger Strength in Rock Climbing
  • Thread starter electerr
In summary, the rock climber is trying to find a way to measure the progress of their training by using an equation that includes the weight, area of contact, and hang time. They are trying to find a way to represent all of these factors together into one value.
electerr
28
Hi,
I am working on a small project and am hoping to get some outside insight from anyone who has the time or interest...
One of my hobbies is rock climbing and because I am quite fanatic about it I train for it quite regularly. One of the methods commonly used for training is called 'dead hanging' which is used to improve finger strength. It involves hanging from a wooden on plastic edge, of various sizes (grip types), for various lengths of time. See pic...
http://www.urbanclimbermag.com/themag/workshop/workshop_-_26_-_hang_time/
I always keep track of my training including the grip type and hang times and am now trying to put my (elementary) physics knowledge to work and represent all the factors going into the dead hang into one value by forming or using a equation or set of equations so that it will be easier to track my progress.
As you can see the 3 factors are weight, area of contact, and hang time.
I first thought that I could use a torque equation (r1*F1=r2*F2) to measure the opposing forces using my finger joint as the axes point but quickly realized that I could not include the area factor if I used this reasoning (i.e. if I hang by 4 fingers or two fingers the resulting number would be the same).
Then I thought that I could use a pressure equation (m*g/area=P) which includes the area and weight (mg) but then couldn't figure out how to incorporate the time of the hang. I tried (mg)/area/time but that didn't really seem right.
In the end I ended up making my own equation mass*g*time/area which gives me a number value that represents the difficulty of a hang in relation with the difficulty of another hang but I am not really satisfied with that for several reasons. I want to be able to compare the difficulty of a hang with other things as well and would like to find a way to convert or rearrange a established physics equation or set of equations to represent all of the difficulty factors with the result being in, for instance, Newton or watts or some other established measurement. Is there anyone who can help me to do this or should I just be satisfied with the equation that I worked out?
Thanks in advance
Elect...Seems like one additional variable you likely need is torque...Ever hang vertically on a pair of still rings in gymnastics? Then try the "extension with arms out horizontally?? Notice a BIG difference, right??
Same idea for your fingers...a right angle at any of your knucles will be a lot harder hang than if they are bent further and so the knuckle is curled up and the angle greater than ninety degrees...and the "extension" reduced...
How about friction at the grip point...type surface, sweaty hands, shape and angle of the grip surface...
good luck, not an easy modeling project...but interesting application of physics...
You are right about the friction part...
We use powdered chalk to improve the 'grip' that we get when climbing or in this instance dead hanging but temperature does still play a role but it is a factor that is too complex for me to calculate accurately but I’d be more than welcome to hear ideas of how it could work...
Any advice on how to work the other factors (area and time) into the torque equation?
Torque is force times distance. so a horizontally extended finger of 1" takes twice the force of one extended only 1/2"...but I have not the slightest idea how a living body reacts to the expenditure of "work"...is the first minute of exercise burning calories at the same rate as the last minute a few hours later?? Once muscles become "tired" it subjectively seems to take more effort but whether that's psychological or physiological or both...I don't know...
Yes, I understand that torque is force x distance and that the answer comes in the form of Nm and if I were going to use the torque equation in my situation then I also must be able to take the answer from the equation (X Nm) and put it into another equation that considers the area and time factors because 5 fingers under a certain amount of torque is not the same as 2 fingers under the same amount of torque. Furthermore, holding that position for 5sec or 2min is not the same either...
Yes, the more tired you get the harder it is for you to hold on but the required force to hold on is the same or...? If instead of it being a person holding on it was a machine with a mechanical finger and a certain weight it would take a certain amount of energy or force for that machine to hold on to a certain grip area, for a certain amount of time with it’s set weight and that should (some way) be able to be measured. This is what I am interested in, a equation taking these three factors (weight, area, time) into account...
1. How does the Deadhang Equation improve finger strength in rock climbing?
The Deadhang Equation is a training method that involves hanging from a climbing hold for a set amount of time. This exercise targets the muscles and tendons in the fingers, wrists, and forearms, which are crucial for rock climbing. By consistently practicing the Deadhang Equation, climbers can increase their finger strength, allowing them to hold onto smaller and more challenging holds on the rock.
2. What is the recommended duration for a Deadhang hang?
The recommended duration for a Deadhang hang varies depending on the climber's level of strength and experience. Beginners may start with shorter hangs, such as 10-15 seconds, while more advanced climbers can aim for longer hangs, up to 30 seconds or more. It is important to gradually increase the duration of the hang to avoid injury.
3. Can the Deadhang Equation lead to injury?
Like any training method, it is possible to injure oneself while practicing the Deadhang Equation. It is crucial to follow proper form and not overexert oneself, especially when starting out. It is also essential to listen to your body and take breaks when needed. If done correctly, the Deadhang Equation can significantly improve finger strength without causing injury.
4. Is the Deadhang Equation suitable for all climbers?
The Deadhang Equation can be beneficial for all climbers, from beginners to advanced. However, it is crucial to have a solid foundation in basic climbing techniques before incorporating the Deadhang Equation into a training routine. Additionally, those with pre-existing finger, wrist, or forearm injuries should consult a doctor before attempting this exercise.
5. How often should the Deadhang Equation be practiced?
The frequency of practicing the Deadhang Equation depends on the individual's training schedule and goals. Generally, it is recommended to incorporate the exercise 2-3 times a week, with rest days in between. It is essential to allow the fingers, wrists, and forearms to recover between sessions to avoid injury and see progress.
  • Other Physics Topics
  • Quantum Physics
  • Materials and Chemical Engineering
