Dealing With a Summation
  • Thread starter FredGarvin
FredGarvin
Hey guys and gals,
While this technically isn't homework, I figured this is the place to post.
I am working over a problem and I am at a point in the solution that has me a bit stumped. Perhaps someone may provide some guidance.
In acoustics, we run into the problem of a radiating body in cylindrical coordinates. Essentially, after a bit of work, I have come to the point where I am stuck in equating a body's radial velocity and the radial derivative of the velocity potential. What I have is:
[tex]C cos(\theta) = \sum_{n=0}^\infty A_n \left(\frac{\omega}{a_o} \right) H_{n+1}^{(1)} \left(\frac{\omega}{a_o} R\right) cos(n \theta)[/tex]
Where C is a constant, An is what I am trying to solve for, and H is the Hankel function of the first kind.
Now, normally I don't have both sides as a function of theta and the solving for An is pretty straight forward. However, this time it is not the case. Is there a way to somehow come up with a general solution to An that does not include the summation? I'm thinking no, but I figured I'd ask.
Thanks!
Answers and Replies
lanedance
3,304
could you do the fourier type approach & mutiply both side by [itex] cos(m\theta) [/itex] then integrate over theta?
FredGarvin
I am not seeing what that will do if I multiply by [tex]cos (m \theta)[/tex]. Can you elaborate a bit more on that? Thanks!
lanedance
3,304
could be missing something/oversimplifying, but here's what i was thinking... directly along the lines of how you determine the fourier co-efficients
so if i'm getting it correctly, for the purpose of evaluating the An constants, the hankel functions are effectively just a constant evaluated at the boundary r = R, so write the total coefficient as Bn for now:
[tex]C cos(\theta) = \sum_{n=0}^\infty B_n cos(n \theta)[/tex]
now, if the terms of the sum were something more like [itex] cos(n\pi \theta) [/itex], then multiplying by [itex] cos(m\pi \theta)[/itex], and integrating you get:
[tex]C \int cos(m\pi \theta) cos(\pi \theta) = \sum_{n=0}^\infty B_n \int cos(\pi n \theta)cos(m\pi \theta) [/tex]
which will cancel out pretty simply due to the orthogonal nature of the cos functions...
so maybe you can find a similar approach...
though its been a while since i done any of these, & that was only really in SL type problems & so some issues i could see:
- if the n aren't nice integers or have a clear integer difference type relationship (no longer othogonal..? is there another orthogonal set?)
- and if any of the hankel functions had zeroes at the boundary
Related Threads on Dealing With a Summation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
