DeBroglie Wavelength: Proton at Room Temp Scattering Behavior
In summary, two protons with low energy and large deBroglie wavelength will scatter as small hard particles with a size of about 1 fermi. The distance of closest approach for these particles is approximately 2A, meaning they will not interpenetrate if we assume they are each 0.7A. The distribution of a room temperature proton is not 100% within 1 deBroglie wavelength, as there is a tail to the distribution that may affect the scattering. The correct distance of closest approach for a potential energy of 0.05 eV is about 290 Å. There may be confusion between the use of "V" to refer to potential (volts) in classical electromagnetism and
edpell
282
A proton at room temperature with an energy of 0.025eV has a deBroglie wavelength of about 1A (1E-10 meters). If we shoot two proton beams at each other with is low energy and large wavelength what happens? Do they scatter as if they are small hard particles of size about 1 fermi (1E-15 meters) or do they scatter as if they are big fuzzballs of size about 1A?
It might be instructive to consider the two protons as classical particles and find the distance of closest approach: the distance at which the Coulomb potential energy equals their total initial kinetic energy.
About 2A. So if we say they are each 0.7A they never interpenetrate.
Is this correct? How do we think about the distribution of a room temperature proton? Is it 100% within 1 deBroglie wavelength? Is there a tail to the distribution so we might see an effect in the scattering?
Check your math. I get r = about 290 Å for a potential energy of 0.05 eV (8 x 10-21 J)
$$PE = \frac{q^2}{4 \pi \epsilon_0 r}$$
I think it is
$$PE = \frac{q}{4 \pi \epsilon_0 r}$$
The electric potential V (in volts, in MKS units) at a distance r from a charge q is given by your formula.
When you put a second charge q2 at that location, the electric potential energy of the system (in joules, in MKS units) is given by PE = q2V. When the two charges are equal in magnitude (q2 = q) this leads to my formula.
Unfortunately, in classical electromagnetism, we usually use V to refer to potential (volts), whereas in QM we often use V to refer to potential energy (joules or electron-volts), which causes confusion.
1. What is the DeBroglie wavelength of a proton at room temperature?
The DeBroglie wavelength of a proton at room temperature is approximately 1.7 x 10^-15 meters.
2. How is the DeBroglie wavelength of a proton at room temperature calculated?
The DeBroglie wavelength of a proton at room temperature can be calculated using the equation λ = h/mv, where λ is the wavelength, h is Planck's constant, m is the mass of the proton, and v is the velocity of the proton.
3. What is the significance of the DeBroglie wavelength in proton scattering behavior?
The DeBroglie wavelength is significant in proton scattering behavior because it determines the probability of a proton interacting with another particle or object. A smaller DeBroglie wavelength means a higher probability of scattering.
4. How does the DeBroglie wavelength of a proton at room temperature affect its scattering behavior?
The DeBroglie wavelength affects the scattering behavior of a proton by determining the range of angles at which the proton can scatter. A smaller DeBroglie wavelength means a wider range of scattering angles.
5. Can the DeBroglie wavelength of a proton at room temperature be observed or measured?
Yes, the DeBroglie wavelength of a proton at room temperature can be observed and measured through experiments, such as diffraction or interference experiments. It can also be calculated using the aforementioned equation.
  • Quantum Physics
