Debugging VBA in Excel.
  • Thread starter jsbxd9
jsbxd9
Hello all. I am trying to get my code to color cells if a referenced cell is populated. That part works but when I tried to populate another cell a different color I encountered a problem. You can see where the mistake comes in on the code. It is when I try to populate a variable 'strMyVar' with an offset property. I have underlined where I am having the problem. Any suggestions?
Sub colorcells()
Dim x, n, y, i As Double
Dim strMyVal As String
For n = 1 To 3000
Cells(n, 1).Activate
If Cells(n, 1) <> ("") Then
For x = 1 To 7
If x < 7 Then
Cells(n, x).Activate
ActiveCell.Interior.Color = RGB(252, 213, 180)
End If
If x >= 7 Then
strMyVal = ActiveCell.Offset(-3, 0).Value
If strMyVal <> ("") Then
ActiveCell.Interior.Color = RGB(255, 255, 153)
End If
End If
Next x
x = 1
End If
Next n
End Sub
Answers and Replies
Borg
3,183
Code:
Sub colorcells()
For n = 1 To 3000
        For x = 1 To 7
            If x < 7 Then
            End If
            If x >= 7 Then
                [U]strMyVal = ActiveCell.Offset(-3, 0).Value[/U]
                    End If
            End If
        Next x
        x = 1
    End If
Next n
End Sub
I wrapped CODE tags around your code so that it would stay formatted. It's been a long time since I've coded anything in VBA but the first thing that jumps out at me is the question of whether ActiveCell.Offset(-3, 0) is ever null. If so, attempting to retrieve value from a null object will break.
chiro
134
Following on from what Borg mentioned above, can you first check that your object being referenced exists?
What is the ActiveCell object structure and what are the valid values for the offset index parameter?
hotvette
997
The problem is you are trying to address a cell with a negative row number. If you put a debug print statement in your code like the below, you'll see that the active cell is $G$1 just before the error. The offset operation tries to address a negative row value, which is illegal.
Code:
Debug.Print ActiveCell.Address
jsbxd9
Thanks for all the input. Very helpful. I am not a programmer just an engineer trying to make my job a little easier.
Hotvette, how should I reference a cell to the left of an active cell??
hotvette
997
For the offset method (should be documented in VBA help), the first parameter is row offset and the 2nd is column offset:
Code:
strMyVal = ActiveCell.Offset(0, -1).Value   'cell on immediate left of active cell
strMyVal = ActiveCell.Offset(0, 1).Value    'cell on immediate right of active cell
strMyVal = ActiveCell.Offset(-1, 0).Value   'cell immediately above the active cell
strMyVal = ActiveCell.Offset(1, 0).Value    'cell immediately below the active cell
Suggested for: Debugging VBA in Excel.
  • Last Post
  • Last Post
  • Last Post
  • Last Post
54K
  • Last Post
  • Last Post
