Which force causes decay in resonance states?
In summary, the conversation discusses determining the force responsible for a decay of a resonance state. It is suggested that the strong interaction may be involved due to the use of the word "resonance" and the specific particle and decay being looked at. Additionally, the broad width of the resonance and the occurrence of another observed decay involving the electromagnetic interaction provide further clues.
Hypersquare
Hey now!
I have just calculated the lifetime of a resonance state using its total width. I want to work out which force this decay is due to. How would one go about doing this?
Thanks
To know the interaction responsible for a particular decay you have to know what the decay is, i.e. what particle(s) the particle you're looking decays into. One particle can decay in many different ways. However, since you use the word "resonance", this might be a hint that the decay is due to the strong interaction, since this is usually part of what one means by the word "resonance".
What is the specific particle and decay you're looking at?
Thanks fo the response Kloptok!
No such information is given. I am just told that the total width of delta 1232 resonance i 118 Mev.
http://pdglive.lbl.gov/Rsummary.brl?nodein=B033&inscript=Y&sub=Yr&return=BXXX010
The dominant decay is (uud) -> (udd) + (u anti-d)
No quark flavour changes are involved, therefore it can occur via the strong interaction. The broad width of the resonance is another sign of this.
Another observed decay is delta1232 -> p gamma. As you can see from the photon, the electromagnetic interaction is involved.
You can find ideas here.
1. What is decay due to which force?
Decay due to which force refers to the gradual breakdown or disintegration of a structure or substance as a result of a particular force or set of forces acting upon it. This can include physical, chemical, or biological forces.
2. What are some common examples of decay due to which force?
Some common examples of decay due to which force include rusting of metal due to exposure to oxygen and moisture, decomposition of organic matter by bacteria and fungi, and erosion of rocks and soil by wind and water.
3. How does decay due to which force occur?
Decay due to which force occurs when the forces acting upon a substance are stronger than the forces holding it together. This can lead to the breaking down of chemical bonds, physical wear and tear, or disruption of biological processes.
4. What are the effects of decay due to which force?
The effects of decay due to which force can vary depending on the substance and the force involved. In some cases, it can lead to structural damage or failure, loss of function, or changes in appearance. In other cases, it can be a natural part of the life cycle, such as in the decomposition of organic matter.
5. How can we prevent or slow down decay due to which force?
There are various ways to prevent or slow down decay due to which force depending on the specific situation. This can include regular maintenance and repairs, using protective coatings or materials, controlling environmental factors, and developing strategies to mitigate the effects of decay. In some cases, it may also be possible to reverse or repair the damage caused by decay.
