Decay of Excited Atoms: Probability & Nonlinearity
In summary, the probability of radioactive decay for an atom is always the same, however the decay of and excited atom or electron is governed by a nonlinear decay probability.
Trollfaz
137
I learned that the probability of radioactive decay for an atom is always the same. However, is the decay of and excited atom or electron non linear(decay probability varies with time)?
Radioactive decay is governed by the exponential law $$N(t)=N_0e^{-\lambda t}$$ where [itex]N_0[/itex] denotes the number of nuclei at [itex]t=0[/itex] , and [itex]\lambda[/itex] is the decay constant which is different for different nuclei. If you use the word "probability of radioactive decay" for "rate of radioactive decay" it is not same for all nuclei. In case of radioactive decay too, the decay rate [itex]\frac{dN}{dt}[/itex] also varies with time in a nonlinear fashion.
In presence of the environment, the eigenstates of the atomic Hamiltonian are not true eigenstates of nature. Therefore, each atomic level has a certain lifetime [itex]\tau[/itex] which depends upon the interaction it is subjected to. In general, a single atom continues to make transitions between the atomic energy levels.
I mean is decay of excited atoms or electrons governed by the exponential law too?
The probability that an existing atom will decay within the next second is always the same.
If you follow a speific atom, the probability that it exists (in the original state) goes down over time - because it might have decayed. That means the probability that you observe the decay after X seconds is smaller than the probability that you observe it after Y seconds if X>Y.Every radioactive decay follows an exponential decay.
There are no excited electrons. Excited atoms exist, and if you don't influence them from the outside, they will decay exponentially.
Likes stoomart
If at any instant of time all the atoms are excited to the higher energy level i.e., a population inversion is achieved, it will eventually relax back to a Boltzmann distribution in presence of a temperature bath.
1. What is the decay rate of excited atoms?
The decay rate of excited atoms refers to the rate at which an excited atom transitions back to its ground state and releases energy in the form of light or heat. This rate is typically measured in units of inverse seconds and is dependent on factors such as the type of atom, its energy level, and any external influences.
2. How is the probability of decay calculated?
The probability of decay for an excited atom is determined by its half-life, which is the amount of time it takes for half of the atoms in a sample to decay. This probability can be calculated using a mathematical equation that takes into account the decay rate, the number of atoms present, and the amount of time that has passed.
3. What is the role of nonlinearity in the decay of excited atoms?
Nonlinearity refers to the fact that the decay rate of excited atoms is not constant over time. As more and more atoms decay, the probability of further decay decreases, resulting in a nonlinear decay curve. This nonlinearity can be influenced by various factors such as the presence of other particles or the temperature of the environment.
4. How does the decay of excited atoms impact the stability of a substance?
The decay of excited atoms can have a significant impact on the stability of a substance. As atoms decay, they release energy that can cause changes in the chemical and physical properties of the substance. This can lead to changes in phase, such as from solid to liquid, and can also affect the reactivity and durability of the substance.
5. Can the decay of excited atoms be controlled or manipulated?
In some cases, the decay of excited atoms can be controlled or manipulated through various methods. For example, scientists can use external influences such as temperature, pressure, or the presence of other particles to alter the decay rate of atoms. This can be useful in areas such as nuclear energy, where controlling the rate of decay is crucial for safety and efficiency.
