Define a relation
Mathematicsresear
66
a relation R⊆ℝ2
It is defined if and only if a2+b2=c2+d2 where (a,b) ∧ (c,d)∈ℝ2
Find all equivalence classes
I said that the following set defines an equivalence class for the above problem:
[/B]
[(a,b)] = {(c,d)∈ℝ2 : ((a,b),(c,d))∈R}⊆ℝ2
so I asked myself when is a2+b2=c2+d2 such that (a,b) and (c,d) are elements of the relation and a subset of ℝ2.
I said when d= sqrt(a2+b2-c2) and a2+b2 > c2
I am not sure what to do next.
Answers and Replies
Mathematicsresear
66
I thought about using the theorem of Thales.
Please elaborate
fresh_42
Mentor
Insights Author
2022 Award
17,826
19,064
##a^2+b^2=h^2## are the side lengths of a right triangle, and Thales together with the definition of your equivalence means: all points on the circle with diameter ##h## are equivalent. This reduces the problem to some signs and classes represented by a circle. So the solution has probably to do with concentric circles.
Mathematicsresear
66
Can't I say that the equivalence classes are:
[(a,b)] = {(c,sqrt(a2+b2-c2))∈ℝ2 : a2+b2 > c2 }⊆ℝ2}?
fresh_42
Mentor
Insights Author
2022 Award
17,826
19,064
If then ##\pm \sqrt{}##, but are your classes distinct?
Mathematicsresear
66
I want to describe all possible equivalence classes.
fresh_42
Mentor
Insights Author
2022 Award
17,826
19,064
Given any equivalence relation, ##\mathbb{R}^2## can be written as a disjoint union of the classes. Can you prove this for your classes? In any case you will need the negative roots, too, as ##(c,d) \sim (c,-d)##. Thus you will at least have ##[(a,b)] = \{(c,\sqrt{\ldots}\,\vert \,\ldots\} \cup \{(c,-\sqrt{\ldots}\,\vert \,\ldots\} ##. And what about ##a^2+b^2 =c^2\,?## You basically parameterized the classes by ##h^2=a^2+b^2## which is the same as my concentric circles. And in which class do you have ##(0,0)\,?## For this point there is no ##c##.
In both cases, you will need a formal proof.
Suggested for: Define a relation
  • Last Post
  • Last Post
  • Last Post
