Defining a new kind of derivative
I'm using these notations:
1.$log^n_xy$: For log with the base $x$ applied $n$ times to $y$. For example, $log^3y=log(log(log(y))$ all with the same base.
2.$^{n[x]}a$: For the power tower or repeated exponentiation of $a$ evaluated from right to left such that the number of $a$'s in the operation is $n$ and it has $x$ on the top. For example, $$^{3[5]}2=2^{2^{2^5}}$$, $$^{0[8]}2=8$$ The power tower contains no $2$'s in the second case.
I've defined this new kind of derivative:
$$\lim_{h\rightarrow0}\log_{\frac{log^nx+h}{log^nx}}\frac{log^nf(x+h)}{log^nf(x)}=\frac{dy}{dx}\frac{x}{y}\prod_{k=1}^n\frac{logx}{logy}$$
where $\frac{dy}{dx}$ is the normal derivative of $f(x)$ and all the logarithms whose base is unspecified should be calculated to the the same base $a$.
I've not found any use of this derivative except in approximations, in which it is better than the normal derivative. I've got these approximation results:
By taking the derivative at $n=0$,
$$e^{x_2}\approx e^{x_1}(\frac{x_2}{x_1})^{x_1}$$,
$$x_2^2+x_2\approx (x_1^2+x_1)(\frac{x_2}{x_1})^{\frac{2x_1+1}{x_1+1}}$$
when $\frac{x_2}{x_1}\approx 1$
$$^{(n)[kx]}e\approx ^{(n)[x]}e+\log_{e}k\prod_{i=0}^n{^i[x]}e$$, when $k\approx 1$
$$\frac{\log_ax_2-\log_ax_1}{\log^{n+1}_ax_2-\log^{n+1}_ax_1}*\frac{1}{((ln(a))^n}\approx \prod_{i=1}^nlog_a^ix_1$$, when $\frac{\log_{a}^{n}x_2}{\log_{a}^{n}x_1}\approx 1$
Can these results be proved by using existing maths concepts without using this derivative of mine?
Answers and Replies
12,385
It's difficult to read your notation, and shouldn't the zero in the power lead to a power of ##1##, i.e. ##1## instead of the other number? Have you tried to write this in an old fashioned way? This would make answers more likely.
Related Threads on Defining a new kind of derivative
  • Last Post
13K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
19K
