Is There a Simpler Definition for the Dirac Delta Function?
In summary, the definition of the Dirac Delta function as a functional is often used in physics, and it can be represented by an operator that operates on continuous functions through integration. However, this definition may not be rigorous and does not take into account more advanced concepts such as distribution theory.
Swapnil
459
https://www.physicsforums.com/showthread.php?t=73447
I saw the above tutorial by arildno and looked at how he defined the Dirac Delta "function" as a functional. But isn't there a more easier way to do this. I have seen the following definition in a lot of textbooks.
[tex]\delta(t) \triangleq \lim_{\epsilon \to 0} \frac{1}{\epsilon} \Pi\Big(\frac{t}{\epsilon}\Big)[/tex]
where [tex]\Pi(t)[/tex] is the gate function and is defined as
[tex]
\Pi (t) :=
\begin{cases}
0 & \mbox{ for } |x| > \frac{1}{2} \\
\frac{1}{2} & \mbox{ for } |x| = \frac{1}{2} \\
1 & \mbox{ for } |x| < \frac{1}{2},
\end{cases}
[/tex]
What's wrong by defining the delta function in this way?
Mainly because that limit of real-valued functions does not exist.
However, physics has this weird notational convention that makes everything an operator -- I've never seen anyone try to explicitly state it, but it's evident in how they manipulate different kinds of expressions. When a physicist writes that expression, what they are really writing is the operator pointwise defined as:
[tex]
\delta(t) [ f(t) ] \triangleq \lim_{\epsilon \rightarrow 0}
\frac{1}{\epsilon} \Pi\left( \frac{t}{\epsilon} \right) [ f(t) ]
[/tex]
And since [itex]\Pi[/itex] is representable by an actual function, the latter operator application is an honest-to-goodness integral:
[tex]
\Pi\left( \frac{t}{\epsilon} \right) [ f(t) ] =
\int_{-\infty}^{+\infty} \Pi\left( \frac{t}{\epsilon} \right) f(t) \, dt
[/tex]
Of course, physicists like to write the left-hand side as an integral too, even though it really isn't:
[tex]
\int_{-\infty}^{+\infty} \delta(t) f(t) \, dt \triangleq \delta(t) [ f(t) ]
[/tex]
(unless you get into measure theory, and define [itex]\delta(t) \, dt[/itex] to be a certain measure. But if we did that, then we wouldn't be defining it via the limit expression above!)
Swapnil:
What I tried to do in that tutorial, was to give ONE fairly rigorous way to make sense of the Dirac Delta function.
The aim of the tutorial is just that, and being thus limited, many interesting issues are not at all addressed there. For example, you won't find any evolved, mature distribution theory in it.
[tex]
[/tex]
Just for the record: That's a definition of the operator, right?
[tex]
[/tex]
Where is this coming from? Is it a result of something or is it a definition?
Hrm, good question. Definition, I suppose.
[tex]\delta(t) [ f(t) ] \triangleq \lim_{\epsilon \rightarrow 0}
\frac{1}{\epsilon} \Pi\left( \frac{t}{\epsilon} \right) [ f(t) ][/tex]
[tex]\Pi\left( \frac{t}{\epsilon} \right) [ f(t) ] =
\int_{-\infty}^{+\infty} \Pi\left( \frac{t}{\epsilon} \right) f(t) \, dt[/tex]
So essentially, the delta function can be treated as an operator with the following definition:
\frac{1}{\epsilon} \int_{-\infty}^{+\infty} \Pi\left( \frac{t}{\epsilon} \right) f(t) \, dt[/tex]
right? ( I don't know why you included the definition in two steps.).
Right. And because one typically defines these operators to operate on certain sets of continuous functions, you can show that's equivalent to the simpler definition of delta:
[tex]\delta(t) [ f(t) ] = f(0).[/tex]
1. What is the Dirac Delta Function?
The Dirac Delta Function, denoted as δ(x), is a mathematical function that is defined as zero everywhere except at the origin, where it is infinite. It is often used in physics and engineering to represent a point-like source of energy or mass.
2. How is the Dirac Delta Function defined mathematically?
The Dirac Delta Function is defined as a limit of a sequence of functions. It can be written as δ(x) = limε → 0 1/ε if |x| ≤ ε, and 0 otherwise. In simpler terms, it is a function that is zero everywhere except at x = 0, where it is infinite.
3. What are the properties of the Dirac Delta Function?
Some common properties of the Dirac Delta Function include: δ(x) = 0 for all x ≠ 0, ∫δ(x)dx = 1, and δ(x - a) = δ(a - x). It also follows the sifting property, where ∫f(x)δ(x - a)dx = f(a) for any continuous function f(x).
4. What are some applications of the Dirac Delta Function?
The Dirac Delta Function has various applications in physics and engineering. It is often used to represent point charges in electrostatics, point masses in mechanics, and impulse functions in signal processing. It is also used in solving differential equations, especially in the field of quantum mechanics.
5. Is the Dirac Delta Function a real function?
No, the Dirac Delta Function is not a real function in the traditional sense. It is a mathematical construct that is defined to have certain properties and is often used as a tool in solving problems. It cannot be plotted on a graph, but it is a useful concept in many areas of science and mathematics.
  • Calculus
  • Calculus
  • Calculus
