Defining division by zero?
I assume everyone who saw this thread first rolled their eyes. Sorry for that. My question is an innocent one, as I am completely uneducated in number theory.
My understanding is that numbers are grouped in a sort of Russian doll fashion, with each successive group encompassing all previous ones. I suppose there is an infinite number of ways to define these groups, but the way I order them goes like this:
-Natural numbers
-Rational numbers
-Real numbers
-Complex numbers
Now, since complex number require the special definition of √(-1), could you just define division by zero (arbitrarily, say, as "1/0 = m") and make an even more general number group?
Answers and Replies
Division is the inverse process of multiplication, so if one wants to allow division by zero one would have to accept 0/0 = 1, as 1 is the multiplicative identity. Then, assuming division by zero is valid, one would have to accept the following argument:
1*0 = 0, 2*0 = 0, 0=0 --> 1*0 = 2*0 --> 1*0/0 = 2*0/0 --> 1 = 1*1 = 1*0/0 = 2*0/0 = 2*1 = 2.
What's in a name?
In math, you are free to use whatever definitions you want. But once you choose one, you have to stick with it! You can't change your mind, mid-proof.
Division is a binary operation. An operation is just a function with fancy syntax. So instead of writing x/y, let's write it out in familiar function notation as d(x, y). It's defined on all points in the (x,y) plane except for the line made up of all points where y = 0.
If we want to allow division by zero, all we need to do is "fill in" this line. We can just make up whatever values we want for d(x, 0) for each x. They can be real numbers, or we can create numbers and fit them into the rest of the numeric framework we are creating.
Let's start off with a naive attempt. Let's just say that d(x, 0) = 0 for all x. So division by zero is now defined. Have we succeeded? Well, we can now say that 1/0 = 0. And 2/0 = 0. But by doing this, we implicitly invalidate some theorems we're familiar with. Namely, division is no longer the inverse of multiplication. It's still true that (2 * 3) / 3 = 2, but it's NOT true for all x and y that (x * y) / y = x. Why not? Because that rule would imply (2 * 0) / 0 = 2, when in fact, by our definition, (2 * 0) / 0 = 0. Oops.
And that is the crux of the problem. The minute we define a value for x/0, division is no longer the inverse of multiplication. It can't be, regardless of the value we choose for it. There is a proof of this that isn't that hard to understand, but I'll leave it to you to convince yourself.
As JCVD pointed out division must have its inverse operation to get back to original thing that was divided. Thus n/4 * 4 = n* 4/4 = n * 1 = n. This can be done with zero since zero times anything is zero. Division by [tex]a[/tex] is thus like dividing something into [tex]a[/tex] equal parts that add up to the thing divided. You cant divide by zero since zero equal parts of anything is always zero.
A number group that allows division by zero would be completely useless. On the otherhand, complex numbers have many practical applications, especially in electronics and wave theory.
79
It's hard to tell what might be completely useless in the future. Grassmann numbers were invented in the mid 19th century, but didn't find a use until the 20th century (in physics.)
Interesting thread. Tac-tics response was great. I wish I'd seen it explained like that a long time ago.
There is a system known as the "Riemann sphere" where operations [itex]+[/itex] and [itex]\cdot[/itex] are defined on a sphere. Except a few combinations are undefined. This does have a 0 and division by 0 is defined (with an exception 0/0 is undefined). It also has [itex]\infty[/itex]. For example [itex]a/0 = \infty[/itex] if [itex] a \ne 0[/itex]. And [itex] 0 \cdot \infty[/itex] is undefined. Often thought of as an extension of the complex numbers by adding one extra point [itex]\infty[/itex].
If this seems interesting to you, see if you can look it up.
79
x/x=1 for all real non zero x. Could 0/0 be defined as zero? Would that have any major consequences for Riemann sphere arithmetic or even standard arithmetic? For example we have the Dirac delta "function" which is zero everywhere except when x=0 where the "function" is infinite. The Dirac delta is defined for all real numbers and need not be affected by defining 0/0 as zero.
Hurkyl
Staff Emeritus
This is a reasonable description of the number systems a layperson typically encounters , but it doesn't work when you start studying more interesting things such as: modular arithmetic, angular position, polynomial rings, function fields, tensor fields, cardinal numbers, extended real numbers.
And some other interesting things would fit in your hierarchy, but it would cause branching. For example, one interesting ring is the Gaussian integers are the set of all complex numbers of the form m+ni where m and n are integers.
Even within the hierarchy you mentioned, you generally lose properties as you go up. The natural numbers has the property that mathematical induction works for them, but it doesn't work with the rational numbers. The real numbers have an ordering, but the complex numbers do not.
Of course, you gain properties too: the complex numbers are algebraically closed -- every complex polynomial has a root -- but the real numbers do not have that property.
You can define things where division by zero is sometimes or even always defined. But this is where "losing properties" rears its ugly head: if we insist on keeping all of the algebraic identities we know and love, you can prove that all numbers are equal, and so this is a very boring mathematical structure.
Probably the most useful structure that allows division by zero is the projective numbers -- but in this system, 0/0 is still undefined, as is 1/0 + 1/0. Wheels are closely related structure where the four arithmetic operations are always defined, but arithmetic identities become more complicated, such as
[tex]x \cdot z + y \cdot z = (x + y) \cdot z + 0 \cdot z[/tex]​
(Pay careful attention to the fact that in a wheel, it is possible to have [itex]0 \cdot z \neq 0[/itex])
CRGreathouse
2,820
You can use induction on the rationals, as long as your inductive step lets you walk along Stern's diatomic series.
:approve:
OK, so I'm feeling snarky today. Hurkyl's point about losing properties as you move 'up' the hierarchy is actually a very useful concept.
No, because division by zero is not division. The operation of division simply doesn't apply when the divisor is 0. It means that no operation is to take place, so it cannot be given a number or variable. You'd have to use some other (new?) operation that is not division.
I do wish there was an accepted symbol for undefined though.
That's an interesting concept. Is there a particularly text that would provide me with a good explanation of Stern's diatomic series?
DaveC426913
2,425
Bah. Mathematicians are thieves. The concept was stolen from the object-oriented programming concepts of 'prototypes' and 'inheritance', which preceded the invention of math by many centons.
:devil:
is the idea of Blue Jaunte to define a ring of 'infinite numbers?
[tex] I(R)=(a,b =Real |a+b\infty = I ) [/tex]
Mentallic
3,798
94
Oh as do I. It just doesn't seem as elegant when being able to express every defined solution concisely in a mathematical sense, then for the undefined solutions, I need to write in words "undefined". It just... suks.
I've come to understand for myself that even though 1/0 is undefined, it still has useful properties such as being able to imagine it as being [itex]\infty[/itex] and thus being able to solve equations with this little issue. e.g. [itex]tan\theta=1/0[/itex] would give [itex]\theta=\pi/2\pm n\pi[/itex].
Also for 0/0, I see this as (from my personal experience) that this is going to be a finite, non-zero value. The only thing holding you back from finding this value is to find the limit of such equations that use this. e.g. finding the value of f(0) in [itex]f(x)=xcotx[/itex]
Hurkyl
Staff Emeritus
We don't imagine -- we construct a new number system (e.g. the projective numbers) in which 1/0 is defined, and use that one instead of the real numbers.
By the way, both of these limits are of the form 0/0:
[tex]\lim_{x \rightarrow +\infty} \frac{x}{x^2}[/tex]
[tex]\lim_{x \rightarrow +\infty} \frac{x^2}{x}[/tex]​
Mentallic
3,798
94
Ahh ok I didn't know that, thanks.
Did you mean for the limits to be approaching 0?
In that case, yes it's true, but for all cases that I can think of, they can always be transformed into multiple limits such as
[tex]\lim_{x \rightarrow 0} \frac{x}{x^2}=\lim_{x \rightarrow 0} \frac{x}{x}* \lim_{x \rightarrow 0} \frac{1}{x}=1*\frac{1}{0}=\infty[/tex] on those projective numbers you've mentioned :smile:
Hey
I'm a first year math student at university and I've been trying to define this whole division by zero as well.
Everybody keeps going on about the division being the inverse of multiplication and all of that. What I think you guys missed is that zero is neither positive nor negative. Zero is where everything starts. In the system of numbers zero i defined as a integer and a whole number. And logic will tell us that any integer divided by itself is equal to one.
Now what I want to know is can one define 0 as a integer or a whole number...
Please respond to this and give me some ideas. I am not a very intelligent guy
Not if it is zero
Since I've started learning division, it is learnt that division by zero is undifined. But in the book "Introduction to Analytic Number Theory" by Tom M. Apostol, I've found that "Zero divides only zero" [Theorem 1.1 (h)]. What does this statement mean?
Hurkyl
Staff Emeritus
The set of things which zero divides is {0}.
Division by zero? NO! Wes Hughes
CRGreathouse
2,820
k | n is defined as "there exists an integer m such that mk = n". So 0 | 0 means that there exists some integer m such that 0m = 0.
In theoretical computer science there is a generally accepted convention
that uses the symbol [tex]\bot[/tex] to denote undefined. This is because undefinedness in programming language semantics (e.g. non-termination) is usually characterised as the least element in
a partial ordering where all (interesting) sets of values have a least element, as does the whole ordered space, hence the use of "bottom".
If integer division is implemented as repeated subtraction, then a
naive treatment of division by zero will result in an infinite loop,
modelled theoretically in programming semantics as [tex]\bot[/tex].
Related Threads on Defining division by zero?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
