What is the ambiguity in forming new functions?
In summary, I think the first definition is just a special case of the second. Single valued functions are simpler and easier to work with, and they allow us to do useful mathematics.
DumpmeAdrenaline
78
Why do we want to always deal with single valued functions?
In the classical treatment a function is a rule which assigned to one number another number. In the modern sense, it is a rule which assigns to each element in a set called the domain an element (one element) in a set called the range.
The first definition does not negate the assignment of one element to two or more different elements from being a function. If we employ the first definition for a function, we can still talk about 1-1 and onto functions.
However, there is ambiguity in forming new functions from old functions.
If an element in the domain is mapped into two different images, which of the two images do we choose to take on to perform the allowed operations on functions.
Because it is simple and easy, I think. As an example inverse function of y=x^2 is actually
[tex]x=\pm \sqrt{y},y>0[/tex]
Here we prefer to choose positive one and invent a symbol ##\sqrt{}## for it. Then we will proceed to deal multi valued-functions in an advanced curriculum.
If you have a multi-valued function, then you must be careful how you operate on the set of function values. You'll see things like:
$$x = -b \pm \sqrt{b^2 - 4c}$$Which can also be written $$x = -b + \sqrt{b^2 - 4c} \ \text{or} \ x = -b - \sqrt{b^2 - 4c}$$Here, technically, ##x(b,c)## is a multi-valued function of ##b## and ##c##. And, you always have to take into account that there are two possible values for ##x##.
Likes DumpmeAdrenaline
I think the idea is to be able to analyze mathematical objects using calculus. If you take derivative of some function and it gives two different results how will you interpret it? In order to use calculus you have to have well-defined functions.
We don't always do this, but as already mentioned, single-valued functions are simpler. Further along in mathematics you'll come to vector-valued functions -- functions whose output is a vector.
For example, ##\vec r(t) = <f(t), g(t), h(t)>##.
I disagree. In fact I think the first definition is just a sepcial case of the second, applying only to "numbers". But in both cases the central idea is that for each [itex]x[/itex] there is exactly one [itex]y[/itex] such that [itex]f(x) = y[/itex]
Likes Hornbein and DumpmeAdrenaline
If you want arbitrary multi value functions ##\mathbb{R}\to \mathbb{R}##, this is the same as single valued functions ##\mathbb{R}\to P(\mathbb{R})## where ##P(\mathbb{R})## is the power set of ##\mathbb{R}##, the set of all subsets of the real numbers.
But these functions can be very strange. You might have some f where ##f(0)= \mathbb{Q}##, ##f(1)= \{0,\pi,12\}##, and ##f(2)## is the set of transcendental numbers.
Ok, what do you do with this function? It seems kind of useless. Even among single valued functions, we restrict ourselves to continuous functions, or differentiable functions, or integrable functions, in order to do useful mathematics.
Likes docnet and DumpmeAdrenaline
Perhaps at this point we should wait for the OP to respond.
Likes Office_Shredder, Infrared and Mark44
Where did you get the first definition? The usual definition of a real valued function does not allow it assign one number to two distinct numbers.
I can imagine why we prefer to choose the positive one, as we can define for instance the distance between two numbers in terms of the positive square root. Some operations cannot be interpreted with multiple images so without loss of generality we deal with single valued functions.
The second definition applies to all well defined sets with objective tests for membership (an element does not necessarily mean we are only dealing with real numbers).
I can infer from this that we limit ourselves to the study of physical situations where for every (one input or more) we obtain a unique value for y in the image set.
I think the point is more, we limit ourselves to the study of mathematical objects with sufficient structure to say interesting things. Often these structures are inspired by physics, but not always (e.g. number theory). If you permit arbitrary multi valued functions where the number of values per input is arbitrary, then you just have arbitrary functions ##\mathbb{R}\to P(\mathbb{R})##. From a set theory perspective this is maybe interesting - e.g. what is the cardinality of the set of all such functions? But in terms of asking 'do these functions have any similar properties beyond the one that we wrote down' the answer is no. Versus e.g. single valued continuous functions, they have lots of shared properties - they satisfy the intermediate value theorem, they achieve their minimum and maximum value on any closed interval, etc. There are lots of things you can prove about a function once you know it's continuous, and proving things is the goal of mathematics.
Are you asking about functions of multiple variables, e.g. f(x,y,z)? Those would still be functions.
No, That's not what this thread is about.
From post #1:
By that definition, the "real valued functions" are a small minority of functions and not much use to us. Afaics, it implies a monotonic relationship and you find a lot of those in real life that don't.
I did my formal Mathematical Analysis course more than fifty years ago so things may have changed by now, but still . . . . .
I think he meant "does not allow it to map one number to two distinct numbers". Not that a function must be one-to-one.
So that excludes x= Root y?
No. ##f(x) = \sqrt x## is a function. But, ##f(x) = \pm\sqrt x## is two functions or a multi-valued function.
Likes sophiecentaur
OOOO KKKKK you Mathematicians live in a funny old world and you have a need to tie things up tidily. So what you are saying is that most functions are, in fact 'multivalued functions'?? Fair enough :wink:
Define "most"!
Likes sophiecentaur
Strictly speaking a "multi-valued function" is not a function that has the property of being multi-valued. It's a new object that is not a function.
Likes sophiecentaur
PeroK said:
Define "most"!
Any 'relationship' between two variables that involves a turning value. All my Maths notes that contain the word 'function' are possibly bo****x then? I used to write sentences like "any function that is continuous and differentiable in the range 0<x<1 ". Clearly not enough. I will have to tread much more carefully now; no more BS in my future posts.
The most general definition of a real-valued function on ##\mathbb R## or some subset of ##\mathbb R## (the domain of the function) is a rule that maps every real number in the domain to a real number.
Functions may have properties like being integrable, continuous, differentiable, infinitely differentiable.
Being multi-valued is not then a property, as it is excluded by definition.
A multi-valued function is a rule that maps every real number in the domain to one or more real numbers (to a set of numbers). A function is then a special case of a multi-valued function.
I can't count the times that members here have held the misconception that ##\sqrt y## has two different values -- one positive and one negative. By definition and convention, the symbol ##\sqrt y## is the principal square root, and is the positive number x such that ##x^2 = y##.
Not sure what you mean by "turning value," unless possibly you mean a local minimum or local maximum point. There's a very simple test for determining whether the graph of a relation is a function or not: a vertical line never intersects more than one point on the graph. Algebraically this is saying that if f(x) = y1 and f(x) = y2, for distinct y1 and y2, and for any x in the domain of f, then f is not a function.
No problem with the phrase above other than a possible misconception about the definition of the term, function.
A multi-valued function is to a function as a counterfeit currency is to a currency.
Not so, if you consider multi-valued functions to be synonymous with vector-values functions.
To any multivalued mapping ##f:X\to Y## you can easily put in correspondence a single valued mapping: ##\tilde f:X\to 2^Y,\quad \tilde f(x)=\{f(x)\}## :)
This assumes that every input has the same number of outputs.
For vector-valued functions, this is the case, assuming the input value is in the domain.
1. What is ambiguity in forming new functions?
Ambiguity in forming new functions refers to the lack of clarity or uncertainty in the definition or purpose of a newly created function. This can lead to confusion and difficulty in understanding and implementing the function.
2. Why is ambiguity a problem in forming new functions?
Ambiguity can be a problem in forming new functions because it can make it difficult for others to understand and use the function. It can also lead to errors and bugs in the code, making it less reliable and efficient.
3. How can ambiguity be avoided when creating new functions?
Ambiguity can be avoided by clearly defining the purpose and functionality of the new function. This can be done through proper documentation, clear naming conventions, and thorough testing to ensure the function works as intended.
4. What are some common causes of ambiguity in forming new functions?
Some common causes of ambiguity in forming new functions include using unclear or inconsistent naming conventions, not fully understanding the problem the function is trying to solve, and not thoroughly testing the function before implementation.
5. How can ambiguity in forming new functions impact the overall project?
Ambiguity in forming new functions can have a negative impact on the overall project by causing delays in development, increasing the likelihood of errors and bugs, and making it difficult for team members to collaborate and understand each other's code. This can ultimately lead to a decrease in the project's efficiency and success.
  • Calculus
