Definition of Limit Paradox
  1. Aug 28, 2008 #1
    I have a paradox here. Please tell me what is wrong.
    I need to prove that [tex]\lim_{x \rightarrow a-}f(x) = -\infty[/tex]
    f(x) = [tex]\frac{x}{(x-1)^2(x-3)}[/tex]
    1st case
    For all M , where M is a arbitrary large number, there exists [tex]\delta[/tex]>0 such that f(x)<M whenever 0 < a-x < [tex]\delta[/tex]
    0 < a-x < [tex]\delta[/tex].
    a-[tex]\delta[/tex] < x < a
    Therefore x<a ....(1)
    Let |x-a| < [tex]\delta[/tex]1 where [tex]\delta[/tex]1 is a positive number such that [tex]\frac{1}{(x-1)^2(x-3)}[/tex] < P where P is a positive number. ...(2)
    < [tex]\frac{a}{P}[/tex] .... from (1) and (2)
    Let [tex]\frac{a}{P}[/tex]=M
    f(x) < M
    Done.
    2nd case (The opposite case)
    For all M , where M is a arbitrary large number, there exists [tex]\delta[/tex]>0 such that f(x)>M whenever 0 < a-x < [tex]\delta[/tex]
    As above,
    Therefore x>a-[tex]\delta[/tex] ....(1)
    Let |x-a| < [tex]\delta[/tex]1 where [tex]\delta[/tex]1 is a positive number such that [tex]\frac{1}{(x-1)^2(x-3)}[/tex] > P where P is a positive number. ...(2)
    > [tex]\frac{a-\delta}{P}[/tex] .... from (1) and (2)
    Let [tex]\frac{a-\delta}{P}[/tex]=M
    f(x) > M
    Done.
    I derive the both cases with the same arguments but obtain opposite result. What is wrong with my proof?
  3. Aug 28, 2008 #2
    Haven't read yoru question but you would do \lim_{x \rightarrow a} to give you:
    [tex] \lim_{x \rightarrow a}[/tex]
  4. Aug 28, 2008 #3
    Dick
    There's a LOT wrong that 'proof'. It doesn't really prove anything. You can't even BEGIN to prove something about the limit of f(x) as x->a until you know what a is!!!! What is it?
  5. Aug 28, 2008 #4
    HallsofIvy
    Staff Emeritus
    One problem you have is that you haven't said what a is!
    is true only if a= 1. where did you use that?
  6. Aug 28, 2008 #5
    You all are right. It is impossible to define the limit if a is not given.
    I confuse this with the case [itex]\lim_{x \rightarrow a} f(x) = a^4[/itex],
    where f(x) = x4.
    https://www.physicsforums.com/showthread.php?t=252170
    I think it is correct in x4 case because it is continuous and the limit of it when x is approaching "a" is always equals to a4 whereas in this question, I can only define that when x is approaching a certain "a", the limit is -[tex]\infty[/tex] but generally when a is any numbers, the limit is not [tex]-\infty[/tex].
    Please help me to check this so that I can make sure that what I am doing is correct.
    Prove that [itex]\lim_{x \rightarrow 1}f(x) = 1[/itex] , where [itex]f(x) = \frac{1}{x}[/itex].
    For all \epsilon >0 , there exists \delta >0 , such that whenever 0<|x-1|<\delta , then [itex]|f(x)-1|<\epsilon[/itex].
    |f(x)-1|
    [itex]= |\frac{1}{x} - 1|[/itex]
    [itex]= |\frac{1-x}{x}|[/itex]
    [itex]=\frac{|1-x|}{|x|}[/itex]
    [itex]=|1-x|*\frac{1}{x}[/itex]
    By letting [itex]\delta = \delta_1[/itex] where [itex]\delta_1[/itex] is an arbitrary positive number such that [itex]\frac{1}{x} < M[/itex] , where M is an arbitrary positive number. (This is the part I am not very sure, my reasoning is there exists [itex]0<|x-1|<\delta_1/[/itex] such that I can get [itex]\frac{1}{|x|} < M[/itex], but how can I make sure that this assumption is always correct)
    So, [itex]|f(x)-1| < \delta*M = \epsilon[/itex]
    where [itex]\delta = min [ \delta_1 ,\frac{M}{\epsilon}][/itex]
  7. Aug 28, 2008 #6
    Y some of the LATEX is not displayed?
  8. Aug 29, 2008 #7
    HallsofIvy
    Staff Emeritus
    Because you didn't tell it to! You did not include the [ tex ] and [ / tex ] tags. Also do not use the HTML tags and in LaTex. use ^ and _ instead.
  9. Aug 29, 2008 #8
    HallsofIvy
    Staff Emeritus
    You need to be a little more careful. If, say, 0< |x-1|< 1/2, then -1/2< x- 1< 1/2 so
    1/2< x< 3/2. Now you can say that 1/x< 1/(1/2)= 2. |f(x)-1|< 2|1- x|.
  10. Aug 29, 2008 #9
    Consider the function f(x) = x/{(x-1)2(x-3)}
    If x has any value other than 1 or 3, the value of f(x) can be calculated by substituting the value of x in the formula. For example, if x=5, f(x) = f(5) = 5/(42*2) = 5/32. The limit of f(x), for x approaching 5, whether from above or from below, will also be 5/32, as f is a continuous function on any interval that does not include 1 or 3.
    The only nontrivial limits are therefore those for x approaching 1 or 3 from above or from below, and those for x approaching plus or minus infinity (that is, x increasing or decreasing without bound).
    First we should realize that f(x) = 0 if and only if x = 0.
    For very large |x|, f(x) will be nearly equal to x/x3 = 1/x2, which approaches zero from above if x approaches plus or minus infinity. The same should be true for f(x).
    For x approaching 1 from below (i.e. x<1 and x<3, but x>0) f(x) will have negative values.
    For x approaching 1 from above (i.e. x>1 but x<3) f(x) will also have negative values.
    For x approaching 3 from below (i.e. x<3, but x>1) f(x) will still have negative values.
    For x approaching 3 from above (i.e. x>3 and x>1) f(x) will have positive values.
    If |x-1| < epsilon, |f(x)| will be larger than 1/(3-1)*1/(epsilon)2.
    If |x-3| < epsilon, |f(x)| will be larger than 1/(3-1)2*1/epsilon.
    These absolute values will therefore increase without bounds when epsilon approaches zero.
    Therefore f(x) approaches minus infinity if x approaches 1 from above or below, or 3 from below; and f(x) approaches plus infinity if x approaches 3 from above.
Similar Discussions: Definition of Limit Paradox
  1. Definition of Limit (Replies: 2)
  2. Definition of Limit (Replies: 3)
  3. Definition of Limit (Replies: 2)
  4. Definition of a limit (Replies: 3)
  5. Definition of a Limit (Replies: 1)
Loading...
