Definition of Torque: What Is Torque?
In summary, The equation for torque is t = r x F, where r and F are vectors. There are some questions about r, such as whether it is a true position vector or the distance from the axis of rotation to the mass. Additionally, r is typically the initial position of the mass with respect to the axis of rotation, and F is the force resolved into its x,y and z components. This is important because if the rotation axis is perpendicular to both, the definition of r as the vector from the axis of rotation to the point where the force acts still applies. The cross product of r and F determines the direction and magnitude of the torque. The force acting on the pivot arm can be simplified as its x,y,z components
Timothy S
49
Hello,
I found the equation for torque to be t = r x F, where r and F are vectors. I have several questions about this; is r a true position vector, or is it the distance from the axis of rotation to the mass? is r the initial position of the mass with respect to the axis of rotation?
My current understanding of the equation is the r is the initial position of the mass, and that F is simply the force resolved into its x,y and z components. Is this true?
if the rotation axis passes through point O and a force ##\vec F## is applied at point P, the ##\vec r = \overrightarrow{OP}## ... that definition works when rotation axis is perpendicular to both. There should have been a diagram with the equation.
Likes RaulTheUCSCSlug
r is a vector that points from the axis of rotation to where the force vector acts. The force is then the force acting on that point on r. The cross product of both vectors will give you the direction and magnitude of the torque. Therefore the force is the force that acts on the pivot arm, which can be simplified as x,y,z components.
Perhaps this website might help? https://www.physics.uoguelph.ca/tutorials/torque/Q.torque.intro.html
What is torque?
Torque is a measure of the twisting force that is applied to an object. It is typically represented by the symbol "τ" and is measured in units of newton-meters (N·m) in the International System of Units (SI).
How is torque calculated?
Torque is calculated by multiplying the force applied to an object by the distance from the point of application to the axis of rotation. Mathematically, this can be represented as τ = F * r, where τ is torque, F is force, and r is the distance.
What is the difference between torque and force?
While both torque and force involve the application of a physical force, the main difference is that torque involves a twisting or rotational motion, while force involves a linear motion. Additionally, torque is dependent on both the magnitude and direction of the force, whereas force is only dependent on magnitude.
What are some real-world applications of torque?
Torque is a fundamental concept in engineering and physics, and can be applied in a variety of real-world scenarios. Some common applications include tightening screws and bolts, turning a steering wheel, and opening a door. Torque is also important in machines and engines, such as car engines and turbines.
How does torque affect rotational motion?
Torque is directly related to rotational motion, as it is the force that causes an object to rotate around an axis. The magnitude of the torque determines the speed of the rotation, while the direction of the torque determines the direction of the rotation. This relationship is described by Newton's Second Law of Motion, which states that the net torque on an object is equal to its moment of inertia times its angular acceleration.
  • Mechanics
  • Mechanics
