Derivation of Proper Time, Speed, and Acceleration in SR
In summary: Earth frame faster than the speed of light.Likewise, proper acceleration or a_p = a\gamma^3 also can be > c but I have been told that there is no limit on acceleration other than that the coordinate velocity be < c . Is that valid?Yes, there is no limit on acceleration in special relativity as long as the coordinate velocity remains less than the speed of light. However, in general relativity, there is a limit on acceleration called the "tidal acceleration" which occurs near massive objects like black holes. This is because the
stevmg
696
This is a continuation of the thread Derivation of proper time of acceleration in SR
DrGreg said:
If you are working in a (t,x) coordinate system, and [itex]\tau[/itex] is proper time:
coordinate acceleration = d2x/dt2
proper acceleration = acceleration measured in the coordinate system of a comoving inertial observer = what an accelerometer measures
rapidity = [tex]\tanh^{-1} \frac {dx/dt}{c}[/tex]
coordinate time = t
coordinate velocity = dx/dt
proper velocity = [tex]dx/d\tau[/tex] although I prefer to call it "celerity" because of possible confusions that can occur (especially over proper acceleration).
yuiop said:
[tex]a = \frac{dv}{dt} = \alpha \gamma^{-3} = \alpha (1-v^2/c^2)^{3/2} [/tex]
This can be rearranged to:
[tex]\frac{dt}{dv} = \frac{1}{\alpha(1-v^2/c^2)^{3/2}} [/tex]
Integrating both sides with respect to v gives:
[tex]t= \int \left( \frac{1}{\alpha(1-v^2/c^2)^{3/2}} \right) dv = \frac{v}{\alpha \sqrt{1-v^2/c^2}}[/tex]
When rearranged:
[tex]v= \alpha t \sqrt{1-v^2/c^2} [/tex]
[tex]\rightarrow v^2 = (\alpha t)^2 - (\alpha t v/c)^2[/tex]
[tex]\rightarrow v^2 (1+ (\alpha t /c)^2) = (\alpha t)^2 [/tex]
[tex]\rightarrow v = \frac{\alpha t}{\sqrt{1+(\alpha t/c)^2}} [/tex]
I am still not sure how we get from the [itex]p = mv/\sqrt{1-v^2/c^2}[/itex] and [itex]F=dp/dt[/itex] to [itex]a = \alpha \gamma^3[/itex].
DrGreg said:
That's true for the proper time of an inertial object, but in general for a non-inertial object you have to use
[tex]\tau = \int d\tau = \int \sqrt{dt^2 - dx^2 / c^2}[/tex]​
from which you get
[tex]\frac{d\tau}{dt} = \sqrt{1 - \frac{1}{c^2}\,\left(\frac {dx}{dt}\right)^2} = \frac{1}{\gamma}[/tex]​
i.e.
[tex] \frac{dt}{d\tau} = \gamma[/tex]​
hence
[tex] \frac{dx}{d\tau} = \frac{dx}{dt} \, \frac{dt}{d\tau} = \gamma \frac{dx}{dt} = \gamma v[/tex]​
in the usual notation.
proper acceleration = the coordinate acceleration measured by a comoving inertial observer
JesseM said:
Physically the "proper time" along a given worldline just means the time elapsed on a clock that travels along that worldline. If you want to know the proper time between two events on the worldline of a clock moving at constant velocity along the x-axis of some frame, it's just [tex]\Delta \tau = \sqrt{\Delta t^2 - (1/c^2) \Delta x^2 }[/tex], where [tex]\Delta t[/tex] is the difference in coordinate time between the two events and [tex]\Delta x[/tex] is the difference in coordinate position. This can be rewritten as [tex]\Delta \tau = \Delta t \sqrt{1 - (1/c^2) (\Delta x / \Delta t )^2 } = \Delta t \sqrt{1 - v^2 /c^2 }[/tex] which is just the standard time dilation formula. For a worldline where the velocity is varying in a continuous way, you can approximate its worldline by a "polygonal" worldline made up of a series of constant-velocity segments each lasting a time interval of [tex]\Delta t[/tex] with instantaneous accelerations between them, then if the velocity during the first time interval v1 (which could just be the average velocity during the same interval for the path with continuously changing velocity that you are trying to approximate), the second has velocity v2, and the final segment has velocity vN, then the total elapsed time would just be the sum of the elapsed time on each segment, or [tex]\Delta t \sqrt{1 - v_1^2 /c^2} + \Delta t \sqrt{1 - v_2^2 / c^2} + ... + \Delta t \sqrt{1 - v_N^2 /c^2}[/tex]. And in the limit as as the time interval of each segment goes to zero (so the number of segments approaches infinity), this approximation should approach perfect agreement with the proper time on the original path with continuously-changing velocity. Since an integral is just the limiting case of a sum with smaller and smaller intervals (or an infinite series of intervals which each have an 'infinitesimal' time dt), that means the proper time along a worldline where the velocity as a function of time is given by v(t) can always be computed according to the integral [tex]\int_{t_0}^{t_1} \sqrt{1 - v(t)^2 /c^2} \, dt[/tex]
starthaus said:
From the blog:
1. Proper speed
[tex]v_p=\frac{dx}{d\tau}=\gamma \frac{dx}{dt}=\gamma v[/tex]
2. Proper acceleration
[tex]a_p=c \frac{d\phi}{d\tau}=\gamma^3*\frac{dv}{dt}=\gamma^3*\frac{d^2 x}{dt^2}=\gamma^3 a[/tex]
t=coordinate time
[itex]\tau[/itex]=proper time
v=coordinate speed
a=coordinate acceleration
We have definitions for proper time, proper speed, proper acceleration, coordinate speed, coordinate time, and coordinate acceleration.
1) What is the definition ofproper distance?
2) If proper speed (or velocity) is [itex] v_p = v* \gamma[/itex] then it is conceivable for [itex] v_p [/itex] to exceed the speed of light. Is that true? If so, what physical meaning does that have? Is there a limit on [itex] v_p < c?[/itex]. Seems like there should be in the sense that there should be NO FR for a given observation in which [itex] v \geq c [/itex]
Likewise, proper acceleration or [itex]a_p = a\gamma^3[/itex] also can be [itex] > c [/itex] but I have been told that there is no limit on acceleration other than that the coordinate velocity be [itex] < c [/itex]. Is that valid?
The proper distance between two events with a spacelike separation is the distance between them in the frame where they occur simultaneously.
Proper speed is the distance you travel in some specific (arbitrary) inertial frame per unit of the traveler's own proper time. For example, suppose I want to define proper speed relative to the Earth's rest frame for a rocket traveling at 0.8c relative to the Earth. Then to reach a destination 20 light-years away in the Earth frame, the rocket would take 20/0.8 = 25 years to get there in the Earth frame, but the rocket's own clock would be slowed by a factor of 0.6 so the rocket would only experience a time of 25*0.6=15 years to reach the destination. In this case the "proper speed" is 20 light-years / 15 years = (4/3)c. As you can see from the http://math.ucr.edu/home/baez/physics/Relativity/SR/rocket.html it is quite possible to reach destinations which are a vast distance away in the Earth's frame in fairly short amounts of onboard time, like getting to the center of the galaxy 30,000 light years away in only 20 years of onboard time, accelerating at 1G for half the trip and then decelerating at 1G for the second half.
That doesn't really make sense, speed and acceleration have different units so you can't say an acceleration is "greater than c" or "less than c" any more than you can say a mass or time interval is "greater than c" or "less than c". But if you're wondering about the physical meaning of proper acceleration, proper acceleration at any point on an object's worldline is just the instantaneous coordinate acceleration in the inertial frame where they are instantaneously at rest at that point, and the proper acceleration also corresponds to the G-force that would be felt by an observer on board the accelerating rocket (which could be measured with an accelerometer).
Yes, at any given moment the acceleration can be arbitrarily high, but your coordinate acceleration in some inertial frame must decrease before you reach a speed of c in that frame.
If you think about it long enough, celerity (=proper speed) is what a car's speedometer measures -- the revolutions of a wheel measure distance along the ground, but the time is the car's own time.
You can't compare apples with oranges so it makes little sense to compare a celerity with a speed. The celerity of light is infinite*, so the celerity of any mass is always smaller than the celerity of light.
*To be pedantic and strictly rigorous about this, it would be more accurate to say the celerity of light is undefined and the celerity of any massive object is unbounded, diverging to infinity as the speed tends to c.
I am not sure Dr Greg?
The ground is length contracted during movement, so the speedometer would measure velocity wrt. the length contracted road. No?
Celerity would be proper time with respect to 'map distance'.
Am I wrong?
That is why in the twins paradox the "traveling twin" ages slower than the sit-on-his-butt twin - which you calculated for me me many months ago. Of course, that poor slob who goes to a distant galaxy and returns in a fairly short time finds all his friends and family are a hell of a lot older than he is - and he can't go back.
You're right - acceleration and velocity are two different animals. The restriction in each FR is that the velocity must not equal or exceed c.
Yes, you are absolutely right, [tex]v_p=v \gamma(v)[/tex] implies [tex]c_p= c \gamma(c)=\infty[/tex]
It makes no sense to compare celerity with speed and to declare that celerity can exceed speed of light. It is like saying that tomatoes are redder than potatoes are elliptical. :-)
Then, is proper speed
[tex] v_p = v \gamma ?[/tex]
Then, what does celerity mean? )-:
It basically means how far you travel using a chart divided by the travelers proper time.
Example:
Suppose a space traveler wishes to go to location X far away from Earth.
Now, he checks the latest edition of Google space charts and verifies it is 1 light year away. He wants to get there in 0.75 years, how fast does he have to travel?
The answer is simple: he needs a celerity (or proper velocity) of 1 1/3 since 1/0.75=1 1/3.
A celerity of 0.75 translates into a velocity as follows:
[tex]v = \frac{w}{\sqrt{1 +w^2}} = \frac{0.75}{\sqrt{1 +0.75^2}} = 0.6[/tex]
So he needs a velocity of 06c and relativity takes care of the rest!
Example:
well put
yes
Proper speed and celerity are two different names for the same thing.
Example:
So he needs a velocity of 0.6c and relativity takes care of the rest!
Passionflower -
I am having a brain dump )-:
where does this equation below (from your post) come from?
I don't remember it.
In addition (this is for anyone) I have a hypothetical simple problem.
An astronaut departs Earth (point E.) He/she accelerates to 0.6c over a two year period.
He/she then travels at 0.6 c for 6 years and then decelerates to 0 over the next two years to a planetary system at Star S.
The return is the opposite:
acceleration from S from 0 to 0.6 over two years,
steady state coasting at 0.6 c for six years
deceleration to 0 at E over two years.
This is a perfectly symmetrical "loop" hence the astronaut will be younger than the cohort of people who were the same age as he/was when he/she left and the speed was relativistic (0.6 c over a total of 12 years + the accleration/deceleration phases.)
I need to figure out:
a) We know by Earth time or lab time as starthaus often chooses to refer to it, this astronaut was gone for 20 years. How much older is this astronaut in his/her own or rocket ship time ?
b) How far did he/she actually travel (one way or both ways) both in distance as measured by Earth and distance as measured by te rocket ship.
c) Assume, of course, no effect of gravity from other planetary or celestial bodies.
This acceleration is about [itex] 3 m/sec^2 [/itex] which is 1/3 gravity. This would be "do-able."
stevmg said:
Passionflower -
w is the same [tex]v_p[/tex]
So, if you invert:
[tex]w=v \gamma(v)[/tex] you get Passion's formula.
So, if you invert:
I
starthaus - "I" - what?
I know that for 12 "earth-years" the astronaut coasted for 2x0.6x6 = 7.2 light-years of Earth distance. The proper time of the astronaut would thus be (6 + 6) yr x 0.8 = 9.6 years for this period of "coasting" at 0.6 c. (That is because [itex] \gamma = 0.8 [/itex] for a v of 0.6.) This confirms the notion that the proper velocity of 7.2/9.6 = 0.75 c is greater than the Earth coordinate velocity of 7.2 ltyr/12 yr = 0.6 (given.)
Now I have to fish for the correct formulas in the prior thread on Derivation of Proper Time for Acceleration in SR to pick up the elapsed distances and proper times for the acceleration/deceleration phases. I will assume that we will start off at some acceleration [itex] a [/itex] in S (the Earth frame) which will decay over the two earth-years to 0.6 c.
There will be then 6 years of coasting. Then I will assume that at 8 Earth years out there will be a deceleration from 0.6 c to zero over two years (terminus at 10 years,) and then an acceleration from 0 to 0.6 c over two years starting at 10 years out with again a 6 year period of coasting and finally a deceleration from 0.6 c to 0 starting at 18 years out and ending up at 20 years. We have two periods of acceleration (0 [itex]\Rightarrow[/itex] 0.6 c) and two periods of deceleration (0.6 c [itex]\Rightarrow[/itex] 0.)
We don't know the distances during these four periods nor do we know the proper times during these periods.
Fishing for those formulas in that 100+ post thread will be a real bear. I will not object if I can get some input on that as I have no textbook. I don't even know what textbook would carry it. I think I have split the problem down to simple terms enough.
If nothing else, confirmation that
a) [itex] v_p = 0.75 c [/itex] during the coasting phase and that my proper times and distances for those coasting phases are correct.
b) My division of the trip into the above segments is correct
would be most helpful and prevent me from going down a blind alley.
This problem would be a piece of cake in Newtonian Physics even with a decaying accleration/deceleration..
...but you know the elapsed coordinate time . I must have shown you this calculation several times already.
starthaus -
You did - in earlier Sept. and maybe before that. I downloaded it then. Now that I've been through hyperbolic functions, I will seek to understand it and calculate the answers to my questions. I will get back when I am done with a "short" version of what I have done. I had to print it out. I can't read it on-line.
stevmg
1. What is special relativity (SR) and why is it important?
Special relativity is a theory proposed by Albert Einstein in 1905 that describes the relationship between space and time in the absence of gravitational forces. It is important because it has revolutionized our understanding of the universe and has been confirmed by numerous experiments.
2. What is the proper time in SR?
The proper time in SR is the time measured by an observer who is in the same reference frame as the event being measured. It is the time that is experienced by a clock that is stationary relative to the observer.
3. How is speed calculated in SR?
In SR, speed is calculated by dividing the distance traveled by the proper time. This is because the concept of simultaneity is relative in SR, meaning that different observers will measure different times for the same event. Therefore, using the proper time ensures a consistent measurement of speed.
4. What is the equation for acceleration in SR?
The equation for acceleration in SR is a = γ^3 * (dv/dt), where γ is the Lorentz factor and v is the velocity. This equation takes into account the time dilation and length contraction effects predicted by SR.
5. How does SR impact our understanding of time and space?
SR has shown that time and space are not absolute, but are relative concepts that can change depending on the perspective of the observer. It has also introduced the concept of spacetime, where time and space are intertwined and cannot be separated. This has greatly expanded our understanding of the universe and has led to many technological advancements, such as GPS systems, that rely on the principles of SR.
